Settings for DVD AND Web?
First shoot with FX1000 tomorrow and I have done a lot of posting and reading. Tomorrows project will end up both on DVD and the web. I will shoot with progressive set to OFF. If I use Sony Vegas to capture, are there certain settings I should set so I can end up with files that I can edit then use for both DVD and web?
5 weeks till first wedding, gotta get dialed in by then :) |
Re: Settings for DVD AND Web?
Thanks Eric, that explains a lot, however when I turn-off the down conversion, my Vegas Capture no longer recognizes or finds mt camera. I thought something seemed strange when it ingested at 720 X 480. Any thoughts on this problem?
Ok, upon further inspection, I have Sony Movie Studio HD Platinum 11.0 and cant get it to recognize after I switch the camera to HDV output. I do see the camera in my Devices & Printers. I downloaded HDV Split and that worked fine. Obviously quite the difference in quality! I cant see the frame width/height details when I right click, there is nothing there in those 2 fields.
Good news is editing is fine! It ingests as AVCHD and its not bad at all. I also used my Canon Vixia HF R300 and those files are a bit more sluggish to edit. Personally i don't like all clips as separate files, I think there must be some good workflow method of having them all as one. UPDATE: Finally figured out capture issue, in the settings it was set to "external" capture device. Working now, but also saves scenes as separate files. |
That's how Vegas works. That's how almost all HD-capable NLEs work. That's how film works, too.
