Vegas pro 10.0 e stop working as i add Magic Bullet in The clips
Gola guys,
I'm desperate cause i'm having Vegas crash every time i try to add from my Magic Bullet looks keychain window a color look that i created. It pops Up with a window: Vegas pro 10 stopped working .... I have to finish this video for tuesday but i can't color correct as i always have this kind of error Many thanks guys for The support |
Re: Vegas pro 10.0 e stop working as i add Magic Bullet in The clips
My first thought it I would forget Magic Bullet, use another method, and deal with Magic Bullet later. For basic color correct I use free AAV color lab, it's a snap and has made my life SO much easier. Good luck.
But i never had this issue before....
Maybe Someone else had The same problem... |
Good luck, sounds frustrating, I"m sure someone will chime in eventually.
Hi Marcus
Are you running 10e in 32 bit or 64 bit ?? I remember seeing a post where there was an issue trying to run Magic Bullet on the Win64 bit version. Chris |
Hallo Chris,
32 bit version! The only plugin i installed in The last 12 months is Pluraleyes.... Any chance of conflict? Many thanks for helping me out guys! Really appreciate it |
Sorry Marcus, but I just opened Vp10e Build 737 and added MBL2 to an MXF Event and it's working fine here.
G |
Again, Marcus, but I just opened Vp10e 64bit Build 738 and added MBL2 to an MXF Event and it's working fine here.
I also re-tried MBL2 in VP12 Build 486 and works as expected. Grazie |
Yesterday i added MBL in a portion of video of 3 minutes of length....
No crash but..... 5 hours of rendering Times!!!! Something is wrong here! I have a nvidia quadro fx3600 with 4 G of RAM, unfortunately running XP32. What should i change in The settings? |
RAM preview set to 350
Max number of render threads 4 Should i change anything? |
Marcus, are still running your old laptop? If so, your slow render times with magic bullet may not be that far off, it might be about right?
Hi Jeff,
yes it is my old laptop but.....a couple of months ago the results were acceptable: 3 minutes of MB CC clips = 20 minutes of render not hours! |
Oh well, it didn't seem that far off to me, but I suppose I mistaken.
set RAM preview to "0"
I tried already but no changes!
