Build 770 Released
Haha so I download Vegas 12 on my new system & minutes later a update is released after my install, now to download again.
Sony Creative Software - Download: Vegas Pro 12 Notable fixes/changes in version 12.0 (Build 770) Added support for MOV files when exporting to Media Composer AAF format. Added support for writing sidecar XML files when rendering XAVC and XAVC S video. Added templates for rendering Sony XAVC / XAVC S video. When rendering XAVC S files, audio is now rendered in LPCM format. Fixed a bug that could cause a crash when rendering a project that contained an empty metadata command marker. Fixed a bug that could cause a crash when using Tools > Multicamera > Create Multicamera Track with an empty track selected. Fixed a bug that could cause a crash when importing 1440x1080 XAVC files. Fixed a bug that could cause a crash when dragging a preset chain (filter package) from the Plug-In Manager to an event, track, media file, or the video output. Fixed a bug that could cause a crash on some systems with NVIDIA graphics when reading 4:2:0 480p widescreen media. Fixed a bug that could cause Vegas to freeze when adding some interlaced MP4 videos to the timeline. Fixed a bug that could cause rendering to hang when rendering to XDCAM EX MP4 files with the Enable no-recompress long-GOP rendering check box (Preferences > General) selected. Fixed a bug that could cause .aaf files imported from Media Composer to be read using an incorrect frame rate in Vegas Pro. Fixed a bug that could cause .mov and .mp4 files imported from Media Composer to be read using incorrect timecode in Vegas Pro. Fixed a bug that could cause a hang when rendering 4K XAVC S video on some computers. Fixed a bug that could cause an error to be displayed when importing and MXF file from an Optical Disc Archive unit. Fixed a bug that could cause Vegas Pro to hang when reading MP4 video from the GoPro Hero 3+. Fixed a bug that added a green bar when reading 480p widescreen AVC files. Fixed a bug that could cause MainConcept AVC rendering to fail when using GPU-accelerated rendering with an OpenCL or CUDA GPU. Fixed a bug that prevented Vegas Pro from updating the file size estimate when Render Loop Region Only was selected during Blu-ray Disc burning. Fixed a bug that prevented Sony F5 cameras from playing XAVC HD 23.98p clips rendered in Vegas. Fixed a bug that caused the Iris transition to reverse A- and B-roll video when GPU acceleration was turned off. Fixed a bug that prevented Vegas from correctly reading SD MP4 clips that were shot in portrait mode. Fixed a bug that prevented Vegas from persisting the View transform setting on the Video tab of the Project Properties dialog. |
