Vegas 12 new feature is driving me mad!
Vegas 12, which I've migrated to from 11 has this irritating new feature....a red handle appears at the end of an event and I don't know how I'm triggering it but I seem to lose video in the preview window when the timeline is paused and any fx that are enabled.
I'm just wondering what this feature is and what it's supposed to do and then I can disable it hopefully if I don't need it. The other new thing I'm not liking is the ability that V12 has now to have half sized windows for explorer, fx transitions etc. For me, they just get in the way to how I normally work within Vegas. Can I disable this new feature too? I'm aware there is a hidden Options dialogue you can access where this might be possible to deactivate these new features. Thanks if you can help. |
Re: Vegas 12 new feature is driving me mad!
Cheers Grazie ps, I like Broadstairs |
Maybe the OP has the Split Screen activated. Can be changed to the normal preview window, by clicking on the appropriate icon above the preview window.
The expanded edit mode is not entirely new feature, it is a combination of previously used expanding track layers, numtab editing shortcuts and new window layout.
To exit expanded edit mode and return to the previous window layout; perform any of the following actions: Choose Edit > Select > Exit Expanded Edit Mode. Press 5 on the numeric keypad. Double-click the event edge. Press Esc. |
The only way I've been able to see this is to double-click the edge of the clip. As I seldom double-click when editing, I've not seen a difference between editing in VP11 and VP12.
1 Attachment(s)
Hi guys, sorry for the delay in getting back but thanks so far for your help in this matter.
The red handle on the event is as you say and double clicking it removes it. As for the docking windows, I do wish I could get rid of Vegas' ability to make horizontal windows, I really don't want this, just the original method of having vertival docked windows side by side so that you just clicked on the relevant tab. It's enough to make me think about reverting back to V11. I've attached a screenshot showing the problem area. Hope someone knows how to stop this. |
You can store your favorite window layouts and recall its when needed.
Press F1 and search for Window layout: [quote] Quote:
Or hold down the CTRL key when moving an window and it won't dock.
No, that isn't the problem really....it's having two windows, one on top of the other, which wasn't in Vegas 11 or earlier. You just had vertical window columns then, each with their own tab when docked. That's what I'm trying to get back so the windows don't sit on top of each other like they are in the screen grab I posted earlier.
You can still do that in Vegas Pro 12. Just drag it to the upper-left corner of the window you want it to tab with.
Thanks Edward, I have been doing that but anytime I then open a new window, it seems to default to the new method of two windows, one on top of each other which is what I'm trying to over-ride. Just checking out the layout in Vegas 11, that wasn't possible in 11. I guess if V12 has no way of stopping this, then I'll have to go with it....just wish there was an option to turn it off.
I was just having a look at the Sony Vegas site Vegas Pro 12 Workflow and half way down, it reads "NEW! Vertical Docking Windows". That is the feature that has been introduced to V12. That is the feature I want to stop if possible.
Sorry to be a pain, guys, but it really does drive me mad. All help gratefully received. |
All the windows un-dock , can be re-sized and arranged as you want. I use 2 monitors and have them arranged in different sizes over the 2 monitors. Not sure I understand your problem.
Ron Evans |
Yes, it is a new feature of Vegas Pro 12 to add flexibility in how you can arrange windows. After you get your arrangement the way you like it, you can save that layout. In fact, you can save many layouts and easily recall them at any time.
I, personally, have not had an issue with this. I tend to use the default layout and do not dock any FX/Transitions/Media Generator windows. |
Chris? Do you want the ability to have "TABs" back? Is that it?
Cheers Grazie |
