March 3rd, 2014, 11:42 AM | #1 |
Speeding up SSDs
I formerly used the fastest HDD available, the Cheetah 15.7K SAS drives and switched to SSD drives. I'm am now using SanDisk Extreme II drives.
Disappointed in the poor performance while editing. When I hit "undo" during multicam editing the wait time is like 15 seconds or more. Playback is about same as before, it's only the undo thing that is lagging. I use undo a LOT while editing so this is a real inconvenience. Any of you performance geniuses (Kim!) have recommendations on things I should check to see if my SSDs are being held back?
"The horror of what I saw on the timeline cannot be described." |
March 3rd, 2014, 12:07 PM | #2 | |
Re: Speeding up SSDs
Even if your system has to recall that undo code each and every time you use it, 15 seconds is an eternity (as you well note) to a computer. I suggest you start monitoring your process with the resource monitor to see if you can catch any spikes occurring anywhere in your system when you're using the undo command. I'm thinking in particular that you might have some paging going on (to a HDD maybe). |
March 3rd, 2014, 12:41 PM | #3 |
Well Bruce, great minds think alike! At the time of writing I had just turned off paging, disabled cache flusing, disabled pre-fetch and superfetch.
I'll report back soon. Thanks for your suggestions. I did try an undo command and it appeared about 50% faster, I'll do a reboot, keep editing and see what happens. I think your idea of the paging thing might be on target.
March 3rd, 2014, 01:21 PM | #4 |
Since taking the above steps it's smidgen faster Bruce, still too much lag though.
March 3rd, 2014, 02:41 PM | #5 |
Sponsor: JET DV
Where are your temporary files (i.e. the "undo" files) located?
Edward Troxel [SCVU] JETDV Scripts/Scripting Tutorials/Excalibur/Montage Magic/Newsletters |
March 3rd, 2014, 04:15 PM | #6 |
I'd recommend testing your SSD to see if it is performing normally.
Atto Disk Benchmark ATTO Disk Benchmark Free Download For your drive you should be seeing around 500MB/s read and write. My only other thought is if you're using Windows XP, you will need to manually TRIM the SSD to restore any lost performance. |
March 3rd, 2014, 04:26 PM | #7 |
@ Edward: I don't know, wherever they are at by default.
@ Jody, I don't use Softonic for downloads nor do I use Cnet or similar sites, but I appreciate the recommendation.
March 3rd, 2014, 05:06 PM | #8 | |
I am sad you have some problems with your new SSD's. I dont know how you have started the setup with your SSD's, but Iam going to describe my way to handle the installation of new disks to your system. This is the way I correctly do it, based on other users problems, and therefor I have never had any problems by my self so far. Never clone your old HD to your new system SSD. Dont trust the manufactures software to do all the hard work for you. This is an easy way, but not an reliable way to do it. You should format your new SSD, do an fresh install of Windows and reinstall all your applications/plugins one by one. This is time consuming, but you will be pleased when you can editing nonstop, rather than trouble shooting time to time... Remember, remove ALL your drives from the motherboard when installing Windows on your new SSD. Dont plug the SSD's and your HD's in to your motherboard until the installation of Windows is completely finished. Only your system disk (your SSD) should be plugged in when installing Windows. There is some great benchmark apps for testing your SSD's, but it doesnt sound like that kind of a problem you are having. By the way, what operating system are you using Jeff? And do you use your SSD's in some kind of raid? Are you using any new generation motherboard? I dont remember how SSD's was inserted either, are all inserted to a 6gb/s port? Normally like me, I have three 3gb/s ports and three 6gb/s ports... With the 6gb/s ports, you can use all of your SSD's write/read speed (500-600mb/s). If connected to the 3gb/s port, only half of it... Maybe you have some extra controller installed? And by the way, when stated that an SSD has an write/read speed of 500mb/s, that doesnt really apply "read" an videofile in various formats encoded in what know... The SSD have various read/write speed dependig on what kind of data it reads/writes. sometime it read some data x10 times slower. But again, I dont believe the problems originate from "slow speed" from your SSD, but either, it doesnt hurt checking their health.. Because I dont know your Windows version, be sure to set windows auto defrag to OFF. Update me Jeff... /Kim Olsson |
March 3rd, 2014, 05:22 PM | #9 |
if you have ist - intel storage technology / fast transfer, or similar, try uninstalling it....
my ssd system used to take as long as the old hd it replaced to boot up and do other ops. removed intel software and bingo, boots in under 30sec and programs load / work at lightning speed.
www.lesliewand.com.au |
March 3rd, 2014, 05:30 PM | #10 |
Thanks Kim. My installation was by the book, done it hundreds of times. I did not clone drive. I am using 6gb ports. Your advice was excellent but think I installed it properly.
I forgot I had HDTach. I installed it and benchmarked my OS drive is over 500 mbps, the other two SSDs are around 350. I think it's a controller issue, will have to rearrange things. Leslie, good advice, I have Marvell Storage manager but my sytem boots up in like 10 seconds, but I'll unistall it. I am pretty sure I have it disabled anyway, but will double check. Will report back!
March 3rd, 2014, 05:32 PM | #11 | |
Disk Benchmark | ATTO Or use any number of benchmarking tools to get the same results. TRIM may also be something to look into, depending on your OS: http://lifehacker.com/5640971/check-...e-in-windows-7 |
March 3rd, 2014, 05:34 PM | #12 |
Jody, thanks for the link very nice!
March 3rd, 2014, 06:03 PM | #13 |
March 3rd, 2014, 06:52 PM | #14 |
Well, thanks everyone for your help.
Learned a couple of things. I have two sets of 6gb sata controllers, one set is clearly much faster than the other. The drives run at rated speed, about 500 on one controller and about 350 on the other. At any rate, the issue is definitely not SSD related. I'm looking at my overclock to see what's wrong there. I feel the issue is related to cpu usage and turbo boost. I thought had I have a constant overclock at 4.1, but I suspect now it's not so.
March 4th, 2014, 01:22 AM | #15 |
Jeff, you did not OC the fsb?
That will OC all aspect of your motherboard. You just raised the multipler? |
