mov problems
I am having a problem with a couple of mov-files I received from someone else. I see only a black screen, when I drag these files into the Timeline of Vegas (version 8). I can see and hear the audio, however.
Does anyone have a solution? |
Re: mov problems
I hate to be the bearer of bad news but odds are that the only solution is to upgrade to a newer version of Vegas. I have Pro 8 and it will not read mov files from, for example, an iPhone or an iPad while Pro 10 will do it.
Re: mov problems
Nevertheless, it is an answer that sounds reasonable.
Re: mov problems
You could also in the short term use a video converter to change the mov files to a format your Vegas can use, since you only have a few of them.
I would encourage getting an upgrade to the newest version of Vegas as the long term solution. |
Re: mov problems
Shortly after I purchsed a new Canon XA20, three months ago, I checked, whether my Vegas Pro 8 would accept the files of this cam. And it did. So my ancient version should not be the problem.
The first thing I tried was converting the files, but this failed. Several tries in several converters. Earlier today however a "version-12-user" converted them for me in Vegas and now I do see the moving pictures. Problem solved. |
Re: mov problems
You can find both of these at Download Old Versions of QuickTime for Windows - OldVersion.com |
