Excalibur 6 updated for Vegas Pro 13
I've been working on Excalibur in preparation for the anticipated move to Vegas Pro 14. With the new OFX Titles & Text media generator, it is now possible to write text via a script to the text box. While this has been available in a couple of previous versions, there was a new option added in 13 that really helped with the implementation of QuickLabels. So a new version of Excalibur 6 is available but it will only work in Vegas Pro 13 and now uses Titles & Text for QuickLabels. The updated version can be found here:
http://www.jetdv.com/scripts/Excalibur6-13-0.exe In addition, it will use smart alignments. If you place the text on the left side of the screen, each label will be aligned on the left. If you place it on the right side of the screen, each label will be aligned on the right. Similarly, if you place it toward the center of the screen, the labels will be centered. This is a free update for Excalibur 6 users. |
Re: Excalibur 6 updated for Vegas Pro 13
edward you are a gent!
i can't tell you how useful excal. has been over the years - it's my go to on nearly every project. i'm not using vegas so much now i'v moved to resolve, but will look at 14 IF you rework excal for it, even if i have to buy it anew thanks and good luck |
Leslie, I just uploaded a new build 6.13.0.38003 with a fix for a color issue on the revised Quick Labels.
Yes, I do certainly plan on updating Excalibur for Vegas Pro 14. It will be a free update for Excalibur 6 users. |
Hi Edward, I've found that only 8 out of all the 48 colour options are carried through to the final QL. What am I doing wrong?
Grazie, I'm simply taking the color chosen and passing the ARGB values to Vegas. So there should be no issues with any color being passed through unless it's an issue of me passing 0-255 and Vegas is expecting 0-1. I'll double check that.What's an example of a color that did not pass?
Ok, version 6.13.0.32480 is now available at the same link and same file name. It was an issue where Vegas is using values of 0-1 instead of 0-255 and I was passing the standard 0-255.
Ed, thanks so much, Excalibur rules.
If you have been following the threads on Magix Vegas Pro 14, if not, Magix is still offering Sony Vegas Pro 13 now for $200 USD with a free upgrade to Magix Vegas Pro 14 later in September. The offer now expires end of August and the purchase does not require proof of a previous version. |
hi george,
already have 13, but have more or less moved on to resolve. however if there's a decent offer for 14 to owners of 13 then i'll probably spring for it. i still love and use vegas for fast rough cutting and throwing together talking heads. |
