-   What Happens in Vegas... (https://www.dvinfo.net/forum/what-happens-vegas/)
-   -   NewBlue titlers on VP14 - Update (https://www.dvinfo.net/forum/what-happens-vegas/533312-newblue-titlers-vp14-update.html)
Edward Troxel December 24th, 2016 12:24 PM
We understand there have been many confusions since the release of Vegas Pro 14 concerning Titler Pro. Here I will explain how things work and how you can get various versions to work in Vegas Pro 14.
First, understand that all versions of Titler installed will replace whatever version was previously installed. This is done to make things easier on you. For example, if you have Titler Pro 3 and install Titler Pro 5, Titler Pro 5 will replace Titler Pro 3 and all Titler Pro 3 titles in your project will automatically become Titler Pro 5 titles.
One key for Vegas Pro 14 is to make sure you are on the newest version available. At this time, they are:
The bundles:
Vegas Pro Complete which has Titler Pro Express
http://www.newbluefx.com/downloads/M...ete-161118.exe
Vegas Pro Suite Complete which has Titler Pro 3
Titler Pro 2
http://www.newbluefx.com/downloads/W...ro2-161118.exe
Titler Pro 2 AE
http://www.newbluefx.com/downloads/W..._AE-161118.exe
Titler Pro 3 (all three versions)
http://www.newbluefx.com/downloads/W...ro3-161118.exe
http://www.newbluefx.com/downloads/W...ite-161118.exe
http://www.newbluefx.com/downloads/W...ate-161118.exe
Titler Pro 4 (all three versions)
http://www.newbluefx.com/downloads/W...161118-032.exe
Titler Pro 5 (all three versions)
http://www.newbluefx.com/downloads/W...161114-061.exe
When installing or uninstalling our products, it is always vital that you first reboot. If Vegas has been started and closed, it is quite possible for it to remain in memory and keep some of our files locked preventing a proper installation. I would also recommend uninstalling any previous version you have installed before installing the newest build. You can also do a clean install:
1. Reboot
2. Uninstall any versions installed
3. in C:\Program Files\NewBlueFX, delete the Titler folder
4. in C:\Program Files\NewBlue, delete the Titler Pro 2.0 for Windows folder
5. in C:\Program Files\Common Files\OFX\Plugins\NewBlue, delete TitlerPro.ofx.bundle
6. in C:\Program Files\Common Files\OFX\Plugins\NewBlueFX, delete TitlerPro2.ofx.bundle
7. Now reinstall the appropriate version listed above
If, after reinstalling, you get an error using Titler pro, try going to C:\Program Files\NewBlueFX\Common and remove the OFXBridgeB64.dll file.
If Vegas is not seeing the proper version of Titler Pro, start Vegas Pro 14 while holding down the CTRL-SHIFT keys, and check the “Clear cache” box in the window that opens.
If you have a full version of Titler installed but can only see the QuickEdit screen (i.e. it believes you are on Titler Express), open the NewBlue Application Manager, click on the gear icon and choose the option to log out, and then log back in. This will force the activation to be reset. Logging out of the Application Manager will deactivate all products on that machine. Logging back in will reactivate them.
To get your Vegas preview screen to update while Titler Pro is open, in Vegas go to Options - Preferences and uncheck the “Close media files when not the active application” option.
