Wierd Problem
When I render a cineform AVI to mpg2 and play the rendered file back, no audio comes through. What gives?
Also have a look (run 'search' if you have too) for a *.mpa which'll be the audio. If you have that, then you can load both the video and the audio into your DVD authoring app, and write your DVD. I am assuming (correct me if I'm wrong) that you want to write a DVD from the MPEG2... |
The Custom button doesn't work.
Couldn't find any .mpa's |
You have the project saved, and all the original files still available? If so... open the Vegas project. Go to "Render As", then select Mainconcept MPEG2 as the format type from the "Save as Type" drop-down list. Then select the template from the template drop-down list... you know, DVD Architect 24p NTSC WS, or PAL DVD video stream... etc, etc (I'm sure you know which template is the right one for you) Then click the "Custom" button. Things to look for in the Custom settings: a) Project tab - Video rendering quality > set to "BEST" b) Video tab - make sure the bit rate is not some stupidly low number, and that all settings look 'right'... change if required. c) Advanced Video tab - Play with at your own discretion, but "Allow field Based motion compensation" is worth checking. d) Audio tab - Tick the "Include Audo Stream" check box. Set the available options for whatever your sound will be... you know, stereo for stereo, dual channel for Dolby 5.1, bit rates etc. e) System tab - hopefully these options are self explanatory... Once it's all set, just click "OK"... then save the render. Hope that helps... other than that though - I'm not sure why the audio would be missing. If there's audio in the CFHD AVI, and you can hear it (which means your speakers are working), and there's a visible waveform showing on the Audio track in Vegas's timeline (just check that there's audio info on the Audio track... if necessary boost the master volume) you have a problem I've not encountered. |
The MPEG2 encoder is included in Vegas so the custom button should work even if DVDA has not been installed. It's just that if you don't have DVDA installed, the MPEG2 encoder must be registered separately.
The Custom button not working has been a fairly common issue, though. |
I got the button working. No luck yet.
AH! I found it.
After Custom, and under system, theres a box for saving the file as seperate audio and video files. This was checked. Seems pretty straight forward. Should work now. Thanks guys. -Kevin |
Just remember for the absolute best results, that 2 pass Variable Bit Rate is the go. The default max, min and av settings are all too low. DVD max bitrate is approx 9.3Mbit, so anything close to that is good. Bump the minimum bitrate up to something around the 5-6Mbit mark and set your average in between the new max and min. The idea is to get a balance of size to quality. Don't forget to check those settings every time you do a render (if you haven't saved the adjusted template as something appropriate that is!!), otherwise the problem will keep on happening... |
