resize multiple video events
I searched Vegas help, google and of course the board for this but maybe I don't know the correct terms to use.
My wife is budding Photoshop power user and we needed to do some rotoscoping. After we got what we wanted, 65 frames in all, I placed all the frames on the time line. Vegas puts static images on the time line at 5 seconds each. Vegas was good enough to put the images in the correct order I needed them but how do you resize them down to one frame? I did it manually with the mouse but is there a better way? Thanks for any help on this. |
Look around for a script, one might already exist... try VASST.com and other places... also on Edward's site http://www.jetdv.com/vegas/forum/index.php there is a forum for requesting scripts... it doesn't seem like a difficult one... you might ask and someone might could whip one up for you ... but other than that I looked around in vegas and nothing jumped up at me :(
The script is already in Vegas, Tools/Scripting/export image sequence.
Ultimate S also offers this with some additional perks. Anyway.... After editing the photos, go to File/open, and check the image sequence box. Then import the images. They'll be one frame each, and Vegas will treat the images as though they were a single file, making it easy to apply any filters to all images regardless of how many they are. |
Oh excellent, my work around was to line them all up, resize each by hand then render as QT lossless mov file, bring that back in the timeline and add the effects I needed. This is way better. Thanks again Douglas, really appreciate you being here.
@ Kevin; let no good deed go unrecognized, thanks for the tip. Scripting in Vegas is something I've avoided but during this down time I think I'll head over to Edward's site and lurk for a bit. |
Dennis, as Spot said - you do a file - import - Media and then pick the first image. If they're numbered correctly, you should then be able to click on the "Open still image sequence" checkbox and specify the starting and ending numbers. That will give each image 1 frame and will give you a SINGLE event on the timeline (instead of one event per image). Resizing each image down to a single frame would be very time consuming.
Preferences
jason |
Thanks Jason, I can see how that would be good for gradually adding certain FX. Thanks.
Photos
jason |
