Trouble with Large Wave Files
I recorded a concert using a Sound Devices 744T.
The files were recorded in polyphonic format, using four channels. Using the Explorer Window in Vegas 7.0b, I am able to drag the files to the timeline, and the files are properly placed on four tracks. I have been editing the files succesfully until I tried a very large file. However, I can not drag a 2.17 GB file to the timeline. I get a "circle with a slash" indicating that I can not place the file on the timeline. I have tried other large files with the same results. The largest file that I could place on the timeline successfully, was 478 MB. I split the 2.17 GB files into four monophonic (single track) files, each 542.57 MB long. These single track files can not be dragged to the timeline either. I have tried both settings of "Render Large Wave Files as Wave64" in Options|Preferences. I am able to successfully load these large files into Neundo 3 so I know the files are not corrupt. Also the Fostex BWF Manager was able to read and split the files successfully. I tried starting a new, empty Vegas project. This makes no difference. Each file was recorded as 24Bits, 96K samples per second. I assume that there is some problem with ".wav" files over 512MB. I welcome any suggestions. I will be downloading Vegas 7.0c tomorrow. |
I thought WAV files had a 2Gig limit which is why Vegas always rendered to W64 for the PTT option.
Yup, a 744t will allow you to make a wav file you can't open in most applications.
I've had good luck with cutting wavs from a 744 into smaller pieces with audacity, then bringing them into vegas. What's odd, of course, is you shouldn't see any problems of this sort with a 512MB file... Had good luck with a 744t, bwf splitter and vegas 6. I think Vegas 7 allows direct import of polyphonic waves, although you have to rename them .wav if they were imported as .bwf. Vegas will not allow anything over a 2GB wave, bwf or not. But audacity will... audacity.sourceforge.net |
Dear Edward and Seth,
Thanks for the information. I will split up the files. By the way, what is "PTT Option"? Dan |
I have upgraded to Vegas 7.0c.
The results are the same. Large ".wav" files can not be dragged onto the timeline. I have sent an email to Vegas Technical Support. I will report what they say. It is my intention to break up the files into smaller chunks. |
Dear Edward,
OK, I figured it out. PTT = Print to Tape |
Yes, Print To Tape = PTT
