Avid captured video in Vegas
Hey everyone,
Quick question; can video captured in Avid be brought into Vegas? Would I have to download a specific codec do to this? Long story short, I've got video on beta tape that I need to bring into Vegas, but right now am unable to capture to the laptop that has Vegas installed on it. My best option is to capture the video using another department's Avid, and then copy it to my laptop. Never having done it this way, however, I am unsure if Vegas will be able to use the Avid-captured video. Can anyone help? |
No. Avid uses a QT based file format with an OMFI wrapper. You cannot import these into Vegas and use them raw.
Is there any way around this?
You might check out Focus Enhancements File Converter Pro.
you can capture in Avid and export from there as an avi, and use the resulting file in Vegas. Use whatever codec you prefer and have available on that system. alternately, since one of my older systems is funky with exporting QT's (half the audio at half speed from Avid) I export as a QT reference file, open in After effects and export from there using a variety of codecs.
Thanks Bill,
that's kind of what I figured I was going to have to do. I was hoping I could get around the exporting step, but knew that might not happen. My first thought is to export the video as an uncompressed avi, as I'm more worried about quality than filesize. However, time could become an issue. Are there export settings that would be quicker, yet still give me a decent quality? |
depends on the how they export/capture the clips in of Avid ...
i use beta SP & digibeta captured clips from Avid in Vegas ... from Avid export using avids 8 bit meridian codec ( free download at avid) which is QT - just drop in Vegas TL ( after you install avids free codec's) ... the 10 bit avid codec ( mfx wrapper) does NOT work in Vegas |
3 computer license?
Doesn't vegas have a 3 computer license? Why not install your Vegas on that system (if possible ..... OS limitations might keep that from happening) capture and then transfer via network back to the master system.
jason |
Our licensing agreement permits you to install the software on as many machines as you own, as long as you are not running the programs at the same time. For instance, you can install the software on your home machine and on your laptop. You are not allowed to install the software on multiple machines if you are going to be using them simultaneously, such as in a home studio setting. If you are going to run the software concurrently on more than one machine, you would need to purchase a separate license for each computer. Note that when you install the software on a different computer you will need to complete the registration process again. Register the software as you did the first time to unlock the program on each machine. |
Correct
