Vegas 7.0e locking up computer- how to go back to 7.0d at DVinfo.net
Old May 10th, 2007, 01:37 PM   #1
I recently upgraded to the new version of Vegas, 7.0e, and can no longer build peaks. The computer locks up trying to render the audio. I contacted Sony, but have received no reply. I am in the middle of a project and can't do it with this bug. Does anyone know how to go back to version 7.0d? Thanks.
Ruth Happel is offline   Reply With Quote
Old May 10th, 2007, 02:33 PM   #2
Sponsor: JET DV
Uninstall "e" and then reinstall "d".
Old May 10th, 2007, 03:49 PM   #3
I don't see an easy way to uninstall e without removing the whole program, and d isn't available on the Sony site anymore. Can you tell me a way to do this? Thanks.
Old May 10th, 2007, 04:05 PM   #4
You can find "d" on the Sony FTP site at http://download.sonymediasoftware.com/current/
Old May 10th, 2007, 05:35 PM   #5
Are those from the Sony FTP site only trials?
Alex Thames is offline   Reply With Quote
Old May 10th, 2007, 05:49 PM   #6
If you don't already have it, then yes, it is only a trial.
In Ruth's case though, she was looking to roll back to Vegas 7.0d from 7.0e and this is a way for her to do it.
Old May 10th, 2007, 07:54 PM   #7
Thanks, I hadn't found that link on Sony's information. I just went back to version 7.0d and everything is back to working fine. I guess I'll wait a bit on this upgrade, since for some reason it doesn't work right on my system. I really appreciate you sending that, I'm back in business!
Old May 10th, 2007, 07:58 PM   #8
Glad to hear that it worked for you Ruth.
I stumbled across the FTP site link on the Sony Vegas forum one day and decided to bookmark it "just in case" :-)
Old May 10th, 2007, 10:42 PM   #9
Your saving the link just in case was great news for me. Thanks! I was totally blocked by the "upgrade" so being able to go back to 7.0d was really important. I appreciate you getting back to me so fast here on the forum, too. I'm back at work now, thanks to you!
Old May 11th, 2007, 03:29 PM   #10
Ruth, has anyone in support gotten back to you?
What was your source-media type?
Matthew Chaboud is offline   Reply With Quote
Old May 11th, 2007, 05:54 PM   #11
I finally got a reply from Sony today but their "workaround" was change the imported files from .m2t to .avi, but since I use elecard to view the files, I really don't want to start changing file extensions. I don't need AVCHD or the other upgrades with the 7.0e revision just now, so will stick to the older version until there is something in an upgrade I really need, and then hope it works by then.
Old May 12th, 2007, 02:28 PM   #12
I'm having this exact same problem, so if going back to 7.0d is the solution, then I'm game.
SB
Steven Bills is offline   Reply With Quote
Old May 14th, 2007, 06:12 PM   #13
I don't understand what the problem is. That native .m2t files can't be imported into Vegas 7.0e because peaks are unable to be built?
I was working with Vegas 7.0a for awhile, but because I have a slow computer, I rendered all the .m2t files to a Cineform intermediary (.avi), which I then used to edit everything. Then I moved to Vegas 7.0e, still using the .avi files and everything seems to work fine. Are you guys saying that if I switched them back to the original .m2t files, Vegas 7.0e wouldn't work right?
Old May 16th, 2007, 10:18 PM   #14
That's how it worked for me. I had e installed, had problems building audio peaks, and so I went back to d, and now I have no problems.
I love how Vegas makes things so easy.
SB
Old May 21st, 2007, 05:46 PM   #15
I dont understand how you un-install E. I tried to re-install D and it says to undo E but how without deleteing the whole program?
Thanks Joey
My videos
http://www.youtube.com/user/lucasberg
Joey Atilano is offline   Reply
