Corporate Spots with A1/Red Rock - Page 2 at DVinfo.net
Old March 31st, 2008, 12:32 PM   #16
Ok, so here's what I used:
FLAT CIN
GAM 2
KNE H
BLK S
PED 6
SET 9
SHP 0
HDF M
DHV 0
COR 0
NR1 0
NR2 L
CMX 2
Everything Else 0
This has Noise Reduction on to help with the noise in the gray areas, but it can be off as well- esp if you're shooting with lots of light.
Then you expose to retain the highlights that you care about, and crush the blacks to the desired level in post.
Hope it's of use- I'm developing a second one that I think I like better. I'll post it when I've shot some stuff and verified that I like it.
-M
M. Gene Hoffman is offline   Reply With Quote
Old March 31st, 2008, 12:49 PM   #17
FLAT CIN
GAM 2
KNE H
BLK S
PED 6
SET 9
SHP 0
HDF M
DHV 0
COR 0
NR1 0
NR2 L
CMX 2
Everything Else 0
-M
Thank you M. Gene Hoffman. I attached your preset below for those who want to start playing around with it. FLATCINE1 is with the noise reduction (exactly as you described above). FLATCINE2 is without it.
File Type: cpf FLATCIN1.CPF (40 Bytes, 565 views)
File Type: cpf FLATCIN2.CPF (40 Bytes, 552 views)
Taj Jackson is offline   Reply With Quote
Old September 9th, 2009, 05:03 PM   #18
Flat cine
Thanks for that info. Being flatter, this should work better than running the standard XH-A1 config in contrasty natural light situations?
Larry Vaughn is offline   Reply With Quote
Old September 14th, 2009, 09:50 AM   #19
Loved the Chroma!! Well Done!
Cheers!
"...The keenest eye is that which looks inward"
Jason Sharaba is offline   Reply With Quote
Old September 27th, 2009, 08:05 PM   #20
Great job,
What kind of lens adaptor you used for the lenses? I have a Canon EF XL lens adaptor but I do not even see any point of having and using it with my XL-H1, specially considering the X7.2 factor.
cheers
Mitchell
Mitchell Yazdani is offline   Reply
