Yesterday i tested with Toshiba NB100 8,9" netbook. Weight is only 1kg.
It worked perfectly with win7 32 bit. Stereo multiplexer and the player with the cheapest DC60 easycaps! Too bad the boy solded it today for about $250 :( Now i search another model. |
Yes, it is too bad. You'll find another similar one, I am sure. The system is really useful. I've placed several clips on Vimeo (
Nice.
The 8,9" netbook is comfortable for outdoor use? How can i setup it up? To the tripod? Or to the ground? Some real life experiences? :) Or a 7" is even better? But we need 2 usb2 of course. |
There are many ways it can be done. If you use a stationary setup such as tripod, there are commercial holders like those shown here: +notebook Holder . I am cheap, so I use a music stand:
. On my portable setup, I just carry it in the Kata bag:
Thank you, great video!
Can you also see anaglyph video in the glasses? For me, this netbook preview possibilities is not only for alignment correction, but also for set the correct stereo base distance between cameras. I like to record far objects, with 30cm base, etc. So with anaglyph mode i easily can see, if the horizontal parallax is too big or slight for a scene. Of course the side by side version is also good for preview (sure the best), no color distorsion, real 3d preview, but when i set the base too much, i can only see "hard to watch 3d video", and cannot see exactly the horizontal parallax. Hope, you understand my question :) regards, Marton |
With the glasses you can see either 2d, so that you can see side-by-side, or anaglyph overlays, just like on the screen. What they add to it, is they can convert either side-by-side OR anaglyph to true 3d (each side displays the proper lens). Another words, it can de-anaglyph and display left and right into the proper lcd (even though some colors are lost in the case of anaglyph 3D), so that if there is a discomfort due to various unpleasant disparities, you can see them before you get back and start post-processing. The main downside is the low resolution of the glasses. That gets even worse with 16:9 aspect. There are higher resolution glasses on the market, but those would be out of my budget. With the glasses you can switch between 2D and 3D with just the controller that comes with the glasses, without touching either the computer or the rig. Sometimes it is nice to align everything in anaglyph, and verify the setup by quickly switching to the 3D view. It is like putting on the anaglyph glasses, without actually doing it.
Ok, thanks.
Definetly i will buy glasses, but in higher resolution, and not now. Tomorrow i check an Aspire one (with intel processor), and if it works, i'll buy it and use as anaglyph preview monitor. Other great thing with this method: on the computer screen i can see the whole frame, not just the cropped, overscanned area like with camcorder's lcd screen. There was many situation, where a tree or something was on the picture, and i cannot saw it because overscan, but there was on the projected silverscreen!... |
Good news!
The Acer One also works great with Easycaps, so i buyed it! :-) I setup the multiplexer once, start the player with the command line parameters: use the multiplexer as input, start in full screen mode and don't show logo.. All of this run with a simple hotkey! No mouse is required, very nice. I can check the setup, the correct base distance, alignment errors, etc. With F4 i get side by side view, so i can check colors, exposure differences and with F5 i see anaglyph preview, so i can check the final depth and horizontal parallax.. After checking i simply set the netbook to sleep mode, go to another location, and check the again when opening the netbook, within 5 sec!! The battery capacity is about 2,5hour. So i think for 3D checking i can work with it in a whole day! Now i start searching a 90 degree usb connector for easy placement of the digitalizers. Thanks all of you! Marton |
Most of you are pro's who will probably laugh at my "rig", but some may wish to experiment with 3D without investing thousands of dollars or buying milling machines. Those maybe interested in the latest improvement of the camera support, which makes the cameras very stable. Something like that is needed to support a moving rig. The solution doesn't cost a lot, works really well, and is reversible. The clip is here:
1 Attachment(s)
This thread helped inspire me to build my own two camera 3D rig.
It consists of two Canon HF21s, a Lanc Shepherd Pro that I interfaced a Phidget relay module with, a motorized pan/tilt head that I interfaced with the same Phidget module, two video captures modules and a Samsung Laptop that controls everything. I also added a Phidget servo to toe in and out the right camera and it is also controlled via the laptop. I use the laptop as a remote server running Stereoscopic Multiplexer and Stereoscopic Player. I log into the laptop remotely and control everything over wifi and also over the internet. For the moment I am using the standard Phidget control software to operate the functions while I watch the video with anaglyph glasses on my Iphone 4 or Ipad. It's a lot of fun. |
That is very clever rig Frank. The Canon HF21S's are great choice I think.
For those of you not against the stereoscopic glasses, Zeiss is coming up early next year with what could be really cool 720P eyewear, that has cool interfacing and OLED display technologies for about $500. IFA 2010: Carl Zeiss Presents New 720p OLED 3D Glasses - DigitalVersus
Thanks Pavel.
I primarily use the rig to shoot 3D video of the local wildlife. The biggest problem is keeping the cameras in sync within about 4 or 5 ms. Unfortunately, the HF21s tend to start quite a bit out of sync when you power them off and then on and stay that way no matter how many power cycles you give them. I am working on a replacement for the Lanc Shepherd that gives me a lot more control including starting them at slightly different times to compensate for this. It will also have manual focus which the lanc shepherd doesn't support. |
BTW, you probably know this, if the power up is consistently off, the problem could be in the camcorders, their H/W or even F/W if it is different or batteries. If for some reason one has bigger filter caps or power-up reset sense threshold or is otherwise different, you could have consistent discrepancy. The Lanc Shepard and similar controllers depend on consistent components. I know that Werner Bloos was matching camcorders for the pairing purpose, and usually wanted to try at least six pairs. If you have a chance, you may want to see if you can try to power up with a different camcorder, store demo, or friend, etc. My camcorders definitely do not power up in sync every time, but most of the time I am within .5 ms, which is good enough for running water, flopping wings, etc. Of course if you design your own, you should be able to scatter the power-up commands. I believe that it is what the original LANC Shepard did as well. |
"Do you have to do a lot of zooming to capture wild life from a tripod?"
I wouldn't say a lot but some for sure. "Do you need to re-space the rig?" No, but I plan on building a new small beam slitter unit with a servo so I can change the interaxial distance remotely also. "Are you going to share the design or manufacture the controller?" Too early to say. At the moment, it's breadboarded with four processors with the main processor running an Apache server. I don't see it as a hand held unit for now. This is what it is going to do: 1. turn cameras on 2. turn cameras off 3. start recording 4. stop recording 5. set zoom speed 6. zoom in 7. zoom out 8. set auto focus 9. set manual focus 10. focus near 11. focus far 12. set max sync error in milliseconds 13. enable auto resync when max exceeded 14. disable auto resync I don't want the camcorders to start in sync, I want the slower camera to start first, in my case that would be around 2 milliseconds before the faster one. |
Pavel if you were starting from scratch with the intention of building this type of stereo rig what cameras would you use? I am thinking that block cameras might be the best way to go but I am not familiar with their video quality and capability, but their design looks right for this type of project. Also it would seem that progressive image capture would be of great benefit for stereo video along with the external sync of course. The Sony FCB-H11 would seem good but it is interlaced and no ext sync from what I can tell. Once you get a block camera with ext sync the price gets out of hand. |
"Pavel if you were starting from scratch with the intention of building this type of stereo rig what cameras would you use? I am thinking that block cameras might be the best way to go but I am not familiar with their video quality and capability, but their design looks right for this type of project. Also it would seem that progressive image capture would be of great benefit for stereo video along with the external sync of course. The Sony FCB-H11 would seem good but it is interlaced and no ext sync from what I can tell. Once you get a block camera with ext sync the price gets out of hand. "
The camera choice is highly dependent on your needs, e.g. size and weight, portability, targeted results (movie theaters vs TVs vs computer screens), close-ups, general videos, landscapes, etc. I like portability and fairly quick preparedness, so I would use the HDR-CX550s and Werner's latest controller ( digi-dat Dienstleistungen - Anlagen - Technik ). But I can see why others would use other brands. The choices of camcorders would be between the the Panny HDC-TM700 (sync?), Canon HF-S21 and Sony HDR-CX550. I would pick the Sony. With the right spacing (the Sony being fairly narrow) one should be able to look into both viewfinders at once and skip a lot of baggage. The Sony only has limited shutter control and only 60i at full HD, but has other advantages (you may wish to see this discussion: (Yahoo! Groups )) I am not familiar with the Sony FCB-H11, but it seems to have only analog outputs, that would be a big hassle. There are times I could use mirror rig, but fairly rarely. To me it takes too long to get ready, but I will probably do one sometimes in the future. It's got a lot of opportunities to do things wrong, specially if you have to shoot quickly, but the only way I know of to get really close and have flexibility. |
The pan/tilt is a standard inexpensive unit that I am controlling with a phidget 8 relay module. |
LVDS stands for Low-Voltage-Differential-Signaling. That is a serial digital stream. SDI and HDMI are also pixel serial digital uncompressed streams, so you might be o.k. with that output, depending of what you like to interface the camera with. No doubt they would have some sort of recording interface.
In general, interlacing doesn't do any harm to stereoscopic cues. That is what my cameras are. Unless you capture in progressive fashion, there is always de-interlacing taking place somewhere in the chain, because there are not many HD interlace display devices left, and none for 3D, as far as I know. Even TV's de-interlace the i-stream first, convert everything into the native progressive scan, before sending the display controlling stream to the panels. The only interlaced displays I can think of are deflection driven = CRTs - mostly gone. Interlacing was invented mainly to deal with decaying phosphors in CRT displays, to avoid flicker. Later on it was useful to give smoother motion with limited bandwidth. These days it is used to get full 1080 lines with less bandwidth requirement, specially for MPEG2 compression and VSB modulation, in case of ATSC broadcast in the US, but not directly used by the TV display(panel). For camcorders, specially those at consumer prices, storing the HD stream on Hard Drive is much easier to accomplish, as well as the compression ( and on playback to de-compression) at half the bandwidth provided by the i-stream. Of course computers and movie projectors also need progressive stream, so everything will be converted at some point. Depending to what you are doing, the interlace will actually give you the equivalent of 60p. For example if you are distributing above/below stream, you can just use the individual fields and end up with "de-interlaced" 60p a/b stereo stream. As far as quality goes, there are couple of adaptive de-interlacing technologies, that yield excellent results. @ 1080 lines, if you will be interfacing the playback computer player to a TV directly, (in the US) 60i/p capture would be just fine. HDMI 1.4 deals with the limits of 1920x1080p frame packed stream high bandwidth by limiting the scan rate( of the pair of frames) to 24p. Of course no TV works in 24/48p, so there is always scan rate conversion required. If that is not done correctly, the 3D cues are completely destroyed. That is one of the reasons why specific 3D TVs, dealing with these conversions properly, are required. If you will be targeting 3DBD or movie theater, you are best off with NATIVE 24p capture. |
My beam splitting mirror will be here tomorrow and I'm excited to start working on the new rig.
Should be interesting trying to design and build it in my garage with only hand tools. After running a large machine shop for over 30 years I enjoy the simplicity of trying to do it this way for some reason. |
| All times are GMT -6. The time now is 08:39 AM. |
