Stereo3D Toolbox 3840x1080 SbS at DVinfo.net
Go Back   DV Info Net > Special Interest Areas > 3D Stereoscopic Production & Delivery > Dashwood Cinema Solutions
Old September 22nd, 2010, 06:09 PM   #1
Tim, is there a way to get unsqueezed 3840x1080 or 2560x720 as a possible output from Stereo3D Toolbox? I would like to try the 4k resolution on YouTube.
Pavel Houda is offline   Reply With Quote
Old September 23rd, 2010, 06:56 AM   #2
There is a way by creating a sequence in that size and using a png or jpeg at that size as slug to hold the plugin. Then just uncheck the "2:1 Squeezed" option.
However, it is an impractical thing to ask FCP to render since it can only access 2GB of RAM and a single processor. Even though in the latest Pro Applications update "several memory fragmentation issues have been resolved" it would still take forever to render and probably give you an out of memory error after 10 minutes.
There is a much easier process. Instead render out separate left and right quicktimes. Then use Quicktime 7 (if not in your Applications folder it can be installed from optional installs on Snow Leopard DVD) and run the attached script to instantly create an unsqueezed 3840x1080 side by side.
Tim Dashwood
Old September 23rd, 2010, 08:29 AM   #3
That is perfect. Thank you very much Tim. - I need a better Mac. Right now each second of each side takes literarily one minute to render, so 2 minutes per second of rendering already edited sequence ....
Old September 24th, 2010, 02:52 AM   #4
Tim, anyone, I can combine the QT files. Can you suggest about how I can convert the resultant aic file into h.264, or other format that is acceptable by YouTube?
Old September 24th, 2010, 03:20 PM   #5
Just drop into Compressor and use one of the H264 encoder presets that maintains original size.
Tim Dashwood
Old September 24th, 2010, 10:12 PM   #6
Thank you Tim. Unfortunately, I only have the FCE, not FCS, so no Compressor. I just figured out that I might be able to do it with Streamclip and Toast though. Couple of the clips are on YouTube and I am pretty happy what the higher resolution brings. The clip at the URL: http://www.youtube.com/watch?v=5-FlZpJlasc can be interesting, because I can see as many as 5 properly 3d, squeezed frames. I placed the raw clip of the Okinawan dancer at URL: http://www.youtube.com/watch?v=3_HELnC_RNo . Finally I did a quick clip at the ends using YouTube "Editor". I was interested in what type of quality degradation it might cause. That clip is at: http://www.youtube.com/watch?v=IYExfUZfX8o . If you are interested, take a peak. The difference in quality due to the higher resolution is pretty big. Unfortunately, to view it you'll need at least i7 machine and a fast down spout. Best is to pause and let the machine buffer the clip first.
Old September 28th, 2010, 08:16 AM   #7
3840x 1080 and 3D stereo toolbox rendering
Hello tim
I made first a two layers 3840x 1080 50p sequence each layer using a 1920x 1080 50P clip, created a side by side using offset of -960 and 960 for each 1920x1080 left and right eyes respectively.
I nested this sequence in a new sequence then applied clip coupler filter with sxs input (in fact now I realised I could maybe avoid this step using directly geometry filter with an sxs input) then applied geometry filter, and get the error message "3D stereotoolbox filter rendering felt.Your computer hardware is not able to render such a large and deep video"
I read the thread but I don't realy understand the way you describe to render such a 3840x 1080 sbs tuned with 3D stereo toolbox in fcp.
thanks
Alain Youcef-Khoudja is offline   Reply With Quote
Old September 28th, 2010, 12:18 PM   #8
Hi Alain,
Your system is giving you the error message because it can't handle rendering a frame size that big.
As I mentioned above it is impractical to ask FCP to access that much RAM for more than a few frames at a time.
Instead render as separate left and right quicktimes and use the utility I attached above to instantly create a 3840x1080 quicktime.
Tim Dashwood
Tim Dashwood is offline   Reply
  You are here: DV Info Net > Special Interest Areas > 3D Stereoscopic Production & Delivery > Dashwood Cinema Solutions
