Re: Sony TD10 3D camera editing suggestions
Going to 720 60P, which is another mandatory HDMI 1.4a 3DTV standard, works pretty well. You can use AVISynth to de-interlace to 1080 60P, then scale to 720. Results are fairly good. For fast action 720 60P IS the way to go in 3D. You need as much temporal resolution as possible to capture action, especially when the motion is parallel to the sensor plane. In 3D, blur = BAD. It is a real bummer that Sony didn't implement 1080 24P in this camera. Also a bummer than GoPro's are 1080 30P (but, will do 25P in PAL mode at least). |
Anyone find a all mac solution for this yet?
Been looking everywhere... Thanks |
Taj, I don't think Sony has made Mac processing of these files a priority - yet. You need to use the Sony Content Management Utility (Win only) to process the M2TS files into discreet L / R files and then you can edit/process them on a Mac in FCP, Avid, AE, etc. I know that the next update of Neo 3D from Cineform will process and mux them directly, but that's an expensive software package at $1K USD. Right now only CMU and Sony Vegas 10D,E or 11 will edit them natively - Windows only.
The main problem with the CMU from Sony is that you need to plug in the camera while you install it, then it runs ok without the camera plugged in after that. Don't know why they did this. So the best answer for exclusive Mac users is probably to use Boot Camp, install any version of Windows from XP to Win 7 (I would skip Vista unless it's free), then install CMU with a camera (owned or borrowed), then make the files accessible from the Mac boot side to edit them. |
Hi! I'm new to 3D, the TD10, and this forum.
I cut on FCP, so I started looking for a solution that could allow me to edit there. I tried Wimmer's MVC to AVI Converter, but there was a big problem! The (beautifully compressed) .m2ts codec used in the TD10 mushroomed in data size, when converted to AVI. It was literally 100X more data; one 100MB file expanding into 2X5GB AVIs. So 10GB of footage would expand to 1TB! And that's all before transcoding the second time, from AVI to MOV. That's a huge workflow bottleneck, in transcoding time, sheer data space, and edit throughput. How much easier it would be, just to cut natively in the .m2ts codec! My first work-around was to pull selects from the footage, with a combination of Wimmer's Stereoscopic Viewer, and Sony's PMB (file management software that comes with the camera), which can trim the .m2ts files without changing their format. In theory, then, the selects would expand to smaller AVIs, although it would still take up a lot of space. Also, archiving footage gets a lot easier. But once I started working in Vegas 11, which can edit the .m2ts files directly, I decided that was the only way to go. As an FCP user, it's a bit frustrating to learn Vegas' very different logic, but ultimately it's worth it, to be able to keep my file sizes small, and my workflow lean. I have just shot an interview on the TD10, with the GoPro 3D rig as my b-camera. Since Vegas can cut the Cineform codec, I'm hoping I can sync up the two cameras there, without having to transcode anything. I'm not yet sure how best to finish the project (it will include some stereoscopic CGI), but I am definitely sold on Vegas (and hence, PC) as my near-term cutting solution. A learning curve in the short term seems like it will pay off well, over time, at least until FCP or Avid starts cutting .m2ts natively. |
Matt, my experience with TD10/NX3D1 files mirrors yours, however, I found Sony Vegas to be a pale comparison to FCP / Cineform Neo3D workflow so I have only been using it to separate the L/R images and converting/muxing them with Cineform MOV to use in FCP. I can see why some would opt to stay in Vegas and edit 3D natively, however I had serious playback issues with M2TS files in Vegas and not in FCP, so I didn't bother learning a new timeline routine. Also the 3D adjustments palate was rudimentary at best with very few options for fine tuning or ghost busting etc.
Vegas does a great job of creating full resolution L/R images from the MVC files and that is good enough for me. Another note, I stated in an earlier post on this thread that the Sony CMU & PMB programs would work without the camera being directly hooked up to the computer, but this appears to not be the case. I have found though, that if your MVC files are still on an SD card in the camera that it is a much easier process to render full L/R frames out from those programs directly from the camera as they can be queued in a batch for processing saving mucho time. Unfortunately this isn't always the case as data gets transferred and then SD cards get re-used, so I'm working out the possibility of re-recording the MVC / M2TS files back to SD cards to insert in the camera for processing. This is ass-backwards of course but for some reason Sony has not made it possible to utilize the separation of clips from existing files on a hard drive - go figure. The fact that the Sony MVC files Right image is not a full resolution but rather a Delta file embodying only the differences between it and the full resolution Left image makes using the Sony software all the more important for image fidelity. Cineform tech support tells me that the next update of Neo 3D will include native MVC processing for files from JVC, Panasonic and Sony. |
The usual: ADN
(any day now) |
As for Vegas' convergence controls, I'm still pretty unsure about them. I first tried to clean up the ghosting using the "horizontal offset" slider, and then whoops, realized I was killing my depth. So far, I've had the best success using the "Auto Correct" function in the "Stereoscopic 3D Adjust" filter (although that also crashes Vegas, a lot). I've seen the Cineform Neo tutorial, and it sure seems more powerful. Good to know that it is. Regarding copying .m2ts files onto an SD card, and re-inserting that in the TD10, I'd like to know if you have any success with that. The instruction manual with the TD10 suggests that it should be possible, but does not say how. I tried that procedure, in order to be able to show selects to others (and set the camera to view the SD card as its medium), but the camera did not see any of the files. If indeed Cineform's Neo will (any day now) natively handle MVC, then I'd much prefer that, to stick with FCP. Either way, I'll need to buy a new computer to handle all the throughput, so the main question is to stick with Mac, or move to PC... |
All good points Matt.
"I wonder how FCP X fares with .m2ts files?" It seems to handle them very well, however, sticking an MVC / M2TS file into it will only give you 2D. I am impressed with only one thing about FCP X which is it's very robust playback engine. It's really something, but I'm afraid it's the only thing I can recommend it for as it's other lack of funtions cancel everything out for me. I'm waiting to see if Apple makes this once again a professional program like FCP 7. They are losing huge market share every day they delay for sure. "I have been hoping that this was mostly a matter of a slow PC, and that adequate CPU/GPU/RAM would bring Vegas up to snuff, but that' s just theory, so far" Not so much theory really. I rebuilt my computer to an 8-core i7 with 16GB RAM and still couldn't playback some files without stutter in Vegas. Same files play fine in PPro CS5 on Windows and PPro CS5 & FCP7 on Mac. On controls like ghost busting and features like 3D text, Tim Dashwood's Stereo Toolbox 3D can't be beat. He has a much more robust toolset than either Neo3D or any NLE standard tools like Vegas or Avid MC 5. Avid MC6 looks pretty promising for 3D though, but expensive. I'm still experimenting with repositioning the downloaded camera files back onto the SD card and using the camera with CMU or PMB software. I'll post an update when I get more info. |
With my i7 2600K overclocked to 4.3 Ghz, the playback of Sony TD10 mvc files is fine. It has been fine for Vegas Pro 10e, it is fine for Vegas Pro 11 too. There is not a lot of playback reserves, but it works.
The Vegas convergene tool work fine - the adjustment of the horizontal difference between the two videoparts adjust in the end of the day the position where the convergence is zero, so what comes out or what stays behind the monitor. It is especially great if you use in the internal preview window a difference picture, where you see in a very quick way where the convergence is zero - and use a nvidia 3D vision with a 120 Hz monitor for the preview of the video (even that still works with a Quadro only). The only range for improvement would be to see how many pixel you shift the video parts (so to show the parallax in a direct way). I never ever would like to edit MVC file directly in the camcorder or with an sdhc chip.Why not move that to the harddisc? Vegas generates the audio waveform files, and that is not fine in the camcorder. |
Wolfgang, perhaps you could share any computer fine tuning tips and tricks you've used to help those of us who are having Vegas playback issues resolve them. I have a system close to yours (i7 @ only 3.33 though) and can't get native m2ts files to playback at all on a Vegas timeline or in the Viewer. The same files playout fine in PPro CS5 in Windows so I'm pretty sure it's a Vegas setup issue and not hardware. Any tips would be appreciated as this playback issue is what prevents me from using Vegas more often.
And I'd also love to hear what GPU has worked for others. I've done a lot of homework on this, online, but most of the reviews are about 3D gaming, rather than production.
The following page from Sony's site has information on which GPUs function with their graphics acceleration. Vegas Pro 11 GPU acceleration |
I have a current project, a small youtube consciousness documentary interview with my dad, who is a psychology professor. I shot it with the TD10 and GoPro rig as b-camera. I am posting it (so far) on Vegas. Once I have a rough cut, I think I'll try to bring the footage into FCP, and invest in the Stereo Toolbox to finish the project. And then I'm going to try to integrate stereo CGI (purchased brain models, animated in 3D Studio Max) in the Z-space (and nose room) in front of my dad. That'll be a whole new learning curve... |
The hardware I use to preview those files is a Quadro 2000D, together with a nvidia 3D vision and a 120 Hz 3D ASUS monitor - what is a nice combination. The reason why I use the Quadro is that only with a Quadro you have a secondary preview with Vegas (even if I know that one of the new features of Vegas Pro 11 is that it should allow the 3D preview on a single-monitor setting too, but a lot of people have issues with that). I do not use the GPU acceleration really, since I have seen that the Quadro 2000D is so weak in terms of CUDA cores, that it slows down the system in both preview capabilities but also render time. I have in addition a GTX 570 in my system, what is a little bit tricky to install beside the Quadro - but you can do that in a way where the GTX acts als CUDA slave only. But even here I see a speed improvement in render time, but not really in the preview of MVC files. So for preview I stick still to CPU only (what you adjust in Options/Preferences/Video). For sure, the project properties have to be adjusted to the footage we use - but that is standard I think. So I was talking about MVC m2ts files only. If you have 2D m2ts files that does not play back really, then there must be another issue. 3D MVC 1080 50i/60i is more demanding then 2D AVCHD 1080 50p/60p, and that is more demanding then 2D AVCHD 1080 50i/60i. |
Wolfgang, yes I was referring to stuttering playback on MVC 3D files. I use a NVidia GTX 285 CUDA graphics card but it doesn't seem to help much in Vegas 11 nor did it in 10E.
Vegas seems to have no trouble with standardized codecs like XDCAM or AVI but the highly compressed AVCHD type files seem to choke it on playback. |
I think maybe the GTX 285 is not strong enough, in relation to your CPU. So I would try the preview with disabled cuda in options/preferences/video, where you set cuda to none.
What kind of hardware do you use - beside the i7? What is the 3D preview hardware? I assume that you use an NTSC model, so are the project properties set to 1920x1080, upper field first, 30 fps? How many frames/second do you see in your internal preview, what preview settings do you use, for a pure Sony TD10 file, without any filters? |
Wolfgang, I'm anxious to try out those settings, but I have to go out and shoot a quick shout-out with Mrs. Pitt today. I'll get back to you tomorrow on this.
I installed some recommended player and AVI converter files and wound up with a Trojan virus - Bunat@rts which appears as Smart HDD. Not sure which file had the nasty in it -- the AVI converter or the player or the fffd driver file. Beware.
| All times are GMT -6. The time now is 05:11 PM. |
