Stereo3D Toolbox v4 released with new-onscreen controls and FCP X compatibility. at DVinfo.net
Old June 11th, 2012, 06:22 PM   #1
Stereo3D Toolbox Product Page
Works in FCP6,7,X, AE CS3,4,5,5.5,6 and Motion 4 or 5. See the website for the specs.
Noise Industries has dropped the price to $999 for the month of June.
Tim Dashwood
Old June 11th, 2012, 07:38 PM   #2
Re: Stereo3D Toolbox v4 released with new-onscreen controls and FCP X compatibility.
Great improvements. Obviously designed by actual user. Thank you!
Pavel Houda is offline   Reply With Quote
Old June 12th, 2012, 12:08 PM   #3
Tim, what's the upgrade price from the full Version 3 ?
Old June 12th, 2012, 12:15 PM   #4
$0.00 (we never charge for updates)
Tim Dashwood
Old June 13th, 2012, 07:53 PM   #5
Very cool! Thank you, I'll download it very soon then.
Old June 20th, 2012, 05:20 PM   #6
Is there a download trial- test run-period possible before purchasing?
Carlton Bright is offline   Reply With Quote
Old June 25th, 2012, 12:41 PM   #7
Hello Carlton,
Yes. You can download FxFactory from this link: FxFactory - Download - Visual effects for FCP, Motion and AE
Once you've installed FxFactory launch the host application (FCP, Motion or AE). You can find Stereo3D Toolbox in the Dashwood3D effects menu.
Both versions of Toolbox are available as a fully-functioning demo for an unlimited amount of time. There's just a watermark on the image. The watermark is removed if the product is registered.
Ryan Alexander
Stereoscopic Specialist & Technical Support
Dashwood Cinema Solutions
Cinematographer, Editor, Colour, etc...
Ryan Alexander is offline   Reply With Quote
Old June 26th, 2012, 06:49 AM   #8
Thank you Ryan,
Question:
I may be misunderstanding something here, but in the registering video, it states you must register first, then "buy now". Then "after purchase" you can use the trial with the watermark...
Does that mean you need to actually purchase, (i.e. pay for it) , and then get reimbursed if you decide not to keep it?
Thanks.
Dcb
Old June 26th, 2012, 10:27 AM   #9
Can you please link to the video you're referring to?
No, you do not need to purchase a license to use the trial version. Anyone can download FxFactory for free and have access to all of the plug-ins, filters and transitions included. Stereo3D Toolbox and Stereo3D Toolbox LE are two of them and we've made our trial fully functional with no time limit, but there is a watermark. This allows the user to evaluate the software for any amount of time - days, weeks, months or even years. If the user is satisfied they can purchase a license to remove the watermark. The plug-in will function exactly the same as before and they can continue working.
Old June 26th, 2012, 12:28 PM   #10
I downloaded and installed FX Factory as described, and 41 seconds into the video you posted above, it says you click and download from the selection of programs to try out, but after clicking on "toobox" download , it just sends me back to the original FxFactory page again... any suggestions?
Dcb
Old June 27th, 2012, 04:09 PM   #11
Stereo3D Toolbox and Stereo3D Toolbox LE are a part of the primary FxFactory download. You do not need to download or install Stereo3D Toolbox or Stereo3D Toolbox LE separately. Simply download FxFactory, install it, then launch one of the supported host applications (FCP 6-7 & X, Motion or After Effects). To access Stereo3D Toolbox or Stereo3D Toolbox LE go to the Video Filters or Effects tab in the host, locate the Dashwood3D submenu then select the desired plug-in.
The process being described at :41 in the Installation tutorial is for the download of additional plug-ins that are not included in the initial FxFactory download. Stereo3D Toolbox and Stereo3D Toolbox LE are already included.
If you're accessing Stereo3D Toolbox or Stereo3D Toolbox LE from the "Products" --> "Online Store" section of the Noise Industries website it will prompt you to simply download FxFactory.
If you have already downloaded and installed FxFactory, Stereo3D Toolbox and Stereo3D Toolbox LE are ready to be used.
In regards to the installation of FxFactory and Toolbox ignore :41 - :50 of the "Installing FxFactory for Final Cut Pro, Motion and After Effects" tutorial video as it does not apply to Toolbox.
Here's the video tutorial for Stereo3D Toolbox v4.0: Dashwood Stereo3D Toolbox v4.0 Walkthrough - YouTube
Old June 27th, 2012, 05:59 PM   #12
Hi Ryan,
Thanks, and you wrote:
"Launch one of the supported host applications FCP 6-7 & X, Motion or After Effects). To access Stereo3D Toolbox or Stereo3D Toolbox LE go to the Video Filters or Effects tab in the host, locate the Dashwood3D submenu then select the desired plug-in."
Unfortunately, The Dashwood plug-in (in fact all the FX Factory plug-ins) are grayed out.
I apologize, and its a bit embarrassing to have so much trouble installing this a single program, but perhaps this process is helping others out there.
Carlton
Old June 27th, 2012, 08:19 PM   #13
Carlton, did you try to click them anyway? Some of mine are grayed out but they come up.
Old June 27th, 2012, 11:58 PM   #14
All filter plugins will be greyed out in Final Cut Pro 7 unless you have already selected a clip to apply them to.
See the video at 5:30
Tim Dashwood
Old June 28th, 2012, 08:51 AM   #15
.... I believe I had the clips in the timeline and a color filter or two applied already, so they in effect, were already selected...
In any event, apon restarting the computer this morning, and starting a completely new test, The plug ins are no longer greyed out.
All began fine this morning however, when appling the "identity LEFT or RIGHT DASHWOOD filters, the clips, "squeezed" into the Sequence, and were not the normal aspect ratio, yet the demo clips do not seem to do this in the demo tape (at 5:47)... What am I doing wrong ?
C-
Again , I apologize for the apparent inept capabilities as an end-user, and seemingly endless string of questions, but again, perhaps others have been running into the same problems.
