-   Adobe Creative Suite (https://www.dvinfo.net/forum/adobe-creative-suite/)
-   -   Goodbye Premiere (https://www.dvinfo.net/forum/adobe-creative-suite/104580-goodbye-premiere.html)
Paolo Ciccone March 13th, 2008 08:54 AM
Originally Posted by Bart Walczak (Post 841731)
And once you've worked in Color, you will absolutely abhor the way that color correction is done in Premiere. Or FCP, for that matter
After having spent much time with the Color Corrector 3 way in FCP I would suggest to anyone interested in color correction to stay away from that. As a matter of fact stay away from CC in the NLE and do it in After Effects. Magic Bullet Colorista on the other hand has given me excellent results and is so easy to use that I was doing secondary and tertiary CC minutes after installing it and, unlike Color, I can do that directly inside the host application.
You start by applying Colorista in Premiere for a quick "eyeballing" of the scene, move to After Effects and your Colorista settings are carried over. At that point you can use all the masking tools of AE to go selective. BTW, AE's Levels and Curves CC tools are fully 32-bit enabled so you can do a lot there without going out, render, re-import etc. In fact this workflow is what motivated my move from FCP to Premiere.
Mark Yang March 13th, 2008 09:57 AM
Originally Posted by Paolo Ciccone (Post 841181)
Let's try to stay away from the PC vs Mac argument. The idea that PCs are cheaper than macs has been debunked many times as being bogus.
I have nothing against macs. Both pcs and macs have their advantages and disadvantages. It depends on what you want - and everyone knows pcs are cheaper, if that is important to you.
If it wasn't for the more expensive hardware, and the fact that you can't build your own, I would have gone for Final Cut Pro. I've tried premiere pro - since there are many people here not happy with PP, I was wondering if Vegas might be better (although I doubt it).
Swen Goebbels July 14th, 2008 12:23 AM
Normaly I never complained about software (also not about Microsoft), but CS3 is the most unstable what I ever have seen.
Especially that "low memory" problem kills me, because I can render only a 10 minute HD project. Then Premiere tells me that my Watercooled Octocore machine has not enough resources to render it! :-( In there specs is not writen that you need a NASA computer for this. So why doesn't it work? I sitched the settings allready to "memory" and not "performance". Also I removed one CPU in the hope that with a Quadcore it'll maybe work better. Nothing!
Furthermore pictures cause trouble, Titel Designer doesn't work well ect .... When I bought CS3 I thought "Ok, every software can have bugs when it's new", but after all these month Adobe isn't able to fix the problems. This really makes me angry. Why is such a big company not able to fix the problems now? There are not only a few people complaining in the www about this.
When the problems will not be fixed for IBC in Septermber you can film "Rambo 5" when I'll visit the Adobe stand!
Maybe I should try Edius or Vegas, but I worked for years with Premiere and my main problem is that I started editing some very big project in CS3 allready. I don't like the idea that this work was nearly useless now.
Mitchell Skurnik July 14th, 2008 02:05 AM
It sounds like you have overclocked your PC. Turn off any enhancements that you have done. It is probably creating some unstability. I recently editing down 8 hours of XDCam footage on my 3 year old HP Workstation. It runs just fine.
Jiri Fiala July 14th, 2008 02:15 AM
Yes, this should become a Sticky on this forum:
DON`T overclock a Premiere workstation. DON`T tweak your system. Premiere runs fine on stable system. I have been on both sides.
Swen Goebbels July 14th, 2008 03:02 PM
I have not overclocked the PC! The reason for that water cooling, was just because that machine was as loud as a car. Now it's quiet.
Is it possible that maybe too much cores can cause a problem? I just tried CS3 on my Dual Core notebook and there it runs without the crashs. Windows accept only 3GB Ram, and when you have 8 Cores every core has only a small memory size to do the job. So maybe therefore my notebook (2GB Ram) works better.
Eric Addison July 14th, 2008 03:31 PM
I'm running PPro CS3 on a dual quad core and it runs great. I think something else must be going on.
Simon Denny July 14th, 2008 03:45 PM
Hey Peter,
If you need a rock solid NLE go with Vegas and Sound forge 9.
It's so easy and quick to edit, can handel SD,HD AND OTHERS allthough with color correction the preview slows down (this will be fixed soon ) It has the pro Tiler which i like and a host of other FX. Rendering in easy and clean, key frames stay in place and the app can be used on most PC machines. Sony sound forge is great for all your audio needs and works well within Vegas.
Simon
Bill Koehler July 14th, 2008 11:24 PM
When having persistent problems of this sort, I tend to suspect memory problems.
I obviously don't know what testing you may have already done, Swen.
I would suggest downloading a memory test utility such as memtest86, found here:
http://www.memtest.org/#downiso
It doesn't cost anything. And you don't install anything. You download a CD ISO file, burn a CD, and reboot using that now bootable CD.
It comes up running automatically. Let it run...after I've built a new machine, I typically let it run overnight.
If you have memory failures, the problem is most likely memory.
If it was a motherboard problem, everything would be behaving erratically.
You are probably finding the memory problem with Premier Pro simply because it makes your system work like *nothing* else. Both in speed and quantity. And another video editor is likely to do the same.
Give it a try. You have nothing to lose, except some time.
Swen Goebbels July 16th, 2008 12:34 AM
Bill,
thank you for your idea. Yes, I'll try the memory test form the boot CD. But I don't think that there is a memory damaged, because when I just Run for example the ProCoder3 (not form CS3 timeline) to make a wmv or mpeg video it works without any crash! CS3 crashes allways after a few minutes....
Swen
