-   Adobe Creative Suite (https://www.dvinfo.net/forum/adobe-creative-suite/)
-   -   Capture Problem (https://www.dvinfo.net/forum/adobe-creative-suite/50026-capture-problem.html)
Eric Elliott August 26th, 2005 01:19 AM
Capture Problem
The Problem:
Video image doesn't show up in capture window as the capture is in progress.
Premiere captures the video clip just fine: It shows up in the preview window when added to the project but the capture window is black during capture (or playback). I CAN hear the audio track during capture. (The window does switch to the correct aspect ratio when capturing, though... but it remains black.)
The Details:
Canon XL2, 16:9 / 24P / 2:3- All settings in Premiere match the footage.
Critical Info:
This is on a brand new machine. I had no problems on my old machine with the same settings. The new machine has better... everything. Storage space, video card, memory... you name it.
Something Odd:
A button shows up on the new machine that doesn't appear on the old one. (Which is odd... it's exactly the same software... same disc!)
Under Project >> Project Settings >> Capture... There is a button under the line that says "Capture module installed" that is labeled: DV Settings. The options are previewing audio / video on desktop during capturing / previewing. Trouble is, changing the settings doesn't make a bit of difference.
Adobe online help has been as useful as a cement life-preserver.
Thanks in advance for any suggestions!
Sheila Ward August 26th, 2005 06:55 PM
Try this, when the capture starts and you hear the audio, select the capture window and move it on the screen just a bit. Sounds crazy, but the same thing happens to me sometimes. All I do is move the window and the video shows up.
Eric Elliott August 29th, 2005 11:56 AM
Thanks! I'll give it a try. After years of experience with inexplicable computer problems, your solution doesn't sound crazy at all!
Sergey Bosh September 12th, 2005 01:16 AM
Hi there!! i've recently found screen capture tool that is an easy and fastest way to take video screen captures from Windows screen.Its quite nice tool, i have checked!!! http://www.geovid.com/Screen_VidShot/
Christopher Lefchik September 12th, 2005 08:50 AM
http://www.downloadfast.com/details.php?did=10821
Rather convenient that you happen to be the author of the program you "found", isn't it?
Eric Elliott September 14th, 2005 10:11 PM
"Screen capture"? That's not even close to what I was talking about, anyway.
Moving the capture window didn't work but the solution that worked for me was to minimize the Premiere main window and then maximize it again: problem solved.
Frikkin' computers... *sheesh*
Joe Bulleit February 21st, 2006 11:30 PM
Same problem here...
I just started having this problem tonight for the first time. I have been using PPro 1.5 since it first came out, and have never had a problem with the monitor window during capture.
But... for some reason (or maybe none at all) the window in the capture module will NOT display the video being captured. I have an external monitor plugged in and am using it to mark my in/out points, so I guess I can live with it, but stuff like this just drives me NUTS!
As I said, I have captured hundreds of hours of video with no problem until tonight. I have checked all my settings, and have made no software or hardware changes since my last capture (2 days ago).
I have tried the solutions on this thread to no avail. Has anyone got any other suggestions?
Thanks...jb
Wes Coughlin February 22nd, 2006 07:37 PM
If you have downloaded the HDV plugin thingy, your capture might be set to a HD camera source.
