-   Adobe Creative Suite (https://www.dvinfo.net/forum/adobe-creative-suite/)
-   -   Severe problem Premier Pro CS6 Mac (https://www.dvinfo.net/forum/adobe-creative-suite/524900-severe-problem-premier-pro-cs6-mac.html)
Chris Korrow September 11th, 2014 05:13 PM
Severe problem Premier Pro will attempt to save your project. I keep getting this message every week or so. The project reopens just fine, but it make me save it as another copy.
I've tried deleting the pek & cfa files, along with deleting the media cache & render files, but the problem still persists.
Can I delete the .ims & pgindex files also? should I delete all the older copies?
Just reinstalled the program & it's still acting up.
Thanks, C
Battle Vaughan September 11th, 2014 09:23 PM
Re: Severe problem Premier Pro CS6 Mac
It sounds like you are talking about the auto-save function? This is a good thing, not a bug, it can save your *** if something corrupts a later version, it gives you something to work from so you don't lose everything. If you really don't want automatic backups, preferences>auto backup and uncheck the autobackup box will turn it off. (I am on PC, assuming the Mac is similar). But have a thought before you do this....or am I missing something else altogether?
Chris Korrow September 11th, 2014 11:14 PM
No. This is not auto save, it is a "severe problem" when closing a project.
John Wiley September 12th, 2014 09:29 AM
I've had a similar message and it usually turns out to be a problem hard drive which goes into write-protection mode after Windows detects an error - not sure if Mac OS has a similar function?
Next time you get the message, try to copy any other file or folder to the project destination drive and see if it is actually a recurring disk error as opposed to a Premiere error.
Chris Korrow September 12th, 2014 09:49 AM
Thanks, I can try putting the back-up drive in.
