Luts - do they sharpen footage or just change colors?
Hi All,
Question is simple enough. If I shoot C-Log and than just drop in a Lut to get a close first look on how the footage will look after grading does the Lut just change the colors to get closer to graded look or it also adds sharpening? Should I still sharpen the video even after dropping a Lut. Just FYI I am talking about regular Lut, not the ones that apply special style or film look. Thanks for any help! |
Re: Luts - do they sharpen footage or just change colors?
As far as I know a lut doesn't add sharpness.
Unless you process RAW or have to downscale a video (and even then use only a little bit) I think sharpening does not make any sense as it harms your image. Sharpening was mostly a thing of SD video. |
It think it depends on how the camera processes it's log footage, my jvc ls300 takes all incamera sharpening out when you shoot in log so it does look softer, adding a bit of sharpening back in post again can in such a case make a difference but at least you have a choice so as it is not always required.
H@@@m, I shoot C100 mkii and the video looks fine even without sharpening but I guess I could make it a bit sharper in post...
Why this question came in in the 1st place was because when I used a Log imitating pre-set for Canon DSLR 70D it lloked extremely soft compared to Canon log. |
If the lut was created by yourself which i do and not use other peoples luts then yes you can add sharpness then save it to my presets with your other settings you created.
A LUT works like a look up table, it transforms a given RGB value to another value without any regard for position. A Premiere Pro preset is not the same as a LUT. |
You saved a preset for the Lumetri effect
Did you save it as a cube? |
No i created one in prem pro cs6 not cc, maybe i have just saved a preset i made not a lut will check it now, thought thats what i did.
Premiere Pro CS6 cannot create LUTs. Perhaps if you have such a misunderstanding of what a LUT is, it's best to refrain?
ye your right Gary,thought it was a lut i created but it was just a preset i created in cs6,
