Export to tape?? (XH A1)
Hi all,
I've been trying (for the first time) to export my finished product to tape (Canon XH A1) and am having no success whatsoever! (I'm using PP2.0) Both are successfully connected to each other. I go to export (I don't have much knowledge yet of what settings to use, but I've tried many many combinations!) , it says camera ready etc... I click record... the camera makes some sounds like its about to do it (the play image comes on with a pause sign) then, PP2.0 says record complete.... The tape has nothing to show for it, and it said record complete within about two seconds of starting, & my vid is about 1 minute long. I have no idea what the problem is... Though one thing I've always found odd is that my A1 is PAL yet, PP2.0 only lets me capture in 24p and not 25... Whats going on there? Any advice would be much appreciated.... Best, Giles B |
Not sure what good it will do you but I can export to my A1 (NTSC) from PP2.0. I set the A1 to VCR and connect it via 1394 to my machine, then start PP2.0. The export initially says "Rendering to HDV" then it records to the camera. No issues using that workflow. My A1 is set to 1080i.
http://www.adobe.com/support/downloa...atform=Windows Cheers, Robert |
You are a legend, I will download that now....
Giles |
Aren't there issues exporting 24f back to camera from Premiere at this point?
I have also have a problem exporting to tape from an HD project. However, I was using 1080i. The render and recording process took hours to render, then began to record -- for only 4.5 min. then the camcorder quit, although the computer seemed to be still trying to export.
Anyone with success, please post the largest size project you did. IF over 10 min, please include everything you can think of on how you did it. Thanks, Bill in Ohio |
I just did an experiment with PP2.0 and my A1 and had the same experience Bill is having - it stopped recording at just under 5 minutes. I will run some further experiments soon (like trying with AC power instead of battery). |
Using AC instead of battery had no effect. What I did notice this last time was a quick flash of a message in red on the LCD "Check HDV Input" right before it stops. |
I opened a support call with Adobe. Here is their response:
Hello Larry, Thank you for contacting Adobe® Web Support for assistance with Adobe Premiere Pro 2.0® I understand that you are still unable to Export to Tape from Premiere Pro to your Canon XH-A1®. Unfortunately, as previously stated, this camera has not been certified for use with Premiere Pro. We are also aware of the problem you are experiencing, and at this time there is not a resolution. As far as we are aware, the Export to Tape process will fail regardless of the software program you are using. This appears to be a hardware problem with the camera. We suggest that you contact Canon for further assistance. Kind regards, Casey M. Adobe Web Support ___________________________________ |
I talked to a Canon Tech Rep, he has forwarded this concern upstream. I asked him to bug them for how they checked they could export to tape.
Did they use a utility? Did they use a specific NLE? I have posted this question on each of the other NLE forums here at DVinfo.net to see if anyone has tried it. I did not see any posts on someone having trouble. Adobe's response seems a little to pat. This is why the military has a single overall integrator for systems -- so the contractors can't point fingers at each other. They really are saying they never tried out this camcorder. Thanks, Bill in Ohio |
Below is my latest response from Adobe. Quite frankly their responses are sounding more credible than Canon's.
************************************ Hello Larry, Thank you for contacting Adobe® Web Support for assistance with Adobe Premiere Pro 2.0® I understand that you have contacted Canon® support for this issue and they advised you it is a software issue. I apologize for the frustration of being referred back and forth. We have tested the camcorder and seen the exact same issue of export to tape stopping after about five minutes from both Premiere Pro and other applications that we tested it with to confirm it was not a Premiere Pro-only issue. This testing was done after other customers reported the same issue with this camcorder. In each case the camcorder displayed the same "Check HDV input" message when the export stopped that you reported. We are not aware of a solution to this issue at this time. You can check our website or contact Technical Support to see if any updated information becomes available in the future. Kind regards, Leland B. Adobe Web Support |
anyone find a solution yet?
Here's the non-news from Canon:
Dear Mr. Chapman: Thank you for your inquiry on the XH A1. Canon USA has made no announcements regarding the release of a firmware update related to the issue you have described. Also, no service notifications have been released for the XH A1. We recommend you check our website from time to time to learn of new announcements. Please let us know if we can be of any further assistance with your XH A1. Thank you for choosing Canon. Sincerely, Chris Technical Support Representative |
I am not sure that this is a hardware or Canon Firmware issue. I tried an experiment with a Canon GL-2 transfering SD to the A1 no problem at all.
Earlier I successfully transfered between two A1s in both HD and SD. All transfers were for over 10 min. The HD transfer was over 15 min. So I think it might be more than Canon's problem. A guy using Edius reported success in another thread. Bill in Ohio |
| All times are GMT -6. The time now is 06:29 PM. |
