-   Adobe Creative Suite (https://www.dvinfo.net/forum/adobe-creative-suite/)
-   -   Ppro 2.0 - Best way to de-yellow the image (https://www.dvinfo.net/forum/adobe-creative-suite/95759-ppro-2-0-best-way-de-yellow-image.html)
Nathan Quattrini June 4th, 2007 01:26 PM
I forgot to white balance, so the video is very yellowy. Whats the best way in Premiere to correct it so its not yellow? Using RGB to change yellow has got me baffled.
Joshua Clarke June 4th, 2007 03:31 PM
Nathan,
Drop Fast Color Corrector or Three-Point Color Corrector on your clip. Find a highlight that you know is supposed to be white; a piece of paper, a white t-shirt, etc. Click the eye dropper next to White Balance under your Color Corrector settings. Position it on what you decided is white, hold in CTRL, click your left mouse button, and release CRTL.
Nathan Quattrini June 5th, 2007 09:10 AM
Theres no white in the shot ;) I used the RGB one, lowered the red a bunch and upped the blue....is this a correct way of doing it?
Joshua Clarke June 5th, 2007 10:27 AM
Nathan, if you are the shooter, it's important that you learn color temperature and switch to the proper setting as shooting conditions change. Don't trust the camera's auto balance. If your camera has presets you can adjust, set one of them to 3200 for tungsten-lit shots, one of them to 3700 for flourescent or mixed source shots, and one of them to 5500 for daylight shots. If you can't adjust presets, always bring with you an opaque white reference and set the camera's autobalance to that reference by zooming in all the way on the sheet of paper or whatever it is. You'll have to do this everytime your lighting conditions change.
As for getting it out with RGB or curves, you'll have to ask someone else. I stick with the color wheel. To correct your footage, drop the FAST COLOR CORRECTOR on the clip, open up the properties under EFFECT CONTROLS set your BALANCE ANGLE to somewhere between 0 and 36 (it'll depend on how warm your footage is), manually drag the circle in the color wheel (BALANCE MAGNITUDE) out to about 50 so that it is VERY blue, and slowly work your way back towards the center until it's just a little more blue than you'd want it. Then, adjust your BALANCE GAIN by dragging it to the left toward 0. This will decrease the power of the blue. Hopefully, this will give you a nice, color balanced shot.
If this does not work for you or you are having a tough time figuring your way around Fast Color Corrector, E-mail or PM me and I'll help you out from my own system.
