vx2000 clip mic
Hi,
What clip mic would someone recommend for a VX2000? Im about to make a car guide and the presenter will be talking while walking thru showrooms etc. I need a clip mic but dont know what to get and from where? Will they all work with a vx2000? Also, in an interview situation, how do u get two clip mics working off of one camera? cheers for any help. |
What are you willing to spend? The simplest solution is a pair of wireless mic like the Sennheiser Evolution 100 series.
There are of course other options too. One common methof is to use a shotgun and let a soundman direct it at the talking talent. You could also use a pair of MD recorders and lav (clip) mics. You synchronize the sound on MD recorders with a clapboard. |
Answer - id like to spend a s little as possible!
You say a pair of wireless mics. Id fit the reciever to the camera - both clip mics would work off the one reciever? Shotgun would make the most sense - except theres only me and interviewer! |
Interviews using two wired XLR mics connected to a BeachTek DXA-4 adapter and then by its mini cable to the mic input on the VX2000 will lay down a left and a right audio track on the cam's tape. I keep the cam set permanently on 16 Bit audio. Sorry for late response from a new member.
Wireless works only in pairs so you'd need two pair for two microphones.
Why not just rent a couple of wireless setups. Not too expensive if you only need them for a few days. |
Do you know if the wireless receiver in the Sennheiser 100 ENG kit can use XLR as well as mini jack lin connecting to BeachTek box. If not, I see no way to connect 2 wireless kits to the VX2000 without a mixer.
The Sennheiser evolution receivers can use XLR as an input. I had the mini jacks cut off and XLR's soldered on. Much more standard and convenient.
You could also use two XLR's connectected to a mini stereo. that would give you a separate input for the left and right track. Hosatech makes a cable for $20. Since the receivers have a gain control, a mixer or beach wouldn't be necessary. |
I think this fellow is looking for a cheaper solution. Just buy a Sony clip on stereo lapel microphone.
One-Point Stereo Microphone ECM-719 It has some nice features and basically does the job. I used this before moving to a wireless setup. There are other lapel mics for less, but you're always stuck with the "leash" until you move to wireless. To attached two microphones to your vx2000, just use a number of audio connectors to break out the left and right channels, and merge them to the tip/ring/sleeve input in your microphone jack. Although RCA <-> 1/8" jack converter cords are less sexy and all 1/8", I find that they usually hold up better because the RCA jacks connections are more snug. Also, they're more common and cheaper. For a stereo microphpone, use a Y-type break-out cord of 1/8" *stereo* phono plug FEMALE to two RCA female. If the RCA female connectors aren't available, you can buy the dual- RCA terminated female connectors. To get the signal into your VX2000, buy the usual computer audio Y cable: 1/8" male stereo tip-ring-sleeve to dual male RCA jacks. The shorter, the better. For mono mics, you can buy mono Y cables to split the signal to both inputs of your VX2000. |
I have purchased 2 sets of Sennheisers and both times they came with minijacks and XLR cables for connecting the receiver to a mixer or camera.
B&H also sell extra cables. |
OK then, problem solved. Both wireless receivers will plug into BeachTek box XLR sockets with supplied cables, or alternatively but less desirably because of loss of its gain control, one will plug into AUX minijack which feeds left channel, and the second receiver plugs into XLR right channel. Does having two receivers side by side cause degradation of signal?
Each receiver has an output level control.
I've used pairs side-by-side with no problem. I suppose an antenna of one could shroud the antenna of the other. The pair I use have different frequency bands. |
Thanks for info. I expect to get hands on experience with 100ENG kit this week. I ordered the "B" kit because the frequencies it offers seem less threatened by interference from local TV stations. If it works as anticipated, I am glad to know that I can add a second kit.
| All times are GMT -6. The time now is 10:03 AM. |
