-   -   Mounting a wireless reciever on the hot shoe (https://www.dvinfo.net/forum/all-things-audio/11388-mounting-wireless-reciever-hot-shoe.html)
Bryan Coleman June 28th, 2003 11:10 AM
For me, mounting my wireless onto my hot shoe would be the most convienent place to put it. Does anyone else do this? I havn't figured out yet, quite how to make a contraption to do this. If anyone has ideas, please let me know. Thanks......
Marty Wein July 6th, 2003 05:01 PM
At NAB-2003 I found somebody who designed such a gadget and it will allow you to mount op to two receivers in an upright position onto the shoe. I will try to look through my notes and I will see what I can dig up.
In the mean time I found a new Bracket for wireless mounting at www.bracket1.com. You can mount your receiver onto the bracket either with Velcro. If you really want to be more professional you can add a BEC mounting box specifically for your receiver.
www.thebecgroup.com
Both items are available at B&H
K. Forman July 6th, 2003 05:27 PM
I have mounted the reciever to the accessory shoe before, even though I usually don't like to record the audio to tape. My ideal setup, was to set up the mics, and run the reciever into my Korg D12. I would put this out of the way in a corner. Worked great.
Chris Hurd July 7th, 2003 09:59 AM
Marty
<< I will try to look through my notes and I will see what I can dig up. >>
I believe this is what you were referring to: http://www.bracket1.com/ -- hope this helps,
Marty Wein July 7th, 2003 05:38 PM
Chris,
Actually the "Bracket1" I did mention in my original post.
What I was looking for is another device that allows you to mount two wireless receivers on the "shoe" instead of on a bracket to the side.
I am sure that I will find it soon and I will post here. Thanks anyways
