Cardoid or omni mic?
Hi
I want to get the a wireless mic kit I will be using it for interviews and outdoor to camera pieces. Should I get the Sennheiser evolution ew 112-p or the 122-p The only difference is the mic, the 112 being omni and the 122 being cardoid. I know how both these patterns work but was wondering if people have first hand experience of both mics in the field? |
omni. despite what you might be thinking, with a cardiod lav when the talent moves their head the levels can change quite a bit. simply getting the mic close will do. I've used ECM44's for NYC street interviews and gotten very clean sound when placing the lav very high up.
Definitely get the 122 omni kit and avoid the cardioid.
Omni = yes Cardioid = no If you use a cardioid to get more "drop out" as the person moves their head. Also the back of the cardioid is pointing towards the body, so you don't get much of the good things about a cardioid and get all the bad. Omni is best. In addition, the difference is only 1.7. This means that an omni aboit 10cm away from the mouth will be equivalent to a cardioid at 17cm. Also, an omni does not suffer from proximity effect, so you can move it closer without changing the quality of the sound. I hope this helps. |
Just to add as the guys say omni is best for personal lav's, you can also use them upside down to stop nasal blasts to the capsule.
Thanks guys
Can someone tell me when a cardioid lav mic would be useful? regards Mark |
For example, stand up news anchor, a pitchman giving a demo at Costco, a sidelines reporter at a sporting event. (Note that all of these and similar are also situations where a handmic is often used.) |
The axis of maximum rejection of the cardioid is pointing mostly towards the chest and you get no real benefit. You can improve the feedback rejection of an omni just by moving it closer, a cardioid has to stay further away. No - steer clear of cardioid lavs. I really don't like them at all. |
| All times are GMT -6. The time now is 11:22 AM. |
