-   -   mini-to-xlr Y-cable (https://www.dvinfo.net/forum/all-things-audio/20750-mini-xlr-y-cable.html)
Nicholi Brossia February 2nd, 2004 05:34 PM
mini-to-xlr Y-cable
I'm thinking about buying this cable from B&H http://www.bhphotovideo.com/bnh/cont...=160632&is=REG, but have a couple questions for anyone that might be able to help out.
Basically what I'd like to do is plug the stereo mini into my camcorder's mic input, then plug a shotgun and wireless lav into the xlrs. I'm thinking that this will allow me to record the lav onto my left channel (channel 1) and shotgun to the right (channel 2).
Am I correct in thinking this will work?
Glenn Chan February 2nd, 2004 05:57 PM
Jay Rose's articles (the "pads"/attenuators one and the consumer mini-disc one) at dv.com (registration required) have information on building the right cable, with explanation of the thinking that goes behind it. There are a few issues:
A- Getting the levels/voltages correct. Some mics require amplification, and most prosumer cameras don't do a good job with that.
B- Filtering out mic input power, if you're using the mic input. (some cameras are better with the line inputs, which does not provide power to the microphone)
C- Providing phantom power if you need that.
Beachtek sells adapters that do most of these things, as well as having adjustable volume controls and automatic limiters. It fits under your camera. They have a model coming out which have preamps in them. Peachtek is selling a similar product, but I haven't seen any reviews of it.
Bryan Beasleigh February 2nd, 2004 08:23 PM
That cable will work, how well will depend on what camera you have. So far as adapters , the Beachtek are very well made and reasonable. One of our members also manufactures an adapter .
http://www.preciseaudio.com/brochure.html
Nicholi Brossia February 2nd, 2004 10:56 PM
I'm using a Canon GL2. I've tried a Beachtek before and liked it. The one you linked to looks good too, but I just don't like how clunky they are. I'd like to keep my weight down and don't like the physical stability, or lack thereof, of the Beachtek. My plan is to make a bracket for a camera mountable wireless lav reciever behind my viewfinder to sustain balance and mobility. The whole setup will operate and look great, but only as long as the Y-cable does a descent enough job.
The articles Glenn mentioned are interesting, but I don't know if they apply to my setup. Both give a low cost, do-it-yourself approach to solving the problems. I think a little surgery would be well worth it if it provided any improvement in audio quality.
Here's links to the articles if someone has an account and wants to read them:
http://dv.com/features/features_item.../2003/rose0303
http://dv.com/features/features_item.../2000/rose1200
I've also sent an email to http://equipmentemporium.com regarding their XLRH8 cables. I guess they have a built in "voltage blocker" but seem to apply specifically to Sony cameras. Does anyone have experience with this cable or ones similar?
Bryan Beasleigh February 3rd, 2004 01:25 AM
Try the $14.50 cable from B&H. I know it works cuz i use one on my VX2K.
I really doubt you'll need pads although jay's articles are very interesting. Any pro mic won't be affected by any camera DC voltage, so did give that a thought. I've been playing with electronocs for years and believe me you'd be hard pressed to build a cable for as little as the Hosatech costs. Your time has to be worth more than the few dollars you may save.
Try the cheap way first and experiment a bit.
Nicholi Brossia February 3rd, 2004 12:36 PM
Just to make sure, with the Hosa cable that I linked to on the first post, each XLR has its own designated channel, correct? I read elsewhere that this isn't the case and just want to make sure.
Bryan Beasleigh February 3rd, 2004 08:55 PM
I have the 5' version and it's a 1/8 stereo to 2 mono XLR. That's a separate left and right channel. The left channel is marked.
Douglas Spotted Eagle February 3rd, 2004 09:07 PM
The channels are separate in Hosa. Just beware of their quality. (or lack thereof)
Nicholi Brossia February 3rd, 2004 09:20 PM
Thanks for the pointers.
Yeah, I'm actually pretty weary of using a Hosa cable. Originally, I purchased one of their single XLR to stereo mini cables that has caused me troubles. For some reason my audio, through the Hosa cable, plays wonderfully through my camcorder headphones, A/V out, and even in Quicktime, but terrible through the camcorder's speaker and in Final Cut (until applying the Expander/NoiseGate filter and tweaking the settings).
I'd really like to find a reliable stereo mini to L/R XLR cable. Unfortunately B&H seems to only carry Hosa. A company on the net called Audiogear (www.audiogear.com) also sells this type of cable. Has anyone purchased from this company or have any other suggestions?
Douglas Spotted Eagle February 3rd, 2004 10:06 PM
Contact performance Audio in Salt Lake City. One of the country's top 5 audio houses, everything carries a lifetime guarantee, they build with Mogami, Canare, and anything else you want.
Ask for Scott or Chris, tell em' I sent you. They'll treat you right.
Bryan Beasleigh February 4th, 2004 12:14 AM
The problem is getting a right angled, molded mini stereo male plug. A straight plug is an inviting target to get rapped. The right angled allows you to velcro or use a rubber band to lock the adapter in pl;ace. I agree that the Hosa leaves alot to be desired, but a straight connector is too dangerous.
If someone can source a molded mini stereo that's better than the Hosa , then let me know. I've bought their adapters and cut the XLR off and installed a neutrik.
Douglas Spotted Eagle February 4th, 2004 12:24 AM
Switchcraft makes a rubber covered, right angle 1/8 connector. It's not molded. But it's also 20.00. Radio Shack also has cheap molded ones. Buy 2-3 for when they fail.
Bryan Beasleigh February 4th, 2004 12:53 AM
I've looked at radio shack and all i've seen are straight and all due respects but their qc and tolerence ain't the greatest. Are you sure it's not the 2.5mm, I've seen those. 1/8 is 3.5mm.
Switchcraft would be worth the money. For $25 you'd have something worthwhile($20 for the 3.5mm stereo and $5 for the neutrik XLR)
http://www.switchcraft.com/
Switchcraft black with gold pin part# 35HDRABAU
silver with gold pin #35HDRANAU
standard # 35HDRANN
All I could find was the standard at $5. Switchcraft silver colored is still pretty good quality.
They look heavy so a velcro strap would be manditory, otherwise there would be too much stress on the female recepticle.
Dave Largent February 4th, 2004 01:22 AM
I use the molded 3.5mm right angle from Radio Shack with a VX. I tape it tight to the VX with electrical tape.
It is the only molded right angle 3.5mm I know
of.
Douglas Spotted Eagle February 4th, 2004 07:31 AM
Horizon sells a rubber covered right angle male end from Switchcraft if that's what you wish to use. Radio Shack sells one that's molded. Several outlets for molded ones. Anything molded is going to have slightly odd tolerances, that's the nature of mass manufacturing of rubber ended cables, unfortunately. Note that in my post I didn't say anything about the quality of the Radio Shack cables? Neutrk might make a rubber covered right as well. good luck!
Nicholi Brossia February 4th, 2004 07:09 PM
Great advice everybody, the Switchcraft looks like a keeper. My only concern now is the actual wiring. I've looked on the internet for wiring instructions. Here's what I understand so far...
Both XLR's #3 pin will be connected to the mini plug's base (black wire).
XLR-1 #2 pin connected to the mini plug's ring (red wire).
XLR-2 #2 pin connected to the mini plug's tip (red wire).
Both XLR's #1 pin reserved for ground (shielding wire). Would it be appropriate to ground these wires to the camcorder?
I'm also concerned with how much wire will squeeze into the little 3.5mm jack. It seems as through two XLR cables might be a little much. Any suggestions here? Am I even on the right track?
Bryan Beasleigh February 4th, 2004 08:02 PM
I have all kinds of soldering gear but it's easier to buy a hosatech for $15 and do the keeper when your sure about cable length etc. The stuff works fine, it's just not pretty.
For wiring go to dvplay.com
Anthony Lee February 5th, 2004 12:08 PM
I had a somewhat related question. I have a GL2, just bought a NT3. I'm having a hell of a time finding a way to use a low to high impedence transformer and yet have a decent quality cable with a right angle 1/8
*edit*
I did find this
http://www.broadcastrepair.com/sales/show.asp?subcat2=10&lbl=XLR-1%2F8%22
"Cable, 3pin XLR Female To 1/8" (3.5mm) Stereo Right Angle Mini Plug, For Palm-Size Camera Mic In, With DC Blocking Capacitors, 10 ft. "
....but I would still be missing low to high impedence transformer
Glenn Chan February 5th, 2004 04:21 PM
If you're going to make your own cable, do all the soldering in the XLR barrel. You can get ones that you can open up, although it's somewhat expensive. You might as well try the Hosa cable first considering the effort you would have to expend making your own cable.
You could always cut it off. ~$30 for 2 cables is only a bit more expensive that buying parts for 2 cables (one with 1 XLR, one with 2 XLR). However, you get a slight advantage to making your own cable in that you can split one XLR onto both channels and record one lower than the other (for redundancy and for extra safety against clipping).
For wiring, the dv.com articles by Jay Rose (the pads and minidisc articles) are different from the dplay.com instructions (the dplay ones can't be printed).
Jay's articles on dv.com have lots of information on that (see the DV camera audio article too [that's not the exact title]). I don't think you need a low to high impedence transformer. Jay has written an article on ohm's law and impedences, but you don't really need to read it. His article on making the right cable doesn't mention that you need to match impedences.
Bryan Beasleigh February 7th, 2004 07:01 AM
Unbalanced for short runs will work in most instances.
Dave Largent February 7th, 2004 08:52 AM
I just ordered the two-XLR-to-3.5mm-stereo from B&H.
I previously had tried a Radio Shack splitter (2-mono-to-1-stereo) but it didn't work out -- noticed a
hum in the audio from a Sennheiser mic. I thought this
might be because of the DC plug-in powering of the VX.
Or maybe it was just a cheap RS splitter. If the
Y-splitter I ordered doesn't do the trick, I'll go with
a cable that has a DC-blocking capacitor.
Curiously, I notice that Beas has not had any trouble with the
VX plug-in power.
