Thanks-- I try to be accurate and add something of value to the discussion. Sometimes it may be a little more detail that people are used to, and I may offer contrary opinion, by I do so in the best interest of fairness.
I appreciate your appreciation. :-) But whats a "Fujinon"?? You've really got me wondering..... |
Fujinon is the broadcast division of Fuji Optical.
Oops, Neil Slade really did have the original post of this idea: I didn't realize I was following in his footsteps until I was alerted of his older post - I guess I did add the coupler idea which makes the project even simpler and to an "In Home Depot" project completely. Anyways, hats off the Neil, and I'm glad so many people are reading this post and making use of it! Best of luck to all in your micing adventures!
Bryan, are you out there?
Hey bryan, just wanted to see if you could e-mail those pics you posted on this thread, the links are not working any more. Thanks!
Boom Pole Origin
Here ya go
http://www.neilslade.com/Papers/pole.html |
wow, quick reply.
Great, thanks Neil.
While at Home Depot, you can get materials to make a blimp for the microphone as well. Gutter covers wired together to form a cylinder with rubber bands shot through and held in place with chopstix on the outside of the metal screen shell works as a great shock mount as well. I have mine wired to a disassembled (cheap) radioshack microphone holder for attachment to standard mike stands. Costume fur cover takes away the wind noise beautifully! Price for the blimp < $10!
http://www.yafiunderground.com/blimp (sorry: Server is currently unavailable, but should be up in a couple of days...service provider issues. Try back 1/20/06) p.s. I'll be using the method here for attaching my blimp to my paint pole...I currently have the blimp wired to a paint roller frame for thread compatibility. |
Blimp
Hmmm
this is interesting- however, transparency of sound can be an issue in regards to the material covering any kind of wind screen-- previously I tried to use fake sheepskin fur in place of the expensive fancy mike-fur of some devices-- it was not at all sound transparent- so care must be taken when putting generic materials over microphones. I am anxious to see and/or try your invention! Neil |
Here are some pix I scrounged up...
http://webpages.charter.net/knightscape/blimp/ |
I picked up the thread adaptor at home depot last night works like a champ...specifically, I got a 3/8" Male Flare to 1/2" Female Pipe Fitting Brass Adaptor. The 3/8" is the right size for standard Mike stuff, but the thread may be too long on that, might try the compression thread (finer thread) to see if it's a better fit. I like the cut of the 1/2" though, it's a wider thread that makes it easier to use to cut new threads on the paint pole. Used a pliers to thread it down. My paint pole has an aluminum end on it, so it's threaded permanently. 16' of boom pole for $15, blimp for $10... I love home depot.
The compression thread didn't work. 3/8ths flare is the best fit for the industry standard mike stuff.
| All times are GMT -6. The time now is 12:32 PM. |
