-   -   Recommendation (https://www.dvinfo.net/forum/all-things-audio/30021-recommendation.html)
Ron Edwards August 3rd, 2004 11:55 AM
Recommendation
I need some help on which model wireless audio system to purchase for weddings. My cam is a Cannon GL2. I have a $600 budget.
Thanks in Advance!
Ron
Mike Rehmus August 3rd, 2004 12:55 PM
It is hard to go wrong with the Sennheiser Evolution system.
Lots of material on this subject in this forum. Please do a search for the very exhaustive posts.
Bryan Beasleigh August 3rd, 2004 03:55 PM
I agree with Mike. I'm happy with my rig
Ron Edwards August 4th, 2004 06:39 PM
wireless
Thanks for your response.
Is there any reason (other than $$) I could not purchase 2 transmitters and 2 receivers and feed both of my cams?
Is the Sennheiser system selectable on frequency where this might be possible?
Ron
Jay Massengill August 4th, 2004 07:17 PM
Yes, almost all of the UHF wireless units are frequency agile these days. The lower end models that aren't adjustable can still be purchased with a different frequency on each unit to allow for simultaneous use.
With frequency adjustment, you have the advantage of USUALLY being able to avoid conflicting interference. However some sources of interference are as wide as some lower end units adjustment range so you can still be sunk if you don't do your frequency research before buying. (The Sennheisers have a very wide range of adjustment by the way.)
Frequency agility also gives you the ability to use two receivers with one transmitter or to substitute receivers or transmitters if one breaks down.
Aaron Koolen August 4th, 2004 07:22 PM
Likewise my Evolution 100 Sennheisers have been great little workers. I'd go for the newer G2 version though if buying now.
Aaron
Ron Edwards August 7th, 2004 08:16 AM
If I understand correctly, I could put a wireless mic/transmitter on both the groom and the minister (same frequency) and receive both signals into my Cannon GL2.
Matt Gettemeier August 7th, 2004 08:31 AM
In order to use 2 transmitters (or more) simultaneously they must be of different frequencies... which means multiple receivers.
If for any reason you wanted multiple receivers getting the sound from one transmitter you could do that... but not the other way around.
Flipping 2 transmitters to the same frequency will result in total interferance and an unusable signal.
