-   -   Can ME2 be used as a wired mic? (https://www.dvinfo.net/forum/all-things-audio/31233-can-me2-used-wired-mic.html)
Craig McCoy August 31st, 2004 11:23 AM
I recently purchased the Sennheisser Evolution G2 100 Wireless system that included the ME2 lav mic. I was wondering if there is an adapter I can use to directly connect the mic to the XLR inputs of my camcorder (which supplies 48v). Thanks.
--Craig McCoy
Mike Rehmus August 31st, 2004 05:45 PM
Probably have to make your own but it should work.
Marty Wein August 31st, 2004 05:49 PM
Tram as well as some other manufactures make an adapter that will allow you to do that. The Tram model is TR-79
http://www.bhphotovideo.com/bnh/cont...=259965&is=REG
Craig McCoy August 31st, 2004 08:02 PM
Thanks Mike and Marty,
The Tram TR-79+ looks like it would do the trick, but is a bit out of my price range. May have to go the route of making my own adapter.
Thanks again,
--Craig McCoy
Marty Atias August 31st, 2004 09:56 PM
Careful now! I wouldn't go plugging a lav into an XLR input with a simple adapter.
Phantom power is 48 volts and a balanced input. The lav capsule itself only requires 3-9 volts and is unbalanced. The "adapter" has to convert the power and balance it up.
That's why it costs what it does.
Craig McCoy September 1st, 2004 02:05 PM
Marty,
Thanks for the word of caution. I'll keep that in mind as I continue to look for an affordable solution.
