-   -   Chance to use mic with battery adapter ? (https://www.dvinfo.net/forum/all-things-audio/32741-chance-use-mic-battery-adapter.html)
Elmar Tewes September 29th, 2004 09:12 PM
i have 2 sennheiser mics. both use those quite expensive and quite rare mercury 5.6V batteries (PX23) that are sometimes also used in photo cameras.
is there any chance to power it another way ? i dont know... perhaps a kind of small adapter where i can power it with external batteries for example ? or has someone build something like that adapter before ? or perhaps that isnt possible ? i dont know anything about electronic so wonder if there is a chance to do that. it would be a much less expensive way to power the mics (besides the fact that its horrible to get them. or perhaps someone knows a shop in the usa who sells them for much less then here in germany ? i know there also exists a mercury free alternative version but well, havnt found them either...
Troy Tiscareno September 30th, 2004 03:35 AM
Any 6V DC power supply should work.
-Troy
Elmar Tewes October 1st, 2004 11:40 AM
hmmmm... but the only chance to power it is to insert a battery in it. so i need to build something thats fits the slot and then power it that way, correct ?
Troy Tiscareno October 1st, 2004 05:56 PM
That will probably work okay if you are trying to avoid opening up the mic, but you'd probably have better results in the long run by soldering leads directly to wherever the battery leads end up. If I were doing this, I'd add a short length of cable with a connector on the end, so that I could easily unplug the power from the mic.
Without knowing a lot about this setup, I can't really give you any specifics.
-Troy
Jay Massengill October 4th, 2004 03:25 PM
Check this link for sources of the mercury-free replacement.
http://pcworld.pricegrabber.com/search_getprod.php/masterid=742626
Elmar Tewes October 7th, 2004 10:24 AM
thanks for the info. well, ~10$ not cheap but chaeper than here
