Which lavelier microphone are you using with your wireless setup?
I am currently in the market for a new wireless microphone system. I will most likely buy the Audio-Technica ATW-18XX dual channel receiver with two transmitters and the 899 lavalier microphones. Although some people say those 899 lavaliers are pretty good, I am eager to find out which wireless microphones you are using and what you like/dislike.
I have worked with Sanken and I absolutely loved the sound they produce. I also read good things about Countryman and more expensive Sennheisers. Thank you in advance for your feedback. |
I have a Countryman B3. The Sanken was out of my price range at the time. I've used it for a number of interviews, and have a series in 2010 I'll be using it for. Very pleased with it.
Sanken Cos-11x and Countryman b6
Tram TR50. Nice mike. Reasonably good price. /Battle Vaughan
I use Trams, with the XLR TR79 Power Supply you can also hard wire them as well as use them on the wireless system.
Make sure you can get your lavalier pins configured for the AT system (not all mkes work with the AT System). |
Countryman B6 and TRAM50s.
Countryman EMWs on my 1821 dual channel setup.
Sony ECM-77B's, Countryman B6 with Lectrosonics.
DPA 4060 and 4061 along with the Countryman B6 and Pin Mics (though these may be out of production)
David |
Sennheiser MKE-2 Gold and SK500 transmitter and EK500 receiver.
Just like many others, Countryman B3's and B6's on Lectros.
I have a combination of Voice Technology 506, Trams and Sankens. All sound a little different and have different clips etc. All work well although I found the clips for the Trams and VT's better than the Sankens. Cost wise the VT and Trams are about the same. Sanken is more expensive. What i would do is ask the rental companies in your area what they use as we often have to supplement what we own with rental gear and it is nice if it is compatible.
Floris:
Why don't you listen and decide for yourself? Audio In Close Up - Which Lavalier Should I Use?" Dan |
Personally, I'm packin' the Sennheiser MKE-2 Gold, Countryman B6, Sanken COS-11d and the PinMic. Each have their own positives and negatives. I'm hopin' the PinMic makes a come back because of its usefulness in scenes with a lot of body movement. A buddy of mine just used one on this little web show Continental Mills - Bread Machine Mix Handling Tips
Hi, i m using the me4 of the ew-122p g2 set.I was thinking to buy the (mk 400 is it possible?).Would you recomend it?
off topic question: when u capture on the phones too Windy noise how do u act? I mean:keep the camera volume under 5 activate wind filter from onboard camera menu I'm curious about the values u set on the tx and RX. thx a lot and sorry for kidnapping the thread for a lil bit MM |
MKE-2 for clip-ons and DPA headsets for theatre work
Alphabetical order: AT899, ECM77, (hardwired) B3, B6, TR50, VT500.
I hear ya Guy, the pin mic was indeed useful. |
Countryman B3 (wired)
and Sennheiser MKE-2 (wireless) |
text speak is really difficult to read. The wind filter will help - it cuts some of the low end rumble - but if you lower the record level you just record less signal - the noise content is the same. The real secret is covering the mic element - there are some dead cat type material covers on ebay quite cheap - although a bit of fur fabric and some sowing skills will make a pretty effective one. Stop the wind getting in is the major battle. The ME4, being cardioid is pretty prone to wind noise.
| All times are GMT -6. The time now is 11:51 AM. |
