Rugged lavalier ?
I tried mounting a Sennheiser lavalier on the chest of a shirted fighter with a wireless transmitter. The microphone popped in the first round. $150 down the drain. Are there any tougher lavaliers for this job or should I use some sort of housing that may also produce horrible resonances? Would a dead mouse help? The audio need not be absolutely pristine.
Is this a rugged choice? Audio-Technica BP896 Audio-Technica BP896 | Trew Audio |
I am a bit confused?
You put a wireless mic on a fighter during a fight, and you expected it to stay on? It would seem the nature of the fight would damage the mic. I must be missing something. |
Yes, I would like to record the close-up sounds of a fight. Almost no one does this, and it's obvious why. I'm wondering if it is possible to do this economically. The next time, I'm thinking about a necklace-type arrangement because the neck is rarely hit, although it is choked often enough.
Another possibility four microphones on the walls or hanging from the ceiling, but since the room is small, there is too much resonant ambience. A boom operator may do a better job, but he risks getting involved in the fight as he must be close. Also, the boom is obtrusive in the video and is visually worse than seeing another camera operator. Somehow, the latter seems more natural in the fight environment. |
Given that rustle is a problem at the best of times, I suspect you'll have huge problems in placing a mic on a fighter during a fight.
In dramas the sound is all faked. |
I recently worked on a cage fight movie and was swinging a long pole from a ladder out side the cage and it turned out well, of course if there is a super wide shot and you don't want to see the mic, I guess you're soon out of luck.
It's only illegal if there are sanctioned rules. I believe the mic broke when it was struck. Anyway, wireless lavaliers are placed in all sorts of dangerous situations, and I'm just looking for something that can take more impact than the average lavalier. Yes, this is an unconventional use of a microphone.
Do what they do for football games: Use a parabolic mic.
If you need to hide a small mic, they don't come smaller than the Countryman B6. Using a hollow knitting needle, it can be threaded into the hollow collar of a t-shirt and medical tape used to hold it in place. But you'd be risking a $400 mic instead of one worth $150. And as Warren said, if an injury results from the presence of a transmitter, you'll be held responsible. For example, if it's in the small of the fighter's back, a fall onto the pack could cause a spinal fracture leading to permanent impairment. At the very least you should openly consult with all parties involved and include a doctor in the placement process to minimize the risks. Even then, you should make sure you have at least $1 million in liability coverage. In fact I would recommend liability coverage for any company. In today's litigious society, you never know when someone will try to involve you in a lawsuit. |
only to ignore it because it wasn't the answer they were looking for. |
No doubt there are certain "regions" where a small transmitter could concealed, but the basic problem is that these are thin mic cables that are not intended to be pulled. The mic may resist, but it's usually the cables that give up.
Always pay attention to health and safety, these days it can come to sting you. You can be required to document any risks involved during filming before you start shooting and besides you have to be more responsible than the fighters for any additional risks you add to their combat. |
Still, I do appreciate all of the advice provided. Thanks!. |
BTW, the Countryman B6 is tiny. About the size of the end of a pencil. And it's very water resistant -- you can dunk it into a glass of water without harming it. The mic cable is also reinforced with strands of kevlar so there's a great deal of tensile strength, too.
The weak point would be the transmitter and the connector. Some of the smallest and toughest transmitters are made by Lectrosonics. But they're not cheap. Placing the mic pack will be the toughest challenge. You don't want to place it where it will cause a spinal injury when the fighter gets dumped on his back. And you can't attach it to his legs if he's doing a lot of kicking. On the waistband might be OK but if grappling is involved it would create a pressure point on the hips. And, again, you want to keep it away from the spine. The only viable place might be on the side, below the ribs and away from the kidneys. It's still a target for mid-body punches and roundhouse kicks. And it'll have to be secured in a way that doesn't interfere with the fighter's breathing or movements. |
Thanks for the Countryman recommendation, Dean. You seem to have thought about covering fights before. I have Lectrosonics 400 series transmitters, but the last time I tried this, I was using the Sennheiser G4s and stuck the transmitters in the front shorts pockets. I'd keep the transmitter away from body points that would be harmed. The fighters punch, kick, grapple and swing weapons such as 28" sticks (using fencing masks). Oddly enough, the fencing masks used for head protection have no room inside for mounting and when the fight goes to the ground, the fencing masks are removed . I'm OK with partial round coverage this way. Since the fighters usually wear shirts, I was thinking of placing the transmitter on rare targets : the deltoid (shoulder with arm strap) , center of pectoral (chest strap), on leg on lower butt (rear) or in groin area (above groin protector). I agree with all of your comments about avoiding certain body areas. Yes, this type of fighting is dangerous, but it's an emerging movement in the US and also needs good video coverage.
Not to beat a dead horse, but couldn't you get the same sound from a good directional shotgun? I mean, if they're allowing you that type of access, I'd assume it'd be cool to get close with a good shotgun, which should allow you to pick up all the same sound.
I just think you stand a good chance of breaking a lot of equipment trying to lav mic MMA fighters. |
Thank, Josh. Shotguns have an odd sound indoors with hard-surfaces, and the whole issue is that the environment produces a lot of unpleasant reverberation. So, the hope is to mic the players. We've tried hanging a number of microphones down from the ceiling, but that still doesn't give you the up-close, dry sounds of mic'ing the source.
My brother is a professional fighter. I've been just outside the cage a few times as well as rolled and trained with him. There is no place on a full contact fighter's entire body that I would place a wireless transmitter and string a lav. There's just too much of a chance that it will hinder the fighter (unless I'm missing something in terms of the style you're dealing with). If absolutely had to, it'd be a Pin Mic, if you can still find one, on a short cable, with the transmitter in some kind of waist or leg pouch. Maybe you can talk them into buying a extra large jockstrap :)
I'd consider parabolic, football stadium style, choir mics hanging, or hypers on a boom - the Audio Technica 4053b does amazing indoors around reflective surfaces. |
Thanks, Guy. Your jockstrap idea is not as far-fetched as you joke. The bladder is not a common successful target, but driving the hard edge of a transmitter may not be a good idea. So, padding the trI do a lot of mixed martial arts fighting myself, although not professionally. There are parts of the body that are not common targets. I liked the results of placing the light transmitter in the pants front pocket and clipping the mic on the edge of the shorts or even on the collar of a shirted fighter. The mic popped after one round, but I liked the audio up until then. I'm just fishing for better ideas. Please toss the idea about when you're having a few brews with your fighting brother while watching UFC.
I work often with dancers and tight costumes, and one useful place is on the inner thigh - girls usually have skinnier legs than muscled blokes, of course - but the shorts would cover it and it's fairly protected. The other thing is to NOT use high quality, branded mics - we have similar problems with some actors on stage wrecking expensive mics frequently - especially if they do fight scenes, or rolling on the floor, or in tight locations where the cable might get snagged or ripped out. We use cheap unbranded mics - available for around the 50UKP price - audio quality wise, they're not quite so smoooth, but perfect for these riskier jobs - where wrecking a DPA each performance is simply out of budget by a long way. Throwing a cheap one away after a couple of outings, I can live with. In a fight situation, ultimate audio quality isn't needed, is it?
Thanks for the suggestions, Paul. I knew another entertainment segment would have solved the same problems. I;ll give them a try.
Yes, I don't need ultimate audio - just something that can reasonably record the subtleties of the breath and grunts. Body microphones provide a much higher signal-to-room reverb ratio and overall sensitivity than a boom or nearby microphone can provide. |
| All times are GMT -6. The time now is 05:55 AM. |
