-   -   the voice of evil? (https://www.dvinfo.net/forum/all-things-audio/479853-voice-evil.html)
Josh Bass June 3rd, 2010 05:08 PM
the voice of evil?
I'm working on an animated project and want to give my super villainess an unearthly quality to her voice. Any fX/techniques you guys know to augment a regular human voice and push it into the supernatural/demonic/etc. range? Or at least starting points?
I have at my disposal FCP, soundtrack pro, and Logic. Prefer to use FCP since that's where I'm assembling everything, but if one of the others has an essential effect that FCP lacks, that's fine.
Adrian Frearson June 4th, 2010 01:11 AM
Well presuming that your voice artist gives a great performance, you could try adding some pitch correction or gender bending effects. I would prefer to do this in STP or Logic rather than FCP, as you have a more control over the audio in these programs.
Josh Bass June 4th, 2010 04:14 AM
Thanks. I played around with pitch, flanger, and reverb in STP, got a decent result. She is also doing an Irish accent and I'm worried, with all the FX, about intelligibility. So I've got to find the compromise between sounding super evil and being understood.
I've seen "Aqua Teen Hunger Force" get into trouble with this with the ghost of christmas future robot character. . .could barely understand a word.
Jon Fairhurst June 4th, 2010 10:54 AM
EQ and compression are your friends.
I like to combine a heavily compressed track (to fill in the vowels) with an uncompressed track (to preserve the dynamics of consonants.)
Here's a quick tour of voice EQ regions:
* 200-300 Hz: This is the voice fundamental. Vary this to make the voice thin, full, or muddy.
* 600 Hz area: You can knock this broad area down to make room for music and fx.
* 1.2 kHz: This is the key frequency for consonants. You can boost the heck out of a narrow band in this area for dialog without problems. Move the frequency around if needed to avoid resonance.
* 2.4 kHz: This broad area can be manipulated to make things dull or nasal. For instance, with an oboe, messing with this region can make the instrument as smooth as a flute, or piercing and annoying. I think of this as the "character" region. If you have two people that sound similar, boost this region for at least one person to help differentiate their sound.
* 5k - 15k: This is the "air" of the voice. You can boost this to make the voice sound magical, but be aware that too much air causes sibilance problems.
If after the pitch shifting, you have intelligibility problems, try boosting a narrow band around 1k. If it's still hard to understand, try layering a 1k band from the unprocessed voice. Ideally, it will just add clear consonant sounds. There is a risk of phasing problems, but it's probably nothing compared to the phasing issues that you will already get from the other processing.
Josh Bass June 4th, 2010 02:10 PM
Thanks. When I was playing last night I was using an already compressed and EQd piece of audio (using settings I'd applied to all the other dialogue). . .now I'm thinking I should bring in "raw" audio, process it, and then play with the EQ and stuff in FCP to see how it mixes, if it's understandable, etc.
Robert Turchick June 4th, 2010 02:57 PM
one of my favs from music producing is the reverse reverb. not sure if FCP or soundtrack could do this but in Pro Tools it's easy.
reverse your VO track so it plays backwards. apply reverb...record the reverb to a new track...then reverse the new reverb track and your VO to play forward. very spooky!
Josh Bass June 4th, 2010 03:37 PM
I'm not quite sure I understand "record reverb to a new track". Do you mean take the tail reverb (what's left after the person is done talking and it's just pure reverb) and put that on a new track? Or do you mean something else?
Robert Turchick June 4th, 2010 05:43 PM
It's a little tricky unless the software can buss effects. That's why Pro Tools works for this effect. Essentially your "session" would have the following tracks:
1) VO (reversed) with aux send to reverb (track 2)
2) Reverb Aux track bussed to new audio track (track 3)
3) Audio track to record reverb
What you are trying to do is make the reverb an actual audio file rather than a plugin effect. That way you can reverse it.
Later tonight I'll take some screen grabs and post an example.
Josh Bass June 4th, 2010 05:56 PM
Ah. That's what I thought you meant. I'm sure there's a way to do that either with STP or Logic, but it is way outside the scope of my knowledge of either program. I'm working around this particular character's lines 'til I get it all resolved.
Robert Turchick June 4th, 2010 06:13 PM
I haven't used logic in a while but I'm sure you could do it in that.
Josh Bass June 4th, 2010 06:18 PM
My brief research into the STP manual suggests that you can create busses, but not route just an effect to it.
OH, PS, it's Logic Express, not Studio.
Josh Bass June 4th, 2010 06:55 PM
Ok. . .I've gotten to the point in logic where I have a bus with what I THINK is just the reverb effect (sounds like the audio itself, but weak, very metallic, and of course, reverby), but it's just an empty track, there's no region/clip or anything that I can reverse.
Josh Bass June 4th, 2010 11:34 PM
Ok, I had a "duh" moment and tried something. Is the effect you describe similar to this: I take a clip in STP, add reverb, export as new AIF, bring that AIF back into STP, and re-reverse it (making it play normally again, that is). So now you have the weird backwards reverb on a forward clip? It's definitely cool, but makes it very difficult to understand. I guess you like the separate bus thing 'cause you can control the amount of the effect? I could likely do something similar by controlling the plugin in STP, how much wet/dry/etc. I add in the first place.
Robert Turchick June 4th, 2010 11:45 PM
yup! That will do it too. And yes, the nice thing about having them on separate tracks is you can easily adjust.
The other tip I'll give is keep the reverb length fairly short. Maybe .5 - 1 sec decay
Have fun and be sure to post results!
Josh Bass June 5th, 2010 01:10 AM
Well, funny thing. I would post the results, but the piece is fairly unPC short about Jewish ninjas. And the only lines that will have the FX are fairly inflammatory.
Josh Bass June 5th, 2010 03:40 AM
Well, anyway, I think I will try the "reverse-verb." I have to do it very lightly (using the platinum verb, 80 dry/20 wet mix, and 1 sec reverb time--that's what STP calls what I believe you mean when you say decay). Too heavy and it makes the words very difficult to understand. I have some ghosts later in the story who just moan. . .maybe I can be more aggressive with it on them.
I'm adding the verb to the pitch and flange FX, and might do a regular reverb on top of the reverse-verb.
This is until I become dissatisfied and change my mind about everything.
Walter Brokx June 5th, 2010 08:26 AM
I presume recording is already finished?
You can put different takes of the same line on top off each other (the best one the loudest, others pitched or EQed).
If it's not recorded yet: also record whispered versions to put on top of the 'normal' one. Add some reversed reverb and it will sound 'out of this world'. Especially reversed reverb on the beginning of a line: it's sounds like it travels from far.
If you ever need inspiration for evil voices: check myspace and visit: Immortal, Cradle of Filth, Opeth, Deicide, Arch Enemy, Austere.
Not everything I mention is my cup of tea (some might even cause headache), but they al use the human voice to portray evil, anger, torment, etc. Although a lot of the lyrics becomes incomprehensible, it might inspire you on your quest. Use multple layers.
Remember: only downpitching is not evil, it's only Boney M ;-)
Josh Bass June 5th, 2010 01:02 PM
Yes, recording is already done.
The multiple takes idea sounds cool, but the reads on each take are generally wildly different--same intent, but different pace, inflection, etc. Without a lot of surgery to sync everything up it was just come out like word noise.
John McClain June 5th, 2010 03:14 PM
Here's a link that should help you out, enjoy! john.
Designing Sound Jim Stout Special: Making a Scary Voice Effect
Josh Bass June 5th, 2010 04:08 PM
Yeah, that's pretty much what I did (except for the delay). I have Logic Express, which doesn't seem to have that "dreamverb" preset (I checked all the five or six flavors of reverb and it's not in any of them). Does anyone know how to recreate it? If not, I'll go with the way I've got it set now.
Rick Reineke June 5th, 2010 10:32 PM
In the analog.. Oooooooo 'dark ages' (no pun) We use to get the 'devil' effect with the Eventide 910 Harmonizer.. and god-forbid.. flip the tape over for reverse reverb and other out-worldly effects. No quick undo or delete.. Sometimes risking total loss of a song / session / job / career. Can't say I miss those days in some respects.
BTW, the Eventide series are available as plug ins. Not cheap though.
Richard Crowley June 7th, 2010 08:56 PM
The effect that I find most creepy (even when I am conscious of it) is "chorusing" where the dialog is doubled tripled, quadrupled (etc) with slightly different-sounding timbres of the original speech. It really conjures up that "legion of devils" concept.
