Zoom H4N vs. Tascam DR-100
Hi there,
I have finished with my research. I do not currently have the need to make a choice, but I just wanted to open a 'Versus' thread about these two sound recorders only for the Joe who is in the middle of the same research. Yes, there is plenty of stuff here about them, but no post ONLY about these two. I have a Rode NTG-3 and I finally got a Tascam DR-100 over the H4N. Why? These were my key points to go with the DR-100: * Separate Line out and Headphone outputs. * Dual battery source (AAs and rechargeable Lithium battery) * Ruggeder built. * I do not have the need of 4 channels. * External dial (manual) levels wheels (no digital through menu) for your XLR inputs. You might have different needs and the H4N will work best for you. But if anybody wants to ask or add more information about these two or their differences please feel free to add. The independent Joe filmmaker (such as myself) will definitely appreciate it. Cheers!! |
I exchanged my Zoom for a Tascam for the reasons you enumerate -- especially the battery and manual level controls.
The Zoom also had a laughably bad instructions manual and the other thing I found annoying was that it seemed too musician friendly, built in metronome etc. I couldn't however say which had better audio, they both seem great to my ears. |
FWIW, I concur with Ben's findings. Based on my experience with Tascam and Zoom products, but without ever having used either specific model, I would choose the Tascam.. if having four discrete tracks is not an issue.
While I am sure that both units works perfectly well for double system audio recording, some things I like better on the zoom:
The ability to input line level through the XLR connectors The ability to record at 24 bits 96khz vs 48 on the tascam The fact that the AC adapter is included and not optional like the tascam The ability to record 4 tracks of audio (Very handy!) Definitely, the ability to set the gain independently on each track on the tascam is a huge plus as well. |
My research has led me to a Marantz Professional 661 with the (significant) Oade modifications, which I will buy over a Zoom H4n or a Tascam DR 100.
Others mileage, as they say, will vary. |
Btw, it's true the Tascam doesn't have AC adapter. But it charges off any USB port, which I love. And my Droid charger works on the Tascam lucky for me. |
Any usb port... Good to know.
Here is a useful comparison. Note the Sony that is rated higher than the Tascam, for not much more cost.
Portable Recorder Reviews |
I think that's old pricing, I paid a lot less than that from B&H.
Also, I can't remember if the Zoom has this feature, but the TASCAM has a red idiot light to indicate peaks as well as the regular screen level bars. I do appreciate them. Anyone know if the firmware giving the Tascam 96hz is out yet? |
Awesome info
I feel I made the right choice. Quote:
Very much indeed.... ;) Quote:
Hey Brian, Yes the Marantz Professional 661 is more expensive and according to my research, it seems to be a (slightly?) better bet than these two (in terms of quality). However, there is another thread about that device and these two. I opened this one just because I wasn't able to find a specific thread about these two devices only. My budget set a limit and the 2 devices fitting that budget were these 2. Have a nice week you all!! |
We've had some glitchy behaviour with the Tascam. In a couple of instances, files have been corrupted. Also, the battery life of the Tascam is atrocious. Finally, it is cheap plastic. The 1/4 screw mount in the rear broke after only a couple of months. So we no longer use it and have returned to using the Zoom H4N. My only problem with the Zoom is the high noise floor. But for the event work I do it's not really an issue.
I think it's time something better came along though! Neither the Zoom nor the Tascam are even close to being pro units. |
As Steve points out, these are not pro level field recorders, and an SD 702 is a huge leap in cost for a pro level recorder from this level.
With that being said, I have used the the relatively inexpensive H4N effectively many times as a field recorder being fed from an SD 302. All the Best! |
| All times are GMT -6. The time now is 11:12 PM. |
