-   -   Rycote S-Series Windshield Demo and Shootout against the Rode Blimp (https://www.dvinfo.net/forum/all-things-audio/499834-rycote-s-series-windshield-demo-shootout-against-rode-blimp.html)
Chad Johnson August 21st, 2011 02:49 PM
I recently picked up the Rycote S-Series windshield, for it's size and simplicity and price (270.00 US) and I really like it. Here's a video I made taking a look at it, and there's a shootout against the Rode Blimp - both going up against an industrial fan. For the amount of wind coming at these blimps, they both did really well IMO. I'm glad I have both, as I can choose one or the other (or both!) depending on my needs for the day.
Do you ave either of these windshields? What are your thoughts?
Matthew Capowski August 21st, 2011 07:53 PM
Re: Rycote S-Series Windshield Demo and Shootout against the Rode Blimp
Just happened to have an industrial fan lying around Chad? Thank you for the interesting video. Good to see another low-price alternative.
Tom Morrow August 21st, 2011 08:20 PM
Chad your shootout videos are incredibly valuable. Thanks for this.
I'd suspect that lyre suspension in the rycote would transmit more handling noise than the softer suspension of the Rode. It looks like the Rycote might be easier to use than the Rode, although I'd be worried about longer microphones slapping the cage depending on how stiff those narrowly-spaced lyres are... I wouldn't think they can make it both stiffer and transmitting less handling noise, so something has to give.
Chad Johnson August 21st, 2011 08:50 PM
Those fans are very useful to many Humboldt residents! Though that one is not mine....
Tom, the Rycote lyres are great things that reduce rumble more than anything else I've seen (heard). Better than rubber bands.
Their effectiveness is demonstrated in another video I made:
John Willett August 22nd, 2011 06:22 AM
Agreed
Wrong - the Rycote Lyre suspension is a lot better than the O-ring suspension.
The Røde suspension is a copy of an old Rycote design that they stopped using when they developed the Lyre.
The Lyre design is the best there is at preventing vibration getting to the mic. and the S-series cable is also of a special design that prevents vibration coming up the cable to the mic. (I use S-series cables on all my mics. now, even when they are not in a windscreen).
And isn't the Røde pistol grip and suspension bit rather heavy when compared to the Rycote?
The Lyres can be clipped at various places inside the S-series windshield - you choose the spacing to suit your mic..
Lyres work in a different way from rubber O-rings - there is a long transmission path that the vibration has to get through before it reaches the mic. and are very effective without having to be so soft as an O-ring. Also, they dont bounce or droop like O-rings and do not deteriorate with age like O-rings - they are also extremely tough and can be tied in knots and still revert to their normal shape.
The only other mount that comes close to the Rycote Lyre is the Cilela OSIX - and that is a lot more expensive.
I didn't change all my suspensions over to Rycote Lyres for nothing - I have Windshield Lyres, InVision mounts and USMs - in fact, every version of the Lyre I have in some form or the other for my microphones. I use them on everything now, from Neumann LDCs, several SDCs, gun microphones and a Soundfield mic..
Have a look at this pdf article - Keeping Microphones Quiet - which will explain things a lot.
Tom Morrow August 22nd, 2011 11:53 AM
I think I'm sold... literally. I'm buying a blimp today and about to pull the trigger on this S-series.. it seems better in usability and if the isolation is better why not. And looks less expensive than the $300 rode blimp [Edit: which includes a deadwombat furry]. No downside I can see except being less proven than the Rode.
Tom Morrow August 22nd, 2011 12:08 PM
I'm thinking of getting the s-series 375 model designed to fit mics 11-13" long so that it will fit my 12.4" ME66. But I'm considering eventually upgrading to a Rode NTG3 which is 10" long. I can't see any reason why a 10" mic wouldn't fit in a blimp designed for 11-13" but am I missing anything?
Tom Morrow August 22nd, 2011 12:11 PM
Rycote Portable Recorder Audio Kit TEST on Vimeo
Those fans may be the key to being able to afford good video gear :-)
Chad Johnson August 22nd, 2011 12:32 PM
Tom I would think that the larger size would help the wind reduction, but you may want to ask if the mic clip would fit both mics. I bought mine for the NTH-3, but it worked fine on the NTG-2, which is a bit thicker.
PS> the dead wombat comes with the Rode blimp.
John Willett August 22nd, 2011 02:12 PM
If you change mics. you can get the S-series end bits on their own - so you can get different lengths to change the S-series for the mic. you want.
The clips on the Lyres in the S-series will take any mic. from 19mm up to 25mm in diameter, including the flat-sided Sennheiser MKH series.
Tom Morrow August 23rd, 2011 09:17 AM
I emailed Rycote and they said there's no problem with going to a bigger size except the slightly increased weight and length. I ordered the s-375.
Chad Johnson August 30th, 2011 01:24 PM
That makes sense. And the extra air space will only help cut the wind.
Toenis Liivamaegi August 31st, 2011 06:06 AM
For low cost alternatives the Soft-Zep II Basic is quite OK. Much better than all those Chinese and India made knockoffs and almost as good as the S-series from Rycote. I tend to use this all the time as it's light and durable. This is an open cell foam based Zeppelin.
But a full blown Rycote and the lyre system is the king.
T
Chad Johnson September 13th, 2011 06:26 PM
That looks OK, but really I'm all for going the extra mile with wind protection. The S-series does a good job, but anything less is going to present problems if any gusts pop up.
Sabyasachi Patra September 14th, 2011 02:01 AM
I use the Full windshield kit 4 and am very happy with the performance. The only problem is while travelling in flight, the security guys often insist on removing and showing the microphone. It has happened a number of times. So I reach a bit early to compensate for this. The s-series kit is easier to dismantle.
I am not sure about effectiveness between the s-series and the full kit. May be John Willet can confirm. Any idea John?
Cheers,
Sabyasachi
John Willett September 14th, 2011 09:46 AM
The S-series is not as good as the full kit - it's half the price.
But it does not fall that far short of the full kit. The suspension is basically the same, the diameter is about the same, but the Windjammer fur is shorter.
In most cases you won't notice the difference I think.
But - personally - I never travel with the mic. in the shockmount; it always travels packed separately.
Sabyasachi Patra September 16th, 2011 01:21 AM
[QUOTE=John Willett;1682027
But - personally - I never travel with the mic. in the shockmount; it always travels packed separately.[/QUOTE]
Thanks John!
Logically it makes sense to pack it separately. I carry it in with me in the flight, so was trying to reduce the number of items in the bag. The sennheiser case for the microphone is nice. Travelling with equipment is becoming increasingly painful.
Cheers,
Sabyasachi
Tom Morrow September 20th, 2011 12:51 AM
I got the S-series just after this thread, thanks Chad. I've had a chance to use it a few times and like it very much. It seems very well engineered, where they really do make the ounces count.
One place they may have gone too far though was with the sizing. I have a mic that is 1/2"shorter than the max rec'd mic for the S-series size I bought, but that's barely enough wiggle room to avoid having the front or back cables of the mic crash into the endfoam of the zeppelin.
I had to readjust, reassemble, shake test with headphones, a few times until I found just the right positions for mic and cable where the mic won't crash into the zep with handling. Maybe I'll put tape on the mic to indicate the proper position, but for now I'm just keeping the mic inside the zep all the time.
Point being if you change your mic often consider a larger zep length to give yourself some wiggle room and avoid crashes.
Anyway, I'm happy with the purchase and doubt I'd see much more value in the full kit.
John Willett September 22nd, 2011 04:19 AM
If you are using the longest S-series and the mic. is still tight, try using rt.angled XLRs - or - the XLR without the housing (as a friend of mine does).
