Is there a small external Pre-amp for camera's?
Is there a (small) pre-amp that can be placed in between the camcorder and the mic's? The idea is to set the camcorder's XLR audio input to LINE mode (bypass internal amplifiers) and use a small external pre-amp and thus increasing audio quality.
All solutions I found where either very large mixers intended to be used by a seperate person or zoom's that record the audio by themselfs (not needed) and didn't have any XLR line outputs... Any ideas? |
Re: Is there a small external Pre-amp for camera's?
Ah yes, thanks for that quick suggestion. However this has 3.5mm stereo jack output where I would need dual XLR outputs...
My search continues :) |
Thanks, that looks quite interesting! Especially the 'unclippable input limiters', 5-18vdc input and the small size.
Not the cheapest, but you get what you pay for. Thanks again for the suggestion! |
Buy once…cry once. :D
Seriously, Sound Devices gear is stuff you'll have for years if not decades. It's that tough and that good. |
Also the MM-1 or MP-1 from Sound Devices. The Sound Devices price is definitely worth it.
MM-1 Line Driver / HP Monitor | Sound Devices, LLC MP-1 Portable Microphone Preamp | Sound Devices, LLC |
@ Steve, Good point. Do you know which cameras that do or don't put a pad on the XLR inputs?
I have had a very noticable improvement in signal to noise ratio when I got an audio feed at line level into my EX1R.
Even very low volume parts could be amplified in post without noticable noise, or at least at a vast improvement over the normal mic level inputs. But better safe than sorry, so can anyone confirm about the EX1R? |
Hmm I can't seem to find an confirmation anywhere about the ex1r completely bypassing the internal mic pre-amps when in LINE mode... I'll do some tests and report back.
I would bet at least the $20 in my pocket that there are NO current-model, un-modified video camcorders which actually BYPASS the mic preamps for true line-level inputs.
NO camcorders are designed to have dcecent audio. At the low-end, it is a matter of economics. And at the high-end, it is assumed that you aren't seriously using the camcorder audio track for anything but a scratch sync source. And in the middle, there may be some cameras still left (???) which may reduce the gain of the mic preamp input stage for somewhat lower noise when used with line-level inputs. But still a kludge. I would wager that the camera with the VERY BEST audio performance is no better than your average decent modern, portable digital recorder. Jay Rose used to test the audio performance of higher-end camcorders, but I don't believe we ever learned anything except that there wasn't anything much above average in any of them. |
Did some testing and as Richard above points out the EX1R probably doesn't bypass the internal mic preamps, but merely pads them. Here are my (non scientific!) findings:
The following yields exactly the same noise floor or signal to noise ratio. These two settings create about the same overal volume. 1) Setting my Sennheiser G3 wireless set at maximum output and my EX1R to line mode with volume knob at 10 and 2) Setting the Sennheiser G3 reciever to -12db, the transmitter to -6db and the EX1R to mic mode with volume knob at 5 and the trimmer to -53dBu ( I use this setting on a regular basis for interviews) Next I plugged my Samsung Galaxy S into one of the XLR's from the EX1R (line mode) and played a piece of classical music. The nice thing is this piece of music has a long fade out which shows what noise the phone itself is creating (and the noise in the track itself, but that's pretty much non existent). After the song ends the amp from the phone shuts off, which only leaves the EX1's noise audible. And after that the clip ends and all we're hearing is the noise from my speaker/amplifier set. -The Samsung Galaxy S is creating a little bit more noise compared to the Sennheiser G3. It's like a little humm (it was just battery powered btw) -When the phone amp shuts down (end of song) the remaining noise is (as expected) again the same as with the sennheiser G3 (compared to either in line mode or mic mode with the according settings on the EX1R) Next was the -20dBu setting on the EX1R. Volume knob at 5 on camera. I plugged in the Samsung Galaxy S once again and set the volume on it so it would give me the same overal loudness: -The same humm coming from the Samsung phone itself was again audible -However, near the end of the track I noticed the overal noise was just a bit lower -When the track ended (phone's amp shut off) it became more obious the remaining noise was lower than the line input mode, lower than the sennheisers G3 line input mode and lower than the sennheiser mic mode with the EX1r at -53dBu. Plugging in the Sennheiser G3 again (and setting outputs accordingly to match the -20dBu on the EX1R resulted also in a similar small but very noticable improvement. Will try some more! /edit It stays about the same till about 30dBu, after which the signal keeps getting louder but then relatively more noisy. So the best (or the least bad) solution would be to set both the inputs between 20 en 30 dBu and set Wireless mic's accordingly... Ofcourse phantom powered mic's have fixed output (except from maybe a wind filter or a pad) and 20/30 dBu is WAY to low... so in that case one could add a Mixpre-D and set that to match the EX1R's 20/30 dBu input. It would give pretty good results although not what the MixPre-D theoretically could achieve. Probably not worth the money if it's only about getting one step lower noise... |
One of the pioneers of this issue:
greg j. winter :: modifications |
As previously mentioned, there are a lot of good reasons to use a proper mixer upstream from the camera - better high-pass filters, better limiters, more control over levels, etc - but avoiding the camera's mic preamps by using its line-level inputs isn't among them.
That said, providing a hot signal to a cheap camera preamp can make the audio competent. Using a mic straight into a cheap camera preamp is a recipe for noise.
Using a juicedLink into a 5D Mark II reduces noise levels down to the limits of 16-bit recording. For best results, use Magic Lantern, which allows the analog gain in the camera to be reduced. On the other hand, using a passive XLR-in preamp into the 5D Mark II gives really noisy results. I've had similar results with a crummy M-Audio Microtrack II recorder. It has no analog gain control, and the digital control simply reduces dynamic range, so you really need to leave the gain levels fixed. If the signal is weak, you boost it in post and get horrible noise. Add a juicedLink upstream and you can ensure a strong signal. Even though the unit supports balanced inputs and phantom power, the JL improves its performance, but it's still not as good as a 5D2 with a JL and ML firmware. But the JL makes it usable. Anyway, a hot signal into a cheap preamp is always better than a cold signal into a cheap preamp. Lots better! But there are still limits. You can go from bad to good, but it's unlikely that you can go from bad to great. |
Thanks for all the feedback! My EX1R seems to be pretty good at the -20 or 30 dBu setting, so adding that Mixpre-D in that scenario does have a positive effect compared to the 'normal' 50 or 60 dBu on the EX1R
Not worlds apart, but that's also due to the law of diminishing returns :) Don't know yet if it's worth the money. 90% of the audio I need comes from the Sennheiser Wireless sets which are great anyway and don't need another amplifier. Only when recording live events with normal mic's and not using the wireless sennheisers would benefit from this MixPre-D, and it would only be critical to use this setup when the application demands it. Like recording a music performance like classical guitar (without amplifiers) or violin etc... No my usual day to day business. |
| All times are GMT -6. The time now is 12:17 PM. |
