Shure mixer connected to Canon HV 30 camcorder
1 Attachment(s)
Hello everyone.
Now that I've got somewhat of a handle on the input side of things between my mic (AT 822stereo) via the right cables, which are on their way, I'd like to touch on the output side of things. So if you'll indulge me... First, I am also well into Jay Rose's audio book, and there is lots of great information there that, in addition to here, will help out the quality and understanding of my own audio practices. My intention is to find the best solution to hook up the Shure FP 33 mixer to a Canon Hv30 camcorder for recording audio. If you have any questions for me I can respond to them as best as I can as we go along. For connections, I obviously won't be connecting the L and R outs from mixer to the camera, since the camera takes a 1/8" mini pin connector (three pole I think). Unless you think there is a adaptor and that's the way to go. The mixer also has a "Tape Out" as well, also mini pin. And then there are the headphone female out of which there is a 1/8 mini and 1/4" TRS. So how would you guys go from the mixer to the camcorder? I don't believe the HV30 has an auto gain switch, but I know that you can set the levels for sound manually and lock them, if that's any help. There is also a menu item you can set for "Attenuation on/off", but not sure which to set that using the set-up above. If you guys recommend either cabling out from the headphone monitor on mixer or the tape out on the mixer, both 1/8" mini, would I use a stereo plug/cable from mixer to stereo plug input on the camera? Regardless of how I cable this thing, would I use the mixer tone generator to set the level on the camcorder? On this I'm guessing yes, so that everything is at the same level. I leave it here. If you have any insights or have used an HV30 connected in some fashion, please let me know your thoughts. And if you have any questions I can answer. On a final note, When I've work on semi pro-pro camera set ups, running the xlrs from mixer to the xlrs into the camera were pretty straight forward. The question is how the HV30 will play with a professional piece of audio equipment like a mixer. Thanks. Jonathan |
Re: Shure mixer connected to Canon HV 30 camcorder
You would need a simple cable with a 3.5mm TRS ("stereo") connector at each end. RadioShack sells cables like these in several colors(!) For example: Catalog #: 42-961 for $4 NOTE: Unless it is already done to your unit, the FP33 must be modified internally to output MIC-LEVEL to that connector. The instructions to do this are in the User Guide at the top of page 9. You MUST make this signal mic-level or it will NOT work with your HV30. THIS IS MANDATORY, not an option. If you don't/can't do this, then you must use the XLR outputs (with the appropriate adapter cable) set to mic-level. Quote:
I've got the HV20 and HV40. As well as the on board mic, there's only an external stereo mic input on this series of cams, no line input for any mixers.
As Richard said, switch the Shures output to mic, and plug its 'tape out' to your HV30 external mic in. Use as short a cable as you can. You can use its tone oscillator to match your HV30s input level. There's more about this in the HV30 manual and in general, in your Jay Rose book. For voice recording, use the Shures limiter to keep the levels in check and monitor with headphones from the HV30, there should be enough level. Practise practise Johnathon :) Never switch the 48V phantom power 'on' until you connect all your 48V mics to the mixer. Do the reverse when you're finished your session. Cheers. |
Richard. Thanks for all that!
So far it seems that the proper way to go is from the tape out to the mic in, if the mixer is set up to handle mic level per your note. I'll check that out. How about this scenerio: I actually have a short cable/adapter that has a female xlr at one end, and the stereo mini pin at the other. Could I plug this into either the left or right out on the mixer (set tor mic level), connect to the HV30? My goal is to get a left and right soundtrack from the camcorder. And is this nuts? How about a custom adapter: two female xlr (left and right on mixer) to mini pin stereo other end. Or would I be able to get left and right sound out from cmcorder using the single xlr from either L or R on mixer to camera? And lastly, I'm assuming that if I wanted to do something like record to HD on a laptop, the same rules apply? Always appreciate your help. Best to you. Jonathan |
And this is NOT the same as a special XLR cable/adapter made for a stereo microphone. Quote:
Once had to hook up an HV30 to the audio output of an ac-powered mixer. Found that when the HV30 was used with the canon ac adapter, I got a ground loop (hum). Didn't do this when run on battery power, however. Might apply in your situation...
The tape out of the FP33 is line level. Switching the XLR inputs or outputs to mic level doesn't change that. Your camera is mic level so you have an impedance mis-match. The line level will have to be padded.
A Juicedlink box is the better choice over the FP33 in this case. |
Levels have nothing to do with impedance. The FP33 has sufficiently low output impedance that there is no issue here. |
Awesome. Didn't know that. Hope it's useful someday. Thanks.
Alan, I must have been type my reply whn yours came in. The Jay Rose book is really helpfull. I still reading and re-reading the first few chapters that deals with some math stuff, plus I'm a slow leaarner.
I will get the shortest cable possible for between the mixer and camera, since both will be near me when I shoot. And yes, practice, practice, practice. Read. Read. Read. I'm using my slow time, between Christmas and Memorial Day, to work through all this ;-} And Richard, thanks again. Tape out to camera is the way to go then. Can I ask a you, is it just standard that the mic input on the HV30 or most camcorders that the input is un-balanced. I'm looking at page 103 in the Canon manual in the spec for Mic "3.5mm stereo minijack, -57dBV (with 600 ohm microphone) 5 kohms or more". I could be so new to this that the answer is right there and I just don't know it. Camera manuals sure don't help a whole lot, it seems. And about the laptop situation, once again I forgot what was sitting right in front of me, my M-Audio Fastrack Pro interface. I think for my VO only work, my practices will be to use that. I will check out page 9 of the FP33 manual. Not certain if that is a dip switch setting or if it involves soldiering something. But I'll look into that today. As far as using AC power, I use that exclusively if I know I'm going to conduct a stationary interview. I have not had any problem (i don't think, but then again, want to go from aceptable audo to a least good audio). Is the noise issue something that occurs mostly when a camcorder is connected to mixer? And I'm assuming this is not an issue with prosumer units that have balanced input (xlr) Or just use the camera in battery mode. Thanks Battle. Thanks fellas. Jonathan |
Quote: Is the noise issue something that occurs mostly when a camcorder is connected to mixer? And I'm assuming this is not an issue with prosumer units that have balanced input (xlr) Or just use the camera in battery mode. Thanks Battle.
A ground loop occurs when there is a voltage difference between two grounds, as I understand it -- Richard will probably have a better explanation --- but there's a small voltage signal existing between the ground side of your camera's ac adapter and the ground side of your audio input's ac power supply that causes the hum. If you eliminate one or the other ac source, the hum goes away. We had to run the camera on battery to eliminate the problem. (Aside) Personal to Richard C, are you the same Richard Crowley I went to college with in Memphis in the 60's by any chance? We were both into stills and 16mm film then... |
"I believe as long as you are operating the mixer on internal batteries, you won't run into the noise problem. The noise comes from ground loops when connected to other power-mains powered equipment.
+1 Additionally, ground-loops can usually be avoided by having the interconnected audio/video gear plugged into the same circuit. Field production audio gear draws very little power so tripping a breaker should not be problem... Obviously, lights should be distributed on separate circuits accordingly. |
Wow! That adapter cable from Trew certainly comes at a premium price! I think I could make 3 or 4 of them for that price. And not even gold-plated! :-)
For me, the way I would feed the camera is to feed out of the XLR outputs on the Shure Mixer, into an XLR adapter mounted on the camera. See the Beachtek or Juice Links for examples. This gives you multiple set up capability. At the mixer you can mix three inputs to two channels out. Most of the time in dialogue, you mix down to a mono signal so you only have to feed one XLR cable out to the camera.
Seems to me the Juicelink alone will do the trick nicely.
The XLR adapter cable on the FP33 may still be preferable to the modification required to change the Tape Outs to mic level: From page 9: Decreasing Tape Out Level to Mic Level 1. Locate R1112 and X511 (the top side of the bottom PC board, by the L Out XLR connector). 2. Locate R1114 and X510 (the bottom side of the bottom PC board, by the Tape Out jack). 3. Remove R1112 and R1114. 4. Solder a jumper through the holes at X511. 5. Solder a jumper through the holes at X510. |
I believe others share my opinion that the Shure mixer is in a different class than anything made by Juiced Link. A Juiced Link product is NOT the equivalent of anything from Shure.
Not knowing how to solder is like not knowing how to put gas in your car. You can survive, but only at the mercy of others. And people who don't do critical comparison shopping are condemned to buy expensive cables. Sorry. Trew is a great company, but addition of a couple of 50-cent capacitors is not excuse to jack up the price of a simple cable by $30-40. You can have a CUSTOM cable built by Redco that does exactly the same thing for less than 1/3 the price Trew is asking. And you can make your own for 1/4 or 1/5 that price. http://www.redco.com/shopexd.asp?ycable=yes&id=899 People who learn at least enough to cook for themselves save tons of money over those who are dependent on McDonalds, et.al. |
Learning to cook for yourself is pretty harmless. Learning to solder on an FP33 isn't a good idea and I wouldn't ever recommend soldering a PC board without knowing the skill of the person. Also, modifying the FP33 affects the OP using it for VO to a Macbook pro
http://www.dvinfo.net/forum/all-thin...ml#post1768958 Then there's ergonomics, the Juicedlink and Beachtek devices are built to sandwich between camcorder and tripod. |
Thanks Guys.
Les, I think for VO, I'd go for the mic>M-Audio Fastrack>Mac laptop. Or at least test this to see if it is OK for my use. All- I am capable of doing some minor soldering surgery, however in this case I haven't yet done the deal to own the mixer, so I wouldn't want to alter the Tape Out>Mic level just yet. I wish that they made this a switchable option so you could reset back to default if needed. And yes, using the less clunky mini-mini from the tape out would be nice. That cable from Trew seems to be a reasonable way to go with out altering the mixer, but as Richard pointed out, the $73.00US is a bit un-reasonable, especially since Santa brought less coal in the stocking this year than in previous years. I gave at Redco a call and discussed the Y-cable option. They can put together a cable for about $30.00, but it would not have the DC voltage blocking capacitor. Apparently that is in case of an overload, but they claim they have not heard of any problems by not using the DC voltage blocking capacitor. As far as the ground loop noise, good to know that that may only be a problem if both the camera AND the mixer are connected to the power bricks. Though the mixer has a DC in, I don't have the proper brick, so it would be running on the two 9 volts, and I'd pack lots of spares (I've read enough for three changes during the coarse of a days shoot/recording.) Best to all. Jonathan |
and one of these will convert a stereo tape output to mic level : ART Pro Audio
it will also allow you to ground lift to remove hum if required! |
You could also do a quick-n-dirty by getting the attenuator cable from Radio Shack. It would knock the FP33 line-level down to mic-level for the camera. However, it is only mono, so only good for one channel (likely the left channel). http://www.radioshack.com/product/in...ductId=2103841 For that matter, you could make (or have Redco make) an attenuating stereo 3.5mm cable. The "attenuator" consists of a pair of 25-cent resistors. The only issue being finding some place in the connector shell with enough space for the resistors. You could do it with conventional 3.5mm connectors by using 1/10th watt resistors, and putting two of them at each end. |
"The only issue being finding some place in the connector shell with enough space for the resistor"
-- Yes indeed. I usually use Canare F-11 or F-12 or other large barrel 3.5mm plug or jack for making attenuating cables. Makes it a lot easier to add resistors and caps. Canare F-11 & F-12 Mini Phone Connectors at Markertek.com |
| All times are GMT -6. The time now is 02:05 PM. |
