Seminar audio question
Hi guys,
I will be filming a seminar over the course of a week soon. The last one I did, the audio from the shotgun mic was great as the room was small and had a great sound system. Ive been told there will be an AV guy setting up mics/p.a. system for the presenters etc. My question is what is the recommended way to record the audio for this situation? I would usually use my radio lapel mic on the speaker but if he already has a lapel mic or handheld mic from the AV guy it might be too much? Also, might there be interference between my lapel mic and other peoples equipment? This interference happened to me once. I have a rode shotgun mic and a Zoom h2n recorder also. Can I hook up the Zoom directly to the AV guys gear and get a direct recording? Many thanks for advice, Brian. |
Re: Seminar audio question
I would hook up the zoom to do a direct recording but also research what radio mic transmitter they are using as you could also fire up your receiver and pick up their mic clean as well.
Sennheiser G2 are the most common types in the UK and I have done several conferences where I have just re-tuned my radio receiver to the same frequency that they are using. |
ah right I get you.
I have the sennheiser ew 100 i think it is. So, Id just ask them what frequency and tune it in. no need for my lapel mic at all, just my receiver. And the zoom as a backup recording. Thanks! |
Brian,
What I do is get a feed out of the audio guy's mixer and feed that into one of (I assume) two channels of audio. The other channel I use for either on camera or shotgun mic. That way if the audio guy knows what he is doing you get good clean audio. In a very few cases I would hook up my wireless out of his mixer and feed my camera. And if you have a digital audio recorder, I put that by the audio guy taking another feed coming out of the mixer. And then you have a completely separate system backing up the first. Get hold of the audio guy and talk. I always find out what model of audio mixer they have so I am familiar with the outputs. I always bring connectors, adapters, and cables to go from the mixer to my camera. Never assume they will have it. Good luck! James |
Thanks for that! Yes, I will keep the shotgun in channel 2 and get a wireless feed into channel one and hook up my Zoom recorder direct into his gear as a back up.
I have indeed just gotten his number and will talk to him too about this. I appreciate the heads up from you guys first. Its really cleared my head up about it all. Thanks a lot. |
+1 on everything James said.
Brian here is a link to an old thread about seminar recording. I started it as humor and sarcasm but it took off with four pages of guys contributing good stuff. http://www.dvinfo.net/forum/all-thin...audio-guy.html Working in the Corporate Ballroom environment is my specialty. Steve |
Brian, Just to say it again, I would not use the wireless unless that was the only way to get the feed. I would take the time and enough cable and hook the camera to the mixer. You never know when the audio frequency would be stepped on by something else, battery goes out, etc. Hard wired cable is much more reliable. I don't want to be try to fix things in post.
Also bring a good set of headphones and monitor the audio with the headphones the entire time. you need to be able to tell the audio guy when there is a problem that is sounding fine to the house but is screwed up in some way to you. Good recording! James |
yes, yes and yes. good advice!
Forgive my inexperience please - so youre talking just a regular xlr to xlr cable. as long as possible, from channel one on the camera into the mixer? Ive never hooked up like that before, might have to purchase one. I will try position myself close to the sound guy. Gonna contact him now. and Ive been lazy to wear headphones at times. Ill make sure to monitor them. Thanks guys. |
Why not cover all the bases by feeding ch1 on your camera with your radio mic receiver on the same frequency that they are using ch2 the camera mic and then hook up the zoom at the mixer end of things with a mix out on ch1 and a clean split of his radio mic receiver on ch2?
Ok just so Im clear -
i have channel one for my radio mic receiver set to his wireless frequency. my channel 2 is my shotgun mic. Then I get the Zoom to record in 2 channels ? on one channel, a mix of sources and the other a only the speakers lapel mic? Im not quite clear on this , sorry! Also, I liked the sound of getting an XLR cable and hooking directly into the mixer. It sounds secure. |
I've recorded hundreds of seminars for law and corporate clients, both multi-camera and audio only. A lav would work if there's only one or two presentations but if there's a panel it won't work. There's are quite few ways to audio off the house board, a main-out feed, pre and post fader aux sends, a matrix and mic splitters. any way you must bring your own cables, attenuators, DI, ISO transformers ect, Most of the outputs on house mixer will be +4dB (nominal) however some have RCAs which are usually -10dB but some Mackie's are around 0dB.
I was friendly with many of local hotels my clients used and was friendly with the A/V staff, they would allow me to use my own mixer and integrate the house feed . My usual MO was to sent the house a pre-fader mix and 'mix-to-tape' off the main linear faders, in which any moves would not affect the house mix. This is not recommended for the inexperienced, especially if there are panel discussions. |
Brian, as many here with great advise have said, Don't use a wireless! When you're able, use a cable!
Like Rick, I've done so many seminars either just audio or video that I've lost count. As a video guy recording the seminar, I want a clean feed from the audio board so I get together with the audio guy (luckily I've probably worked with him before) I pull a feed to my camera set it to channel 1 on AGC and channel 2 to manual have ALL the mics checked for levels and quality of sound then press the red button. Remember at a seminar, there might be, well any number of wireless kits going. I've done seminars where there were 12 kits set up and as many as 6 running at once. Makes it hard to find an open freq plus all the cell phones, blackberrys and othr wireless devices that while they may not be on the same or even close freqs as our wireless, they hunt for the network and BAM! Now you can get interference that can not be cleaned in post. Did I mention that most venues that can host large seminars are generally hotels or convention centers and around my area at least, they are constructed with a whole lot of steel. Also not good for wireless systems. Buy or rent if you can a few 100 foot XLR cables, put together some other connections that can work off of the XLR connections in case you can't get an XLR out and don't forget the gaffers tape to tape down your cable after it's out and tested. Wireless has it's places and I'm a big proponent of wireless but not for picking up an audio feed at a seminar. Like I said earlier, When you're able, use a cable! |
If you're able, roll your own cable.
As long as you're adding much-needed XLR cable to your kit, and you have some time and patience, why not make your own? It's a lot cheaper than buying pre-made, pretty easy to do if you still have opposable thumbs, satisfying, and you gain the knowledge for repairs (if possible) whilst in the field. My cables look every bit, and sometimes a lot better, than commercial cables. $0.04 (adjusted for currency exchange). |
My god, this forum is awesome, it never fails to impress me. As I said before Im a jack of all trades and a master of none so when Ive been landed with a job thats slightly out of my day to day expertise its great to have people give me some time.Much appreciated.
So I cant just stick any old XLR cable into the mixer and hope it works? Crud. Im awaiting a reply from the audio guy, Ive let him know my situation and the seminars not for 6 weeks. Im pretty sure that getting the seminar recorded was an afterthought of the organisers but Id still like to be as professional as possible and learn as much as I can along the way. Many thanks, Brian. |
What do you have in Ireland in the way of musical instrument, DJ, and audio equipment stores? Just walk in, grab an XLR cable off the wall, and it will likely work. Simple as that. You can run 'em many hundreds of feet with no signal degradation. When you're given, say, unbalanced RCA or some other outputs (say, from consumer equipment or a musical instrument), then you need additional kit to mate with XLR connections, but I don't think you wrote of anything suggesting that would be your case. However, if that IS your case, you'll likely need what's called a DI box. For garden variety audio work, a passive DI box should work fine: unbalanced input (of many different kinds) on one end, balanced XLR out the other end. Single or multiple channels, your choice. Super easy to use and good boxes can be had for cheap. (I paid US $120 or so for mine.) |
Thats a relief!
Im probably just being over careful. Its just that I work alone (mostly self-taught) with no training in most areas I work in and no friends or support that do what i do to show me tips and tricks. Its quite disconcerting when faced with a new project, that you dont know if it will throw up some horrible anomoly I have never heard of. I fixed the house mics at the last confrence I filmed at when noone else could, just by being techy enough to figure it out logically, even though Im no sound guy. Its reassuring to hear that the answer will probably be that I plug a female xlr in my camera and a male in the mixer and itll work, along with my other backups of course. Anyway, I have the audio guy yet to get back to me about it. Im sure we will tease it out between us before the day. I feel better now, thanks! |
Sorry to mention something else that might be obvious (but if not it will become painfully obvious): just make sure to match mixer and camera levels, i.e., line output to line input, or mic output to mic input. The audio mixer guy can probably give whatever you need (but CHECK!), so the question is what does your camera take: mic or line inputs (or either)? Feed line output into your camera set to mic input, and you're in for a noisy disaster. Mic-->line and the level will be much too low.
I have the Panny af101. I think its both mic or Line. But I will make sure to match them. thanks for that. its the little things! Thanks for thinking of it.
B |
+1 for what Steven said and I forgot to mention in my previous lengthy post....Forget about using an on board mic of any kind as a "backup" source. You'd be better off doing shorthand writing and then doing a VO to match the speakers lips moving. ;-)
I've done seminars where I'm 150 back from the stage and audio world is a good 60 to 75 feet away from me off to the side and the speakers which are set up on stands are from 50 to 100 feet away IF they have fill speakers set up. So a shotgun or hypercaroid on the camera would be a complete waste. HOWEVER, if you can set up a stand alone recorder like a Tascam DR-05, or 40 or anyother name brand from the mixer great, if not maybe a mic set up on a stand in from of one of the speakers going to the recorder if not frankly don't worry about it. Get in early enough to set up, fax everything out (do a sound/record test and play it back for you to see and hear even if only thru a small playback monitor and headphones) then do it again. Make sure. Live events, you only get to do it once. BTW just to be truthful here, in all of the live events I've done (seminars, conferences) I've never set up a secondary audio source. I trust what I've got from the board if I'm pulling from the board. IF I'm covering a smaller event and there is no board, that's a different story. First rule of seminars...Never let them see you sweat! You'll get it done. Have fun! |
One addition to Steven's post above. If you have coiled XLR cable left over on your run, don't throw the coiled cable on top of the extra coiled AC cable you may have laying under your tripod. A 60Hrtz hum sucks!
Steve |
Steven D, good catch. Yeah I've seen sound guys do that and I feel I have to say something even if I'm not pulling any audio to my camera. Audio and power, like fire and gas. Don't mix!
Steven R, yeah a 60 mHz hum in Europe could be a sign of a larger issue! :-0 I'll bet we could tell some great stories! ;-) |
I feel better now, thanks![/QUOTE] Brian, Unless you have some new fangled camera you will be plugging the male XLR into your camera. What happens on the house end is questionable, but a female XLR to male 1/4inch will usually do the trick if needed.Seminars are what I do for a living, here in the States and in Canada. The best advice I could give you is make contact early. Engage the audio people from the venue and your client in the conversation. If your client is paying for your audio feeds that's best case scenario. It will be on the spec sheet. I usually look at room diagrams if I'm traveling and request a riser and a audio feed in the best possible spot. On the day of the show get there real early (2h hr min). Make friends with the A/V guy. Test your feeds as soon as you are setup. 15 minutes to show time test again. I've never had a tested audio feed fail. Even if it does fail, a wireless wont do any good, because at that point the failed house audio will put everything on hold anyway. I say just have a couple of turnarounds and a attenuator. You should be good. |
| All times are GMT -6. The time now is 12:39 PM. |
