-   -   How does this sound 2 (https://www.dvinfo.net/forum/all-things-audio/519664-how-does-sound-2-a.html)
Kathy Smith October 26th, 2013 08:00 AM
A while ago I posted a recording and had people evaluate it (http://www.dvinfo.net/forum/all-thin...s-sound-5.html)
In that thread few things got clarified for me. 1. My wireless receiver/transmitter combo is not really up to par 2. One of my Sanken COS 11D was not functioning properly
Since then I got an adapter for my mic so I can wire it directly to the camera and I got one of my mics fixed.
In this thread I am hoping people can compare my wired recording to my wireless (I have not upgraded it YET!) and let me know if this is the expected difference or if there is still something not right with my recording. Now, please remember I am recording directly Canon C100 (not top of the line Sound Devices recorder etc). Both recordings are straight out of the camera, no post processing. I am looking for a sound that would be make people say "this sounds very nice" not "this sounds f***ing awesome" as I can't achieve that with my equipment. Also, there was noise in the room so...
Anyway, here are the recordings. Please let me know if I should be getting something better out of C100 and wired Sanken COS-11d. Thank you so much.
https://www.dropbox.com/s/ny01gmynae6pwkf/wired1.wav
https://www.dropbox.com/s/1zchh6azc4urb31/wireless1.wav
Rick Reineke October 26th, 2013 11:05 AM
Re: How does this sound 2
Both sound OK to me. The wired clip sounds cleaner and 'fuller', but a wireless track could be EQ'd and such to sound almost as good if there are no RF hits.
BTW, if you transcoded your WAVE files to single-channel mono, they would be half the size and no quality loss should occur. No big deal on local network hard drives, but on the internet, size is an issue, especially for folks with a slow connection.
Gary Nattrass October 27th, 2013 03:49 AM
Both are acceptable but the wireless sounds thinner and probably has some high pass filtering in the transmitter.
I would probably be adding some 150hz in post to both to warm them up a little but would also have a 100hz high pass filter as standard on any speech or dialogue channels.
Kathy Smith October 27th, 2013 07:51 AM
thank you.
Kathy Smith October 27th, 2013 07:52 AM
How do you apply 100hz high pass filter on dialogue channels? Do you do that in post. Where do you get the filter?
Daniel Epstein October 27th, 2013 08:20 AM
Both sound okay but may be a little overmodulated on peaks. Looking at the Manual for the camera (pages 73 to about 76) there are a few settings which could make your mic recordings sound better or worse. There is a sensitivity setting and a peak limiter setting. This might make a difference to a recording of a mic which sounds a little ragged to one which sounds smooth on the peaks.
Kathy Smith October 27th, 2013 09:11 AM
peak limiter is off and sensitivity setting is set to normal. Do you think there is a need for me to change that?
Daniel Epstein October 27th, 2013 09:29 AM
Hey Kathy,
I would play with it and see how it sounds. Maybe go down to the -6DB on sensitivity and turn on the peak limiter. When I looked at your tracks in Audacity nothing seemed to go above -6DB but it was hitting that level which is pretty hot for digital when recording from a mic.
See this note from Page 77 of the manual
Manual Audio Level Adjustment
You can set the audio level for each channel manually from -G to 18 dB.
1 Set the audio level switch of the desired channel to M.
2 Turn the corresponding dial to adjust the audio level.
• For reference, 0 corresponds to -G, 5 corresponds to 0 dB, and 10 corresponds to +18 dB.
• As a guideline, adjust the audio recording level so that the audio level meter on the screen will go to the right of the 18 dB mark (one mark right of the 20 dB mark) only occasionally.
• Closing the protective cover will prevent the audio controls from being changed inadvertently.
NOTES
• If at least one of the channels is set to manual audio level adjustment, you can also activate the audio peak limiter to prevent audio distortions. When activated, the audio peak limiter will limit the amplitude of audio input signals when they exceed -6 dBFS. Use the [¡ Audio Setup] > [Audio Input] > [Limiter] setting.
Kathy Smith October 27th, 2013 10:10 AM
Originally Posted by Daniel Epstein (Post 1818287)
Hey Kathy,
NOTES
I'll run some tests tomorrow.
What I find annoying is that I always record my levels low although in camera it seems like I am recording them pretty high and when I bring them to final cut they are usually around -20.
Gary Nattrass October 27th, 2013 05:48 PM
Some cameras have a high pass filter fitted as do location mixers and they can both help.removing LF rumble or wind buffeting noise.
You can also use them in post but if there is a risk of the mic amp overloading on location it can be good to use them there. My P2 cameras and location mixers both have 80hz high pass filters and the mixer also has 160hz for difficult high wind rumble.
Kathy Smith October 28th, 2013 09:09 AM
OK, I did a few more tests this morning.
Here is what they are:
1. Sanken COS-11D mic wired to C100, the way I normally record (peak limiter off, mic sensitivity normal)
2. Shure lav mic (not sure which one) wired to C100, the way I normally record (peak limiter off, mic sensitivity normal)
With test 1 and 2 I wanted to hear the difference between these 2 mics to see if it was worth getting the Sanken
3. Sanken COS-11D mic wired to C100, I raised the levels because I always get them low when I bring them to Final Cut (peak limiter off, mic sensitivity normal)
4. Sanken COS-11D mic wired to C100 (peak limiter on, mic sensitivity set to -6db)
All of these are straight out of the camera, no post processing
What do you guys make out of all of this?
What else can I try?
https://www.dropbox.com/s/3pxkoce8fp84c1p/1.wav
https://www.dropbox.com/s/3r2zurlu21vcrzz/2.wav
https://www.dropbox.com/s/vm4hzaj2lc4sdj7/3.wav
https://www.dropbox.com/s/lx8ku3lvaxzjufb/4.wav
Daniel Epstein October 28th, 2013 12:15 PM
Kathy,
In order of preference by listening on my system Number 4, Number 2, Number 1, Number 3, If you are looking for natural sound and smooth. Number 3 has volume but feels harsher. Number 1 seems thin but might be easier to boost in post. The Shure mic sounds pretty good at Normal settings although mic placement might change ones decision. Frankly all are acceptable although Number 3 is starting to have characteristics I would worry about.
Bruce Watson October 28th, 2013 12:20 PM
Yep. What Gary said.
Kathy Smith October 28th, 2013 12:24 PM
Originally Posted by Daniel Epstein (Post 1818396)
Kathy,
Thanks Daniel.
Is it normal to always boost levels in post?
Bruce Watson October 28th, 2013 12:25 PM
Number 4 is spot on. I wish I could get audio that clean and nice. But that would take a COS-11D which I can't afford. Sigh....
I would always run with a peak limiters at the preamps -- mixer or camera, in this case. You never know when they'll be needed. Dropping the sensitivity seems to have cleaned up what over modulation there was.
Daniel Epstein October 28th, 2013 12:57 PM
Originally Posted by Kathy Smith (Post 1818399)
Thanks Daniel.
Kathy,
it is a common occurrence to adjust audio levels in post. Normal is always a difficult thing to measure. Is the interview sound too low or the other audio too high. Field recordists are looking for a good recording without distortion not necessarily worrying about what level works for the mix. Some edit systems lower the volume of each track on the time line so the mix doesn't always reflect the initial record level. A few db can make a big difference. As long as the recording sounds clean it is usually preferable to boost it in post than to overmodulate it on the original recording.
By adding in the peak limiter the average sound can be recorded a little higher without worrying about peak distortion and you end up with a fuller sound. Of course the limiter has to sound good doing this and some don't.
Kathy Smith October 28th, 2013 01:14 PM
Thanks Bruce. Good to know about peak limiter!
Kathy Smith October 28th, 2013 01:15 PM
Originally Posted by Daniel Epstein (Post 1818404)
Kathy,
Great. Thanks a lot. So if I record everything the way #4 is recorded and then do some post production on the file that should sound pretty decent I think!
Daniel Epstein October 29th, 2013 07:47 AM
Hey Kathy,
Seems like a solid basis to start. Good thing you are testing and looking for the the best combinations of gear made by different manufacturers with tests rather than just jumping into real recordings. Of course the one thing about field production is making our decisions based upon circumstances and in real time. Be prepared to make choices about settings in the field. Monitoring how the recordings are working and making adjustments are all part of the deal.
Kathy Smith October 29th, 2013 08:05 AM
Kathy,
Thanks Daniel!
