Re: Help removing plastic bag in audio
Hacking away with the digital machete - I like that! Although RX can be a very fine-edged scalpel, but using it that way takes...a long time. I had a clip once from some conference - don't know what the intern had done with that camera - but the audio was just buried waaay down in the sputtering noise floor. Couldn't save that no matter what I did. I even took it as a learning experience and spent about a dozen hours I never billed - just to see what could be done (I was new with RX then). Sometimes there's just no way.
RX is my absolute favorite. I did a video/recording of the Tchaikovsky Piano Concerto #1 - at the entrance to the 2nd movement there is a solo pizzicato passage in the violins. One guy Pizz'ed a little late so to speak. Sounded awful. I was able to remove the errant Pizz.with RX
In the introduction, one horn was a tad late - I couldn't fix the late attack perfectly but I reduced it a lot so it wasn't quite as obvious. Great piece of software. |
I have a commercial recording of Finlandia where the tuba put a depth charge-like sforzando in the wrong place. I wonder nowadays if there wasn't the budget to do another take whether that could be fixed in post?
I often wondered whether the tuba player ended up fixed to a post :-) |
I'm a tuba player myself as a matter of fact.
If you could grab 5 - 10 seconds each side of the offending Sforzando I'd be willing to try to tone it down. Might be do-able. |
| All times are GMT -6. The time now is 06:00 AM. |
