Which mic to hang?
I am filming a musical stage production in a few days and I would like some advice about hanging a microphone from the roof. Hanging a mic is really my only option I think because I am right on top of the show, maybe as close as 8 feet and it is being staged in traverse with me and two other cameras along one side so my feeling is that there is no room to put mic(s) on stands in front of the show as it were. There is no audience. My plan is to hang one Octava 012 from the roof using the cardioid capsule. I was thinking this would be preferable to the omni capsule because then I wouldn't get any noise from behind the mic from things such as scrolling gels. Is this a good plan? The stage width is probably about 35 feet with a 4 piece live unamplified band at one end. The roof height is probably about 20 feet. I do have a matched pair of the Octavas if anybody has a different plan they think would work.
Re: Which mic to hang?
The Octavas would probably be ok for the band, but for dialog, the Octava 012 has low sensitivity/output (10mV) which would require lots of 'clean' mic preamp gain. Even with expensive mic preamps, they don't have much 'reach' to get decent sounding dialog from more than a foot or two away.. If good quality wireless lavs are not an option, I would recommend two or three boundary mics on the stage floor or choir/gooseneck type hanging from above.
I would probably start with a stereo recording with cardioids spaced about 10' on stands at the front edge of the stage or the first row of empty seats, the mics at about singer head height. This assumes the singers are singing/projecting to the missing audience, not the ceiling.
A problem could be that the band is too loud relative to the vocals. Will you have a chance to test mic positioning during rehearsal? Recording solos with the singer 15 feet from the mic can be problematic sound quality wise. Too much room effect/reverberation for starters. (Not as much of a problem with choral groups.) Any chance the singers will be miced? |
Hi Rick. The Octava would be fed into an SD722 if that makes any difference. I'm afraid wireless isn't an option and I don't own any boundary mics. I do also have an Audio Technica AT 8033 omni. Would that be a better bet to hang? I know its a very cheap mic so I assumed the Octava would give a better result but perhaps not.
Apart from the AT omni which I have used for a show into a Zoom H4n with results that pleased the client if not me all my equipment is going into use for the first time hence my questions. I'm definitely in the dark here. I suppose it comes down to what is acceptable sound which is a big unknown right now. Are you saying that they might not even be heard if they are say 20 feet from the Octava in the roof? Hi Dan. My preference would be to do as you say and set up a stereo pair. I confess I'm a little afraid of it and thought a hanging mic would be a safer option given that I am very green at all this. Perhaps I should put my anxiety to one side and go for it! I am hoping to be able to test the positioning and levels. I too am worried about the band being too loud. This was a problem in the last show I did. I had to set the levels, this was on a Zoom H4n, to accommodate the band which meant I had to bring up ALL the dialogue in post. I'm recording to a 722 now but obviously that problem remains. I have no idea what I can do about that apart from deal with it in post as before.. The singers won't be miced. Thank you both so much for your advice. Its really appreciated. |
Hi Dan. How would you aim the mics in this configuration. Straight ahead as a sort of very wide A-B technique or as a kind of crossed pair so to speak? Apologies for my ignorance. |
Patric,
I am a bit confused about the set up. When a full performance is done without an audience the point is usually to play "to" the cameras. Why are you stuck in the wings? Are the other two cameras part of your crew so you have options there too? If not your crew are they friendlies you have worked with before? You could put a solution together for all of you and each take a feed from it? If you hang octavas and one of them is using boundary mics it would sure be nice for both of you to have each others track? You have a SD733 and a Zoom H4n to work with here..... |
It also sounds as if you will not have anyone attending to the audio. That really just leaves what you get up to chance, especially with just one mic hung over the stage. If you could hang at least one over each side, that would help as actors move around or actors from different sides of the stage speak or sing. With an audio person, they could bring up the closest mic while turning down the farther one. They could also adjust levels for the dialog vs. when there is music. Still not perfect, but better than one "set and forget" mic. Good Luck! Rob |
Straight ahead should be OK.as a starting point
The larger question is what is the intended purpose/use/distribution of this recording. That will drive the importance of getting it right vs. getting it "good enough." The question is what type of performance w/o an audience was already asked, sounds like a dress rehearsal of a school or amateur group. If the band is too loud, can it be moved; e.g., for this performance could it play in the audience areas or where the PIT would be in a typical theater? As the mic moves further from the sound source (vocalist) the ratio of direct sound (from the singer) to indirect sound (echo/reverb) decreases, and the portion of other sound (e.g.. room, HVAC, digestive noises) increases. These all can detract from the recorded audio. If there is no budget, no additional gear, and no staff, you have to do what you can with what you've got. |
Hi Steven. It is a dress rehearsal but its not specifically being done for video so they won't be playing to the cameras. It is just their last dress rehearsal before actual performance. I am photographing their first dress earlier that day and the videoing the next so I will get to see it before I video it. It is being done as a test to see what we can achieve and gauge the interest throughout the college.
Sorry if I have confused you. We aren't in the wings. the show is being staged in traverse: Traverse stage - Wikipedia, the free encyclopedia The other two cameras are working with me. We will be set up along one of the long sides of the staging which will be a rectangle. Its only me who has any mics! so we are limited to two Octavas, an AT omni and a Rode NTG3. I am a bit time limited and my two assistants have zero knowledge about setting this kind of stuff up so I am on my own. I'm thinking about Dons suggestion of spaced cardioids for stereo recording but I'm not sure which mic technique would be the most suitable. Thank you very much for taking the time to respond. Its incredibly helpful. I suspect I'll be adding to my collection of mics fairly shortly. |
Thanks for your advice. Much appreciated. |
OK, this picture is coming together. You have two dress rehearsals to work with. You will be using the DSLR for stills at the first one. This is what I would be thinking.....continuity! Rehearsals were my best friend when I shot live productions. I always got great cover footage and b-roll for post. In your case you are going to be lucky if you end up with one complete scene well recorded since you won't be covering the real show. Even if the director told me he was going to let them roll through the last dress I never met one who could do it. There is always interruptions.
If you are serious about this I would record the audio and have static cameras rolling at the first one while you get your stills. Then do the best you can at the second and know you are going into post with a lot of work to do! Good Luck! Steve |
Hi Steven. I can't video the first one because I need my three Nikon D4s to photograph it. I wish I had six! I will be videoing them on the same DSLRs later. It is also a musical so cutting between two performances of one song could be problematic although yes I would video it if I could.
I am going to record sound on the first one although I cannot monitor it at all just to give me some information for recording the second rehearsal. Plus one of my assistants will be there during the first one and she will do some video testing with my Nikon D800 partly to try and make some notes about exposure etc but also its a way for me to find out how well the D800 footage would cut into the D4 footage in the future. Not that well I suspect. This is actually a test and the staff know that so if the show does get interrupted then so be it. In that case I will cut together a trailer for the show or something. The important thing for now is to see how good I can make it look and sound. Their benchmark up to now has been a locked off single camera with a mic on top of it halfway up an auditorium. I'm confident I can do better than that. Thanks very much for responding. Patrick. |
Since they're playing the show in traverse, and you have a limited selection of mics, I think you have only one choice. This is dictated by the fact that half the time the players are playing toward one side (stage left?) and half the time they are playing toward the other side (stage right?). If you put your mic (or mics) on one side of the stage only, then half the time the actors will be playing with their backs to the mic(s) and the recording will be really bad.
Given all the above, I would hang one mic on each side of the stage, roughly the same elevation as the heads of the cast. Do NOT mix the mics. Record each mic on a separate channel. Then, in post, switch between mics, always taking the mic which the speaking actors are facing. You will end up with a mono recording, but at least you won't have to deal with dialog that's muffled because the mic is behind the actor. Distance will be difficult to predict. If you're too close to the stage, then as the actors walk up and down stage, their distance to the mic will change drastically, and the levels will change accordingly. You can somewhat fix this in post. OTOH, if you're too far from the stage, everything will become indistinct because of all the reflections from the hall. (Reflections probably will be quite bad, since the house will be empty, with no audience to absorb any of the sound.) I think that, with luck, you might end up with something that is useful for archival purposes, to analyze actors' diction and expression, etc. I think there's little or no chance you will end up with anything that is really pleasing to listen to. The end result might be OK for family and friends to listen to, as a keepsake. I think it's unlikely that anybody would want to listen to the entire recording for its own sake. And you will have a lot of work to do in post, constantly switching back and forth between mics, and riding gain, as the actors play to one side of the stage and then the other and move up- and down-stage. Good luck. |
+1 on everything Greg said. He nailed it.
Traverse stage and three cameras....I would have one of the cameras on the opposite side even if it was a wide lock down. But you probably have a reason for placing them all with you. Steve |
The stage is so narrow that a camera on the other side will just see the other two cameras and also all the production desk garbage which I am planning to have behind me.
I think in the end I can get something they like but either way it will be a learning experience for everybody and the college appreciate that which is good Best wishes. Patrick |
If you drape the front of the cameras, tripods, etc. with Duvatyne, and the cameramen wear black, they should be barely visible since they will be outside the range of the stage lighting. (I'm assuming this is a true dress rehearsal, and they're running the lighting cues by the book, not rehearsing under work lights.)
If you position two cameras on the side opposite the production desk, and they are separated by a reasonable distance (maybe 1/4 the width of the stage), then when they are following the action, at any given time they would not BOTH have the prod desk in frame, so just use the shot without the desk. And unless the cameras are up on platforms, they will be shooting somewhat upward from horizontal if they are zoomed in on the key actors. That should help eliminate clutter from the frame. Besides, we've already conceded that the audio is archival quality, not "DVD release" quality. Why not just accept the fact that you are also producing archival quality video, and occasionally you will see some of the house as well as the stage. (After all, that's what the audience sees in a Traverse production ... they are always seeing the other half of the audience on the other side of the stage.) Wouldn't it be better to see the front of the actor who's speaking, even if there is a bit of dark clutter in the BG, rather than just see the back of the actor? It seems to me you have unrealistic expectations about this production, and you are creating unrealistic constraints, and as a result you will end up with result that's needlessly limited. |
+1 again Greg
That advice came from a guy that knows what Duvatyne and "show blacks" are! I would take it ;) Patrick, he is telling you the truth as he sees it. We are a reasonably friendly crowd here at DVINFO. I see you have not been here for a long time, so welcome! Steve |
Until I get there I don't know about entrances and exits off stage. It may be possible to put one camera more at one end and keep it really tight. I'll just have to see. From my previous experience of this space I doubt that would work but I'm definitely going in there on the day with an open mind. The cameras may be able to shoot up to the actors a little but the grid in this space is very very ugly with some low hanging fluorescent tubes that are the spaces work lights. They won't be on obviously but its all very visible in shots if you tilt up too much but I do like the idea of being slightly underneath them. The wall on the other side from the production desk will be black and clear of anything. You may be right Greg that I have unrealistic expectations especially given the type of staging which probably couldn't be any more challenging but this is a test and everybody involves knows this so it will be considered with that in mind. Thank you for all your advice. I really appreciate it. |
My background is that I have worked in theatre for over thirty years as an actor, then as touring crew for an international ballet company and the last 20 years as a theatre photographer. Video is getting used more and more and I am getting increasingly involved in that side. Thank you for the welcome Steve. Best wishes. Patrick. |
Hi Steven,
Thanks for your kind words; and a "welcome" from me, as well. Since you mention your background as touring crew with a ballet company, I'll just mention that I was sound man for Joffrey Ballet on their 1974 U.S.S.R. tour. Lots of memories there, both joyful and painful. (Trust me: canvas-covered soviet army trucks are less than ideal for hauling theatrical sets and electrics during snowy season!) I didn't realize your present space is so small and that your production desk is so big. Certainly you know the space better than I do. It sounds as if you are forced to shoot rather close and wide, which exacerbates the difficulties. If my suggestions are really unworkable in that space, then so be it. Like you, I had also pondered having one of the cameras at the (downstage) end of the platform. One dreams of having three remote PTZ cameras, fully draped in black, with only the lens visible from across the stage ... oh, well. You're right, it does sound like an extremely challenging space. If you are used to shooting stills in this space, then retouching to make them look "picture perfect," I can understand your instinctive desire to have "Beeb quality" videos of the performance. Keep an open mind, and good luck with it! |
Thanks Greg. I worked for English National Ballet for years and then shot stills for them for years. I'm trying to think if I ever worked on Joffrey at Sadlers Wells in London. I don't think I did. Memoery is a bit hazy now. It would have been mid eighties. Its hard enough touring shows in proper semis/artics never mind in Soviet era military trucks. I was told that a long time ago Opera and ballet in Britain at least used to be toured on the train. Imagine all the loads and unloads onto trucks at either end. No thanks.
I'm sure this video is going to be very challenging but I've got to see what I can achieve. I have another one in May which is proscenium arch but miked up with wireless so I'll have a whole new set of challenges there. Thank you ever so much for taking the time to respond. I really appreciate it. If its worth it I may come back and post a link to it and then duck for cover:-) Thanks again. Best wishes. Patrick. |
Perhaps consider setting up all four mics, spaced to cover the full stage. the omin perhaps midstage, and the band on the back side of one of the cardioids (to reduce its apparent volume). if you can get a 4-track recorder (e.g., TASCAM DR-70D, one channel for each mic) that would be great. Use the warm-up time before the run-through to set levels to avoid clipping, use the limiter. And have fun mixing in post.
And be sure to record full audio for each show. Mixing separate takes mid number may or may not be problematic. Lip sync being a potential major issue, but even that can be time-warped in post to being "close enough" for many purposes |
Many thanks Don. I have run out of time to source more equipment such as a DR70D as the show is this coming Monday. I do have a Sound Devices 552 which has a built in recorder so along with the 722 I do effectively have four tracks although the dynamic range of the 552 isn't as good as the 722 but I'm sure I wouldn't notice. I confess though I am very new to this having done three shows before pretty successfully but only using a Zoom H4n and a single hanging mic. The staging of all of these was very straight forward and didn't present these challenges. So all this equipment is new to me so setting all this up with four mics in the time I have with my pretty basic knowledge and experience would probably be enough to panic me:-) Definitely in the future I will consider these options though. I am going to record the first show as you suggest if only to get information about levels. I cannot monitor it during the first one because I will be shooting stills but I will definitely be monitoring the second.
Thank you very much for all your help. I really appreciate it. Best wishes. Patrick. |
I spend virtually all my video time tin theatre, and have done for years. A few thing leap out of this production and ring very big 'Danger, Will Robinson' bells.
First question is - what is the purpose of the video? To provide evidence for grading/ Archive purposes? Promotion? Sell-through? Musical theatre in traverse is fraught with problems of all kinds - the killer problem is lighting, because to light faces from both sides mean they will also hit the lenses of your cameras, unless you get them up high, and look down. Blocking in traverse, with students inevitably means real blocking of sight lines. With traverse, there is no fixed 'playing point' - the actors are effectively playing to themselves, not an audience. Your sound is going to be pretty awful. with them attempting to play multiple directions, they will not be heard, unless the venue has amazing acoustics or they are all miked up. What are you going to do if the music is too loud, which it probably will be. Real musicians or tracks? This kind of show takes real planning for the video. You may also want to consider covering your rear too - remember that if they are doing a proper musical, rather than a self-derived performance, that the license they have taken out will specifically ban any audio or video recording, it's a contract condition, and if you don't work for them, and are in effect, a contractor, then it could be you who takes the flack if somebody in all innocence puts it on youtube! This happens quite often. The usual solution is for you to email (for evidence) them asking a few general questions and just ask them if they've cleared the copyright. Mic wise - I'd use PCCs all around the playing area, because flown mics often perform more like omni, and feature lots of feet, and little voice, as nobody projects upwards. If you are hoping for a set and forget audio system, I suspect you'll be a bit disappointed. I think you'll probably end up with something that may well serve an evidence function, but you are going to struggle with the audio - especially when people sing. With amateur performers the range of ability and performance rarely compliments promenade, traverse or in-the-round. From the video perspective, cameras on both sides also cut together horribly because of the constant crossing the line shift between left and right directions. There's little you can do about it, but it's uncomfortable to watch. It will be fun, and a 'learning experience'. The teachers have picked something very unusual. After all, the pro's very rarely do musical theatre in this format because it's just nothing but trouble, from every technical perspective. Just a thought? They don't have a recording studio do they? If so, could they record multitrack stems you could then sort out in post and dub over. |
Hi Paul. Thanks for responding.
The purpose of the video is a test to see what can be achieved over and above a single locked camera with a mic on top. Ideally it could be an archive and used as promotion. Given that it is traverse mostly this is going to be a test in damage limitation. I realise its about the worst possible scenario to video. The space is very small so I'm sure we will hear everybody but clearly not in any quality fashion. It is a live unamplified foursome at one end of the traverse. One instrument is a grand piano I understand. All the content is original so their are no rights issues. They are MA musical theatre students. Their stuff is never videoed in any meaningful manner hence this experiment. Their singing will be up to it I'm sure of that. Unfortunately I don't have any pzm mics and the gig is this coming Monday so impossible to rent anything. I am stuck with basically my two Octavas with whatever capsule I put on. I guess given what you said it won't make any difference whether its an omni or cardioid capsule? Regarding crossing the line, I agree and I'm not entirely sure that I will have cameras on both sides. Mondays gig is basically probably going to be a wash out so I think I might as well test other things camera and audio wise while I'm doing it so that when the next test comes round in May I have a bit more experience. Having said that the May test is pros arch and wireless mics so very different and probably mean taking a feed from the sound desk. I'll worry about that in May! As you say it will be a learning experience which is how I'm looking at it now. A recording studio is out of the question for this particular test. There has been a lot of talk about PZMs. I'm assuming a PCC is the same thing. It sounds like a few of those would be a very worthwhile investment if this develops. Would you have a recomendation? Bear in mind my equipment right now is a Sound Devices 552 mixer and a Sound Devices 722 recorder so at the moment I would be limited to 5 inputs. I'm not sure this would ever go far enough to justify more outlay in that direction but who knows! I really appreciate the time you have taken to respond Paul. Many thanks. Patrick. |
"There has been a lot of talk about PZMs. I'm assuming a PCC is the same thing."
Sort of.. PZM, (Pressure Zone Microphone) is a trademarked name by Crown, for their line of boundary type plate mics. I once used a pair of Crown PCC-160s taped to the underside of a grand piano's lid which absolutely had to be closed for sight lines. Sounded pretty good. photo: UCC Synod 24, Minneaplis, MN |
Thanks for clarifying that Rick. Much appreciated. Nice tape job on the piano!
Regards. Patrick. |
PZMs are omni above the horizontal plane, whereas PCCs, are cardioids - the most common still being the Crown series. The designer Bruce Bartlett makes a number himself now. Damn good devices.
Flown cardioid mics can be aimed, with bits of wire to create the angle, but the cables often take a day or two to stretch out and up till then rotate as the cable settles. Hanging them downwards just creates an omni pattern below, with the null up towards the ceiling. Small scale musical theatre with just a piano may well be doable without too much grief, but absolutely NOT on the camera. The last thing you want is the balance changing as you pan left to right. |
Well....I ended up with an Octava on a stand on opposite sides to each other with the cardioid capsule. I had plenty of time to set levels in the morning. I couldn't actually monitor it during the show but I will make sure I can next time. I listened to it in its entirety today and to me it sounds pretty good. When the band and singers are at full loudness you can hear a little bit of hardness from the room acoustics occasionally. It could be mic colouration but I have nothing to compare it too but overall i,m calling it a success. Interestingly, the guy who runs the sound for theatre course came in to say hello. He had been in New York with a broken email so was unable to help me leading up to it but he actually suggested I could have hung the two mics which was my original plan sort of. He was basing that on my only having the two mics available. I had already set up and set levels and didn't have enough time to change. It would have avoided picking up the director talking as he decided to sit near the mic at one point so next time....
I had decided ahead of time that we weren't going to get a full video of the show because there were just too many issues that couldn't be resolved. That's what testing is for I suppose! My plan now is to choose one of the songs and have a montage of footage from the show behind it. Obviously I will have to avoid footage of people actually singing but there is plenty of footage to cover one song. The head of the course is very excited by the possibilities so hopefully I can deliver. Ive got a lot of lessons to learn from it to take to the next one. I want to thank again everybody who was so helpful with all their advice. Although I went round in circles a few times it definitely helped me to better understand what I was going to face. |
| All times are GMT -6. The time now is 01:36 AM. |
