-   -   Noisy Canon C70? (https://www.dvinfo.net/forum/all-things-audio/539762-noisy-canon-c70.html)
Kathy Smith August 3rd, 2026 10:04 AM
Noisy Canon C70?
I know C70 has a noisy preamp but I don't know if my C70 has faulty preamp or this is a normal noise level. Can someone verify for me? I'm attaching a file.
Some info:
1. Firmware 1.1.3.1
2. No mic attached
3. vol level set to 5, Manual
4. audio input selection set to INPUT TERMINALS Input1 MIC+48 for both channels.
5. No fan running while recording
https://www.dropbox.com/scl/fi/rqhdt...11rkb9sj1&dl=0
Allan Black August 3rd, 2026 01:08 PM
Re: Noisy Canon C70?
Hi Kathy, I don’t have a Canon C70 but I set an average music level playback level on my latest iPad and listened to your noise sample. It sounded Ok to me, another example might be to have someone speak at normal level and record her/him at ‘normal’ level on your C70 and listen for the background noise on that example so you’ve got a reference. Is your firmware the latest version?
This might help you with your audio settings and check the comments …
And you should look around the web, there’s C70 groups. Don’t forget to let us what results you get, to help others here in future. Good luck.
Kathy Smith August 5th, 2026 07:33 AM
This might help you with your audio settings and check the comments … https://youtu.be/3er6pnJ_8Dc
Thanks Allan. I watched the video and I understand all the settings. I also reset camera to factory settings for testing purpose, but I get the same noise with factory settings. I'm on the latest firmware. The thing is I just feel like it's more noisy than it used to be. I just checked my files from 2 years ago and it's the same noise level, so maybe I'm imagining it. But I have no way of verifying my settings from 2 years ago and what my volume level was etc. The puzzling thing is that when I have no mics attached I wouldn't expect to have an audio recorded but when I drop my files to Final Cut, I do have a audio track and it's just noise. I can obviously delete it but I don't remember ever needing to do that. Maybe I need to find C70 forums and post there.
Allan Black August 6th, 2026 03:51 AM
Hi Kathy niggles with gear you can’t seem to solve can drive you crazy after a while, and yes with audio noise you might be imagining it unless you’ve got the gear that can actually measure it.
You might have seen these, to avoid audio channel noise have you ensured your phantom power is turned off if your microphone does not need it. Dynamic mics and many modern units do not use it. And be aware that the camera's fan can introduce noise. Set the fan mode to automatic to minimize this during recording.
There’s the C70 community forum …
https://community.usa.canon.com/t5/P...p-2/m-p/513546
Kathy Smith August 6th, 2026 06:36 AM
Yes, I tested the noise with phantom power and without. I have the camera set to turn off the fan while recording.
Thanks for the forum link, I posted my query there.
Pete Cofrancesco August 6th, 2026 09:00 AM
Dedicated audio recorders and mixers will always outperform cameras. So you are free to upgrade to the many audio devices offered today.
Outside of that I’ve found people on message boards tend to obsess over things the client isn’t complaining about. While you might hear noise in silence sections there are audio noise software filters to clean this up. In a normal interview preamp noise will not be heard if you’re getting proper levels from a well placed mic. Usual the audio issues of the acoustics and noise of the location will far outweigh noise of the camera’s amps.
I also can’t stress enough how important mic placement is. If it’s too far away from the subject when you turn up the gain it will raise the noise floor and bring out any defects in your audio chain.
Paul R Johnson August 7th, 2026 12:48 AM
We can’t tell the noise level without a reference. The noise could be loud or quiet, but where is the maximum? Even plugging a mic in and going one two at your usual level, then pull the plug out. I may have been listening too loud? It sounds noisy, but what actual level is the noise? Has it been squished or compressed? I suspect you just set the input to 5 and pressed record? What is 10 like or 2? We don’t have a reference
Kathy Smith August 7th, 2026 05:18 PM
Hi Paul,
Yes I just set the input to 5 and pressed record.
Here are the reference files:
Level 2: https://www.dropbox.com/scl/fi/a7qa4...m6d3l9net&dl=0
Level 5: https://www.dropbox.com/scl/fi/5lelj...z7f9ylo6e&dl=0
Level 10: https://www.dropbox.com/scl/fi/a3te4...bvu2xm8rt&dl=0
Christopher Young August 11th, 2026 01:01 AM
1 Attachment(s)
Some info:
1. Firmware 1.1.3.1
2. No mic attached
I had a look and listen, Kathy.
In iZotope RX that audio is modulating between -57 and -54 and the wafeform is looking like it is active and possibly has an auto gain function going on. -60 is generally considered a good noise floor.
I am not saying that what I am outlining below is your answer but do some checking on the following.
I think you may find if you kill channels #3 and #4 to ∞. In other words set them to MANUAL and then set their Gain Levels to 0dB, which is Infinity, then you may solve the problem. I know this works for some Sony cameras. I have never tried it on a C70.
Often by default these channels #3 and #4 are set to internal mic and are set to AUTO. Even though there may be no ambient sound across these circuits they remain active and are searching automatically, looking for input sound levels. If they are doing that, they are auto gaining and this can lift sound floor noise levels.
Have a look at page #101 of the C70 owners manual.
Good luck!
Chris Young
Rick Reineke August 18th, 2026 10:46 AM
FWIW, the unloaded noise floor numbers of Kathy's files are . (to the nearest whole number) which do not look too bad.
Level 2: -90 dBFS
Level 5: -60 dBFS
Level 10: -40 dBFS
A high sensitivity mic is a good idea which requires less gain. Proper mic placement usually requires less gain as well. The Audio Technica 40 series mics has very high sensitivity.
The AT 4071a long shotgun sensitivity spec is a whopping (89 mV) re 1V at 1 Pa
The AT 4073a short shotgun is (71 mV)
However, the Max SPL dB for both are in the mid 120s
Kathy Smith August 19th, 2026 11:50 AM
1 Attachment(s)
Good luck!
Chris Young
Hi Christopher,
Thanks for looking into this for me. My channels 3 and 4 are not active at all.
Kathy Smith August 19th, 2026 11:54 AM
Level 2: -90 dBFS
Level 5: -60 dBFS
Level 10: -40 dBFS
Thanks, Rick. I'm using Sanken COS-11D mics.
Rick Reineke August 20th, 2026 09:46 AM
"I'm using Sanken COS-11D mics"
- Wireless or with a XLR adaptor/power supply (Battery or Phantom Pwr?
Kathy Smith August 20th, 2026 05:27 PM
XLR, phantom powered.
Kathy Smith August 22nd, 2026 02:52 PM
Level 2: -90 dBFS
Level 5: -60 dBFS
Level 10: -40 dBFS
What confuses me is that if I don't have mics plugged in, why turning the gain up and down make a difference?
