-   -   What is a normal noise floor indoors? (https://www.dvinfo.net/forum/all-things-audio/79396-what-normal-noise-floor-indoors.html)
Emre Safak November 11th, 2006 04:33 PM
I am trying to find a way to make my DVDs sound better, by which I mean to bring clarity to the dialog. I studied some commercial DVDs, and realized that the dialog is always clear no matter how quiet the actors are talking. On my projects, by contrast, sometimes it is difficult to hear the actors when they are shouting, due to noise. Usually this is beyond my control, but I do my best. I judiciously apply noise reduction, but I still can not avoid noise without grotesquely distorting the character of the speech.
Just to put it into numbers, I took some statistics from a kitchen scene. The RMS value of the noise floor is -32dB, whereas the dialog is -19dB (maxing out -0.87dB). In other words, the noise floor is 13dB below the dialog. Is this an acceptable value, or am I shooting in especially bad conditions? I just listen to it and it sounds amateurish, unclear, and I find myself helpless. I considered gating out the noise but that makes the remaining dialog sound noisy. Maybe I should gate out just some of it?
Greg Boston November 11th, 2006 05:19 PM
Emre, in those DVD's you were looking at, they use ADR. The actors watch themselves on a monitor in a studio and re-record their lines. Then they use foley to re-create and enhance the environment the actor was in and mix it all together.
That's just a basic explanation, but you get the idea.
-gb-
Emre Safak November 11th, 2006 06:17 PM
So they do ADR, as a rule, when shooting in uncontrolled environments?
Ty Ford November 11th, 2006 07:29 PM
Some films use ADR, but if you're regularly having that little distance between the noise floor and the dialog, something is not right. What sort of noise are you encountering?
Ty Ford
Emre Safak November 11th, 2006 08:04 PM
Just the city hum.
Steve Leverich November 11th, 2006 09:16 PM
If it's something that could work for you, I get a LOT less room tone/outside noise interference using a Sennheiser G2 with a Tram directional lav - haven't actually measured the diff, but seems like at least 6-8 dB, maybe more. This is true whether using in-camera mic or Rode Video mic or AT 897... Steve
Ty Ford November 11th, 2006 10:06 PM
Originally Posted by Emre Safak
Just the city hum.
get the mic closer to the talent. it should be no more than 2 feet and preferrably within 18 inches of the mouth.
Your mic is OK, but there are better ones; Sanken CS3e shotgun and cmc641 for supercardioid.
Even in exteriors, the Schoeps can be better if the environment is noisy from many directions because it is more directional than a shotgun.
Regards,
Ty Ford
