Sound Devices 702
I just received my Sound Devices 702 ENG recorder. After owning a couple of field recorders from Tascam and Fostex, I gotta say I don't know why I wasted my money on those other recorders. The 702 is a true gem, albeit a bit expensive, but, well worth the cost. I'm not too familiar with syncing a video camera with an external recorder, other than using a clapboard.
Is there any easy way to sync the black burst signal from the composite video output to a word clock on the audio recorder? |
the 702. i decided that the 702T doesn't help my syncing by adding a timecode unless i could sync the audio recorder timecode simultaneously with the cam. the clapper technique works fine and the streams stay in sync very well. since the 7 series recorders are 1394 aware, seems like the 702 software could incorporate a "record" signal from the camera
Thanx for your help |
yeah, ultimately, that's the method I use to sync the two together. not really a bad approach, except for the time it takes to cue up the video and audio streams, sync the head, then the tails. I wanted to find a more automated method, but, it seems it's not to be had, at least not inexpensively. I think what I'll do is feed my external audio recorder thru the cam. then I can sync the waveforms from the two audio streams.
Steve...
thanx. I had assumed the audio out would be a pass-thru, not a real compressed/uncompressed version. I like your idea with the mixer, think I'll give that a try. I, usually, mix the signal from the musician's soundboard in my own mixer anyway. in fact, maybe what i want to do is run the feed from the kick drum thru an aux send into my camera. That's a pretty good beat signal. |
The option of running from recorder to camera probably exists. I've got a 744T, but I imagine that the 702 has a tape out jack or some other out that you could run to the camera. Steve's concerns are valid about not getting the camera anywhere near your path for recording decent audio, but once you've got it, having a reference on the camera doesn't hurt.
Hey Bill, I notice you're up in Santa Fe. Always nice to see a fellow New Mexican on the boards. |
Wow, it really is a small world. I did a shoot over at Sandia High just last year as part of a PSA on truancy. It's still there :)
sheesh...great to hear all you folks here in ABQ. I live in Sfe but work in ABQ. At least, that's tru today. Yesterday, I spent the day playing with my 702.....what a great snowstorm, huh?
I recorded Chris Dracup over at a place on central with a Fostex MR8. The dynamic range of a 16 bit recorder just kept clipping the peaks or swallowing the lows. Did a disservice to some very good jazz. I think this 24 bit recorder oughta help that prob. ...yep, could connect the headphone out to the camera...funny I didn't think of that....course, I'd want to monitor A/B not A/Bm....LOL |
I wish i can afford the SD702. Right now i just have to settle with the Tascam P-2 :(
| All times are GMT -6. The time now is 04:23 PM. |
