booming without a boom op
Sorry if this subject is an old one, but just wanted some advice on using a boom pole/shotgun mic with a c-stand? Of course, my subject will be stationary, and outdoors.
If there's a previous thread to this, please let me know. Appreciate any and all help, thanks! --JA |
Make sure the boom is set to 'tighten' by gravity, put sandbags on the legs, get the boom as close as possible to your subject in the shot. (Don't overlook booming from below if the location and shot calls for it.)
That's pretty much it. Depending on how long the boom is, you might want to sandbag the opposite end of the boom pole for balance. And yeah, if you can run a lav in the other channel, do it. I've done this on numerous 'one man band' interviews. Good luck. |
from above, make sure the path of the mike is past the mouth and into the chest...this will help round out the sound and the body will dampen the environmental sounds as well as provide the chest cavity rumble that we all equate with "Big" sound.
from below, past mouth and into the head...sky will provide the lack of noise for you that the body/ground would booming from above. make sure the third foot of the stand is pointing the direction of the boom and sandbag. http://www.tyford.com has a clip in his archives about using a fishing pole holder in a grip stand to hold a boom pole :) |
If your using a hyper-caroid mic, also look at what the mic is pointing at. If its pointing up, make usre there isn't a ceiling fan running where its looking. Or, a Fridge sitting a couple feet away right in the line of fire, etc etc....
It's easy for the ear to miss this on set, but the mic won't.... Once you've set up put on headphones and listen to what the mic is recording before you add the actors in. cheers geo |
Thanks for everyone's input!
I'm not quite a "one-man band", more like husband and wife team. But since she's going to be conducting the interviews, it'd be real tricky boom op-ing, monitoring sound, and asking questions at the same time (I'm hauling around the XL2). Sandbags will definitely be used! And yes, Ty Ford has excellent sound advice. We're also considering buying a wireless lav system to accompany our AT897 shotgun. If we end up getting into a run and gun situation, I think the lav maybe the best way to go (instead of carrying a heavy c-stand :) --JA |
Jeff,
Check out the "avenger" stand on wheels. Also get a grip head and something to mount the pole on the grip head. Lock down the wheels, and the grip head (once you've got everything situated), and you're in business. A friend of mine (local sound guy) fabricated a wooden plate that slides down into the grip head. He bolted a fishing pole holder on the wooden piece, so the pole is supported, but can be angled up or down(by loosening thenretightenin the grip head). Works great. Bruce S. yarock www.yarock.com |
Thanks for the advice Bruce!
BTW, I was going to email you about several audio set ups and such; I guess expect one soon :) --JA |
Thanks Cole. Ty |
Hey Ty,
is yours also an "Eric Toline" special? maybe he should start manufacturing soon. Bruce Yarock www.yarock.com |
I do have the Eric Toline #001. Available at better fishing supply stores. :)
Regards, Ty Ford |
Stationary Boom Configuration
Hi Jeff,
I use a Octava MK012A mic - here's the configuration I use to go with it (from B&H Video - you may want a longer boom and the Windjammer & BBG isn't critical unless you might be outside with wind noise): MAHWH2.5 Hollywood Grip Head - 2-1/2" GBBPH Boom Pole Holder K-Tek KE-79CC - Aluminum Avalon Series Boompole with Coiled Cable RYBBGWJ Windjammer for Baby Ball Gag Windshield RYBBG22 Baby Ball Gag Windshield Good luck, Michael |
"I use a Octava MK012A mic - here's the configuration I use to go with it (from B&H Video - you may want a longer boom and the Windjammer & BBG isn't critical unless you might be outside with wind noise):"
Even inside you can't really swing a MC012 or MK012 on a boom without some sort of wind protection or you'll ruffle the diaphragm. Regards, Ty Ford |
| All times are GMT -6. The time now is 11:40 AM. |
