Sony Wireless Mic TO cable
I have a SONY Wireless UWP-C1 that I use with an ECM-77 BMP - http://www.bhphotovideo.com/bnh/cont...ughType=search
The ECM-77 has a 1/8" Locking Mini-Plug to connect to the UWP unit. I would like to "transform" it on a cable mic. I need an adapter (with power) similar to the Sony DC-78 - http://www.bhphotovideo.com/bnh/cont...ughType=search This one in ONLY for mic's with SMC9-4p Connection. Not the mini-plug. Does anyone know if this adapter exists? (if we need it, someone should have already made one ... ...) Sincerely Carlos |
Carlos, I have that kit and thought of doing the same, but I couldn't find an accessory to provide the ECM77s power.
I'm thinking that a simple 3.5mm to XLR cable should do.
The 48V phantom will be provided by the Z1 camera. I'm affraid of damaging the mic if it does not support the phantom power, not sure on this. |
Look on this url, about the middle of page 7 in the specs http://bssc.sel.sony.com/Broadcastan...s/ecm77(2).pdf |
Call one of the companies that does sound for a living like Trew Audio or Location Sound. They can set you up with something that you can be sure will work for you.
| All times are GMT -6. The time now is 10:34 AM. |
