condenser madness!
Hi all!
I've been messing around with condenser lenses for some time. I just wonder if anyone has been experiencing the condenser to be working fine from a distance, ( evenly bright ) but once you put it in front of your camera, a hotspot appears, within the 36x26 area. I tried with a smaller condenser lens, and it didn't have this problem. Nice and bright all the way, but too small to use though .. So I was thinking, it might be the focal length it all comes down to, the shorter you get, the brighter, but after searching through the threads here at dvinfo.net, it has been said that the focal lenght isn't an issue. Can someone help me with this? I'm kind of lost. PS: Small lens: 30 mm dia, 40 focal length Big lens: 50mm dia, 80 focal lenght |
I think the camcorder (not sure what part - mabe the CCD :) ) has to be in the focal plane of the condenser. So yes, the distance between the condenser and the lens DOES matter.
Hi Martin,
It looks like you're actually asking two different questions with your post. Quote:
This all sounds like a rock-and-a-hard-spot situation, but there is an answer. If you stack two long focal length lenses in sequence, you will produce the less distorted image with better diffusion. I have a feeling that my explanation isn't up to par. Page 4 and page 5 on Topcontechnotes webpage provide very good information on exactly what you're asking. |
Wow, thanks alot guys!! I really appriciate your help!!
And, yes Nicholi, two condensers in sequence did the trick!! .. Nice and even! :) Thank God for this forum! :) |
<<<-- Originally posted by Nicholi Brossia : Hi Martin,
This all sounds like a rock-and-a-hard-spot situation, but there is an answer. If you stack two long focal length lenses in sequence, you will produce the less distorted image with better diffusion. -->>> So something like two 50.8MM X 76 FL in sequence is a good solution? I found that lens available here: http://www.edmundoptics.com/onlinecatalog/displayproduct.cfm?productID=2032 Before I purchase I just want to verify I'm not making a mistake. Can anyone verify this, or offer alternative condenser advice and source for purchase? Thanks for any help you can offer. |
You're on the right track.
Edmund Optics makes great, precise lenses, but are still quite expensive for experimenting. You may find that a 50.8mm diameter works great, but the 76mm focal length is too short. Having to buy all those $30+ lenses would add up fast. I recommend taking a look at SurlpluShed. They have lots of lenses that cost substantially less than Edmund, but will work just as good for prototype and experimentation. Then, once you make your decision/calculation and are ready for the final build, you can purchase the exact lens you need from Edmunds. |
When I get a hold on some money, I'll buy myself a brand new condenser lens, since every lens I have gather from old projectors are either made of plastic or full of scratches. Since a new lens probably comes with a big pricetag, I just want to now if anyone can recommend buying ONE 60mm lens with 66mm FL? 66mm FL is the closest thing the optician could get me ..
Alright, this is getting old, the same old bitching about condensers .. sorry, but I need understand this before I do something stupid and expensive .. :) So with ONE 60mm lens with 66mm FL after the GG, I can expect the following: 1. No hotspot 2. Image distortion So, I guess my question is .. will I have image distortion, even though my FL is bigger than the lens diameter? .. Or will image distortion be introduced once you go under that value ? |
I do, however, remember one member using a 50mm diameter, 50mm focal length lens and commenting that it produced too much distortion. |
| All times are GMT -6. The time now is 11:51 AM. |
