-   Alternative Imaging Methods (https://www.dvinfo.net/forum/alternative-imaging-methods/)
-   -   Ground Glass Grain (https://www.dvinfo.net/forum/alternative-imaging-methods/36545-ground-glass-grain.html)
Chris Rubin December 24th, 2004 09:00 AM
I find Aftereffects most convenient for jobs like this, because you have to create a project like Bob suggested only once. With every new clip, you just replace the incoming file and you're done. Aftereffects also supports realtime preview (given your system can handle it).
The 'layer stacking' Bob describes seems to be the same as native 'echo' function in aftereffects. I've used it to clean up nighttime footage in music videos I've done.
Chris
Jim Lafferty December 25th, 2004 10:27 AM
<<<-- Originally posted by Chris Rubin : I find Aftereffects most convenient for jobs like this, because you have to create a project like Bob suggested only once. With every new clip, you just replace the incoming file and you're done. Aftereffects also supports realtime preview (given your system can handle it).
Chris -->>>
You should be able to just replace media in Vegas, too. Ditto the realtime preview.
- jim
Richard Mellor December 31st, 2004 03:33 PM
static adapter
hi everyone I sent a email to cris hurd with a photo of the static adapter .I will be linking to it soon
Jim Lafferty January 1st, 2005 10:53 AM
I've been trying to replicate Chris's results using Vegas with mixed progress.
In Vegas, I'm running the inverted grain image along a track, and parenting it to a copy of the footage I'm degraining. Then, I set the grain track to luma mask, and on the copy of the footage (the composite child), I'm adjusting luma up, to bring the darker grain of the image within the range of the brighter grain of the original footage.
All of this is placed over the original footage, left untouched.
I will say it *supresses* the grain, but does not remove it entirely -- it looks good for stills, but in motion it doesn't add up to a 100% grainless image, and in reality there's little aesthetic difference between one kind of grain and the other.
I tried the AE 6.5 demo today, just to see if AE would treat the image differently than Vegas using Chris's technique -- the results aren't as good as I got with Vegas, but I'm left with the impression that with a little tweaking, I could get them close to one another. Still, it's not a completely grainless image.
I'd like to be proven wrong -- Chris, if you've got some footage to show at full DV res, I'd be happy to host it for a bit. I'd really like to see the results in motion...
- jim
Filip Kovcin January 1st, 2005 11:10 AM
just wandering - did anyone tryed to subtract grain with "digital fusion" (probably now "maya fusion")?
some time ago i saw brilliant results with that software, but i never use it.
maybe someone has expirience with it?
filip
Aaron Shaw January 1st, 2005 11:31 AM
I'm not sure of this but you could try using After Effect's (6.5 pro) degrainer to do this task. I know you have to sample the footage first - perhaps you could use the grain image as this sample? I think AE will literally perform a subtraction (not just a manipulation of overlay settings).
Richard Mellor January 2nd, 2005 05:41 PM
grain
Hi everyone: If anybody has info on this one too.
http://www.retouchpro.com/reviews/grainsurgery/
John Nagle January 2nd, 2005 06:39 PM
Richard,
I have seen footage that was treated with Grain Surgery and the results were stunning.
On another note I was talking to a friend who is involved in sandblasting and he says he can get a finish down to 3 microns so I was wondering what would be the ideal finish for frosting glass in microns or grit rating?
Chris Rubin January 3rd, 2005 03:31 AM
I'm sorry, but grain surgery just doesn't do it. Just blurs your fine detail. If you want good results, the only decent noise reduction plug-in I'm aware of is NeatImage. But whatever you use, the video will still look 'doctored'.
Chris
Aaron Shaw January 3rd, 2005 10:48 AM
Chris, I know for a fact that it does more than blur fine detail. You literally sample an area of the frame and the software attempts to intelligently remove the noise. Doesn't always work well of course but it can work amazingly well when done correctly.
Jim Lafferty January 3rd, 2005 10:57 AM
Chris,
Any chance we can see some footage using your method?
I'm not getting stellar results and I'm worried it's just because I'm missing something...
- jim
Chris Rubin January 3rd, 2005 02:16 PM
I'll post my tests as soon as I get my adapter assembed again (in a few weeks probably). I designed a new adapter with threaded tubes (enables me to adjust the gg distance from both the camera lens and the 35mm lens on the fly) and I'm waiting for the parts to be finished.
Richard Mellor January 3rd, 2005 02:32 PM
static adapter
I have been thinking about adding this part.
http://www.thorlabs.com/ProductDetai...roduct_ID=1486
Joshua Starnes January 3rd, 2005 03:32 PM
Richard, when are you going to e-mail out some information on the finished adaptor you were talking about?
Richard Mellor January 4th, 2005 09:18 PM
35mm adapter parts list
hi everyone: this is a link to a new thread with complete parts list
and photo
http://www.dvinfo.net/conf/showthrea...threadid=37296
